| ProXimaCore |
 ProXimaCore Dougal
 Posted: 16:31 - 31 Jul 2004 Post subject: Refilling engine oil frequently |
I've had my bike GSXR400R 1990 for 3 months now. I've done 3000 miles in that time with it. I have had to refill the engine oil twice since then. More than 3 litres each refill. I was under the impression that engine oil remained inside the engine and was just reused over and over then you changed it once in a while when needed. My bike seems to be drinking it up and I was just wondering if this was normal? I didn't once need to refill the oil in the 2 years i had my car.
 ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Frost |
 Frost World Chat Champion
 Posted: 16:39 - 31 Jul 2004 Post subject: |
you should change it, not refill it. bikes naturally lose some oil, allthough yours seems to be worse than most
Check if it smokes when hot/cold/low revs/high revs
high revs when cold often cause alot of smoke and oil loss |
| rizo-sri200 |
 rizo-sri200 Trackday Trickster
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 16:48 - 31 Jul 2004 Post subject: |
Damnit, I'm worried now. There's no smoke that I can see coming out of it and my mate says he's never seen any when riding behind me.
And having the NSR before this has always taught me to warm the engine up properly first. So I have always done so with this bike. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Frost |
 Posted: 16:55 - 31 Jul 2004 Post subject: |
Well the oild has to be going somewhere!
you sure your checking the oil at the right time and not checking it one time when cold, and then another time when warm? |
| ProXimaCore |
 ProXimaCore Dougal
| Guest |
 Guest Brolly Dolly
| Robby |
 Robby Dirty Old Man
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 19:55 - 31 Jul 2004 Post subject: |
It's got about 24,000 Km on the clock. Don't know what that is in miles.
Yes I filled it up to the level in the window like you said.
My Dad reckoned it could be the rings as well. Seems as if everything is going wrong for it at the moment. Was going so well up till now too.
The new problem I now have is the engine doesn't rev right. It sounds funny and there's a distinct lack of power when applying the throttle. It's only been like this today.
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 20:09 - 31 Jul 2004 Post subject: |
Actually I've noticed it doesn't idle right lately either, the revs take a while to settle from even a slight rev. So, I'm guessing the mixture is getting screwed up. Is this related to the piston rings being knackered? ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| Guest |
 Guest Brolly Dolly
| Robby |
 Robby Dirty Old Man
| mr jamez |
 mr jamez World Chat Champion
 Posted: 23:58 - 31 Jul 2004 Post subject: |
As has been said, that much oil has to be going somewhere! If it isn't under it on the garage floor and isn't burning it (you should be seeing some serious smoke if that is the case and loads of soot round the exhaust) then there aren't many other places on a bike 3l of oil would fit. In the belly pan, the airbox?
Another place to look is in the radiator, see if there is any oil in the coolant which would indicate a fecked head gasket. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dibbster |
 dibbster Nearly there...
 Posted: 00:16 - 01 Aug 2004 Post subject: |
3 litres is a lot of oil. In fact from the sound of it you are going to need shares in Shell! 24,000 km is about 16,000 miles which isn't a huge distance. If its is burning 3 litres at that rate, you should know about it because everywhere you go will be under a blue cloud. Hope you find the problem and the solution isn't too expensive. ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
 Posted: 01:13 - 01 Aug 2004 Post subject: |
6 litres of oil over 3000 miles is a hell of a lot.
It probably is just about within the acceptable limits quoted by the makers but I would not be happy with it.
If you have run the engine out of oil then you will probably have done quite serious damage, primarily to the big end bearings but also quite likely to the valve gear (one of the last things on the lubrication circuit).
Did the oil light ever come on while riding?
| ProXimaCore |
 ProXimaCore Dougal
| Claud 14.7 to 1 |
 Claud 14.7 to 1 World Chat Champion
| Claud 14.7 to 1 |
 Posted: 13:04 - 01 Aug 2004 Post subject: |
Suzuki claimed come stupid oil consumption was within specs for the later type 1200 Bandit when they screwed up and bored the oil holes in the pistons in the wrong place / too large so that they allowed oil above the oil control rings.
Anyway, if you put 3 litres in with a spec of 2.9 litres it was out of oil. Does the oil light come on when you turn the ignition on, or when you press the start button?
A 4 stroke engine relies on a good supply of oil at a good pressure. If it is deprived of that then it will have major problems and will damage the crank (or if you are just just the shell bearings on the crank). The crank really needs a good oil supply (for example the 1200 Bandit oil pressure at 3000rpm is 43~85psi). If it has done damage then filling it with oil will not fix the damage (and dealers often see bikes suffering from lack of oil failures which just happen to be full of clean oil).
Also bear in mind that the oil does a good job of cooling the cams, etc. With no oil supply the cams will overheat, possibly turning blue.
| Big Pete |
 Big Pete Spanner Monkey
| Big Pete |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 19:49 - 02 Aug 2004 Post subject: |
Changed the fuel in my bike today. There wasn't much left in the tank and I had suspicions about it being funny. Anyway I refilled the tank and the throttle response and the funny noises have gone completely and it seems to be back to the way it was. Except the idling part taking a few seconds to settle. Could just be something as simple as adjusting the mixture screw, I haven't tried it yet. (don't have the tools to get under the tank Must go out and get them)
So it's just down to the oil being burned quickly. I had a few others mention check the spark plugs, so I guess that's the first thing I should try.
Cheers for all the help guys. You've all been great. No doubt I'll be back to ask more questions though.
| AcIdBuRnZ |
 AcIdBuRnZ World Chat Champion
The last post was made 22 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
