REMINDER - Antifreeze!
PostPosted: 23:14 - 27 Nov 2010    Post subject: REMINDER - Antifreeze! Reply with quote
Just a reminder to everyone to check they have antifreeze in their bikes.
Popped core plugs are no fun at all!
Quote Me Happy
PostPosted: 23:16 - 27 Nov 2010    Post subject: Reply with quote
Air cooled FTW Dance!
On a side note, does antifreeze 'go off' after a while?
My Gasser's had the same stuff in it for a year and a half, just wondering if I should change it?
PostPosted: 23:27 - 27 Nov 2010    Post subject: Reply with quote
I think it does but not if the bike is in storage and not run. I'd guess that it would take a long while until it lost all 'anti-freeze' properties, if ever.
Unfortunately, last winter my 'busa which had only water for coolant froze up in the garage and popped the core plugs in the head. Was no harm done and not much effort to put them back in but a pain in the backside draining & flushing the water out of the engine. This year the coolant is drained.
PostPosted: 23:41 - 27 Nov 2010    Post subject: Reply with quote
I've read that anti-freeze can start to corrode some bits if left for too long, thus you're supposed to change it regularly.
Apparently this can often explain head gaskets going in a bit older cars.
If your core plugs do go, drain straight away.
Do not run the engine a few times to work out why your oil is full, then why it's all white and misty.
Definitely do not do this four days before your first race of the season.
Then you've got to do an awful lot of oil flushes to remove all the mayonnaise. Not the ideal start to a season.
LongJohn22
PostPosted: 23:57 - 27 Nov 2010    Post subject: Reply with quote
Anti-freeze is an all year treatment, and amongst other things, is designed to protect against corrosion. If you fill an alloy engine with plain water, chances are you will suffer internal corrosion, in most cars, barring leaks, the anti-freeze that was initially used to fill the cooling system will still be there when the vehicle breathes its last. I have little reason to believe bikes are any different. The name "anti-freeze", is itself a misnomer, most people these days buy "coolant".
PostPosted: 00:34 - 28 Nov 2010    Post subject: Reply with quote
A link to a random google result I found https://bioengr.ag.utk.edu/ExtProg/machinery/Articles/engcool.htm relating to degradation of antifreeze. I was researching issues with my car and found a variety of discussions on this subject. All just 'net research, but evidence points to it being reasonable.
PostPosted: 08:51 - 28 Nov 2010    Post subject: Reply with quote
You don't put anti-freeze in a bike to be used on a track John, in case of spills.
I bet there are a good few bikes on the road too who have none, perhaps because it was drained during maintainance/work by the owner and temporarily replaced with water then forgotten about.
Paxovasa
PostPosted: 08:58 - 28 Nov 2010    Post subject: Reply with quote
Thanks for the reminder Thumbs Up
Who do I send the repair bill to for putting antifreeze in an oil cooled engine? Razz
PostPosted: 13:34 - 28 Nov 2010    Post subject: Reply with quote
Well I'll give you the conclusion from some properly controlled, qualitative research (don't still have the actual figures). My sixth year chemistry project was on corrosion rates in steel and ways of reducing this rate.
One of the common corrosion inhibitors used in anti-freeze is sodium nitrite. This significantly reduces the rate of iron ion production in solution (the first step in corrosion). Something like a 70% reduction when used at anti-freeze rates.
It DOES however become exhausted, the Nitrite "mops up" the free protons in the redox reaction by reducing to nitrate. The longer it sits, the less effective it is.
This process is ongoing, even if it is just sat doing nothing but the rate of corrosion (and therefore nitrite degradation) is increased by temperature. It'll go off anyway but will go off quicker if the engine is run up to working temperature regularly.
There is another factor though. Bringing the coolant up to boiling point drives any dissolved oxygen out of the liquid. Corrosion rates in water that has been boiled then allowed to cool without being in contact with the atmosphere for more oxygen to dissolve (I used a layer of oil on the surface of the water to achieve this) are much reduced.
I do wonder, since the coolant is pretty much a closed system, if this has an effect too. Wouldn't surprise me if it is significant in the context of an engine but I didn't go that far. I was concentrating on steel load-chain used in marine environments and suggested storing it in a tank of fresh water with a layer of oil on top rather than dumping it on the deck of the rig would significantly increase its useful lifespan.
The last post was made 15 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 63.87 Kb
