| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 15:13 - 27 Nov 2010 Post subject: ER5 Valve Clearances |
I'm adjusting the clearances on the ER5 this weekend, but I'm stumped at what this means in the manual:
https://i15.photobucket.com/albums/a376/ms51ves3/VC.jpg
Any ideas? It's mainly the pictures that are confusing me. What are they showing? Obviously they are showing valves, but why are the valves in the bottom picture rotated 90 degrees? What's the dot on the valves indicate?
| finpos |
 finpos World Chat Champion
| ms51ves3 |
 Posted: 16:42 - 27 Nov 2010 Post subject: |
Remember you'll need two new o-rings to go round the rocker cover coolant pipes. If you don't use new ones, they will leak.
As said, those pictures show the position of the cams where you should check the clearances. They are marked with two lines and a punch mark.
You rotate the crank until the marks are in those positions. Remember you can be 360 degrees out, that position will appear twice in every cycle. So check the cam lobe is pointing away from the rocker, if it's pointing towards it (valve opening), you need to do another full turn of the crank. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ms51ves3 |
| Itchy |
 Itchy Super Spammer
 Posted: 17:34 - 27 Nov 2010 Post subject: |
ESB bolton keep a ton of stuff in stock, they might have them. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| ms51ves3 |
| robocog |
 robocog Traffic Copper
 Posted: 19:41 - 27 Nov 2010 Post subject: |
Any garage workshop will have an o-ring kit with an assortment of o-rings in it. If you take in the old one, they'll be able to sort you out with a new one.
Halfords also sell o-rings. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| robocog |
 Posted: 19:46 - 27 Nov 2010 Post subject: |
14mm x ?
I'm sure I looked in at Halfords at the kits and they didn't have an equivalent (and ended up in desperation re-using mine at great hassle)
I'm sure I wrote down the cross section and it wasn't a common size?
Anyway where I got mine from...part way down the page
https://www.gpzzone.co.uk/gpz500s/acatalog/Flexible_hoses__pump__Thermostat__coolant_etc.html
50p each
not connected to the company in any way....just had good service when I bought mine
Regards
Rob ____________________ Needs a bigger garage... |
| robocog |
| ms51ves3 |
| robocog |
 Posted: 22:29 - 27 Nov 2010 Post subject: |
nope deffo 18mm as theres 2 lots of 2mm
Paint diag coming right up...
Regards
| robocog |
| ms51ves3 |
| ms51ves3 |
| robocog |
| robocog |
| ms51ves3 |
 Posted: 23:00 - 27 Nov 2010 Post subject: |
Cheers Rob, Stinkwheel, Finpos and Itchy  |
 Posted: 02:07 - 28 Nov 2010 Post subject: |
The water pipes are a piece of piss to refit if you use new o-rings. You just shove them in.
There are oilways under the rocker cover, you can adjust the tappets with them in place but it can be easier to get the feeler guages in if you remove them (otherwise you need to put a 45 degree bend in the feeler guages). As said, removing and refitting them is not as scary as it looks. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Asimo |
 Asimo Spanner Monkey
 Posted: 16:11 - 28 Nov 2010 Post subject: |
Simply Bearings have the correct sized o-rings in stock but they're rather expensive. Especially since their prices are excluding vat. |
| chris-red |
| ms51ves3 |
| chris-red |
 Posted: 10:30 - 29 Nov 2010 Post subject: |
Sent first class this morning, you should have them tomorrow. Look out for a scrapy 'envolope' with is really a folded over bit of paper with lots of tape.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| ms51ves3 |
 Posted: 12:24 - 29 Nov 2010 Post subject: |
Cheers Chris  |
The last post was made 15 years, 335 days ago. Instead of replying here, would creating a new thread be more useful? |
