Generator cover buggered, what happens
slyrob
PostPosted: 01:04 - 28 Nov 2010    Post subject: Generator cover buggered, what happens Reply with quote
A product of my recent adventures was the destruction of what the parts list names as the generator cover. Seems I am looking at £90 unless I find one at a breakers, What fluids or oil etc might I have lost from here and how would I repair this?
Please help me I want my bike back!
Thanks Rob
Edit: should add it's not an r6 it's a thundercat
https://i878.photobucket.com/albums/ab349/slyrob/IMG_1681.jpg[/quote]
Pitslayer wrote "it could be Ndubz.....ruining this once great place with donkey gobbling loafer knobbing "music".
silky666 wrote "In my eyes, when you shake cocks with the devil, you may as well go for the full reach around"
Villers wrote "as reliable as a ginger stepchild on smack"
PostPosted: 01:32 - 28 Nov 2010    Post subject: Re: Generator cover buggered, what happens Reply with quote
Looks beyond sensible repair - keep an eye out on ebay and maybe have a look on r6messagenet if it's still going.
slyrob
PostPosted: 01:41 - 28 Nov 2010    Post subject: Reply with quote
I didn't mean repairing the cover I just wondered what's behind it and should it be filled with fluid? Does it need a new seal when replaced
MaybeGuy
PostPosted: 01:46 - 28 Nov 2010    Post subject: Reply with quote
one of two things behind it.
one, cover comes off, just a flywheel.
the other is the stator plate and generator coils mounted to the plate.
it's more than likely the second one. oil behind the seal.
as long as you dont tear the gasket getting it off, should be fine to reuse with a bit of hylomar if needed.
easy enough to swap over
Casper
PostPosted: 01:51 - 28 Nov 2010    Post subject: Reply with quote
This
slyrob
PostPosted: 02:04 - 28 Nov 2010    Post subject: Reply with quote
1888 wrote:
If it was an r6 I probably would have found that too!
MaybeGuy
PostPosted: 02:07 - 28 Nov 2010    Post subject: Reply with quote
i was thinking the same thing.
is it an FZR genesis?
slyrob
PostPosted: 02:09 - 28 Nov 2010    Post subject: Reply with quote
Nope it's a thundercat although I nearly bought an fzr!
MaybeGuy
PostPosted: 02:14 - 28 Nov 2010    Post subject: Reply with quote
well it would appear that the thundercat one seems identical to the FZR one (same engine?) so at least that narrows down the parts search
https://cdn.bikechatforums.com/files/fzr600_068_116.jpg
Teflon-Mike
tl;dr
PostPosted: 02:27 - 28 Nov 2010    Post subject: Reply with quote
This and lots of other questions are answered by the Haynes Manual.......
Looks like a TZR motor, be helpful to know what it is, rather than having to work it out from the photo.
Some bikes have a 'wet' generator, that runs in the engine oil. Some have inverted generators with the stator coils bolted to the inside of the cover. Your, I THINK is a conventional 'dry' generator, so the cover should be no-more than just a cover, keeping water and crud out of the gernerator.
So you shouldn't have to worry about any fluids leaking out. That's the good news.
Bad news is that generator covers are, as you have discovered, vulnerable when a bike goes down, therfore, they are one of the parts there tends to be more demand for than supply, hence expensive. True, people do scrap motors from siezing them or melting pistons, and sell off the bits, but theres still more people who want them than people flogging the bits.
So, you have four choices:
1: Pay the Yamaha main-stealer price for a new part
2: Pay an inflated price for a 2nd hand price from a breaker
3: hope to get lucky on e-blay
4: Bodge it!
In trials, its quite common for the mag covers to get badly mashed, and to be honest, I have seen worse than yours, filled up with gloop to keep the water out. Even seen as badly damaged covers, on classics where replacements are more difficult to procure, made good enough for a show bike with judiciouse cosmetic surgery with lumiweld.
Personally, for a better than average 'bodge' I'd go with araldite and aluminium filings. See here: [b]The 'Loaded' Epoxy Repair worked for me before in such instances.
Thats a BIT of good news, HOWEVER; running milimeters behind that mashed metal is the flywheel, which is a heavy chunk of metal, rotating at high speed, directly on the end of the crank, and wizzing around in close proximity to some big coils of wire.
Not unknown for a heft smack on teh side to push metal into the flywheel, and in severe cases actually bend the crank. Early 80's Kawasaki, inline four's were a bugger for it, as the angle of impact tended to be quite oblique and put more bending force on it, where a narrower single, HOPEFULLY will get smaked more end on.
But, risk that a smak on the flywheel, could have off-centred it, which may cause high speed vibration, that will wreck main bearings in a a hurry, or more likely, effect the generator and ignition.
So that lot needs checking out, and really the cover round the outside is probably the least of your worries.
Oh, yes there will be a seal in there, its on the end of teh crank-shaft, behind the rotor. Keeps the charge in teh crank case as the piston rises and falls pumping it through the transfers into the cylinder. Not likely, but possible it might have been damaged by impact, more likely it would fail if the end of the crank is running eccentric becouse its bent.
slyrob
PostPosted: 02:47 - 28 Nov 2010    Post subject: Reply with quote
As mentioned above twice its a thundercat! a 1997 yzf600r. How would I tell if the if the flywheel has been knocked off centre?
Tristan.
PostPosted: 03:03 - 28 Nov 2010    Post subject: Reply with quote
take the cover off and tern it over measuring the runout (if any)
The thundercat bottom end is common to many bikes, FZR600 4JH and 3HE FZR 400 3TJ but not 3EN1-2
Teflon-Mike
tl;dr
PostPosted: 03:09 - 28 Nov 2010    Post subject: Reply with quote
They weren't posted when I started typing..... could have said at the start!
As for telling if the cranks bent or the flywheel 'out', you need to start by taking the cover off and having a look.... it might be quite obviouse.
If not, you need to 'clock' it with a Dial Test Indicator. Little plunger device that sits in a dial, you clamp to the casing, resting the plunger on the flywheel. You then rotate the crank carefully by hand, slowly and watch the needle, if it moves (it probably will) then the flywheel's not round.... it probably isn't that round to start with, so you have to see what the book says as far as tolerences go, but big needle movements not good.
You do it on a few places accross the width of the flywheel, becouse if it is skew, you'll get more deflection at the front of the flywheel than you do at the back, at the same point in rotation, that will be mirrorered when you rotate it 180 deg.
Its not a job that your average independent back-street mechanic or ameteur bodger would do, but if you can beg-borrow or steal the tool, its not that difficult.
Not as accuracte, but as a confidence check, you can mimick the set up pivoting 'something' on a bolt into one of the casing lugs, that can rest on the flywheel as you turn it, and magnify the movement as you rotate against a scale on a piece of card-board.
Improvised, garden shed technology, but it can work!
Casper
PostPosted: 03:10 - 28 Nov 2010    Post subject: Reply with quote
slyrob wrote:
Oops
To be honest you are better just getting a new cover and giving the bike a spin round the block and check its charging. If the flywheel took a knock you will see scuff marks on the thing. Was this a high speed crash or a spill and slide?
slyrob
PostPosted: 03:24 - 28 Nov 2010    Post subject: Reply with quote
Many thanks Matt And mike, no problem 1888! I should have made it more obvious! I just don't fancy paying £90 but they seem quite hard to get hold of
Casper
PostPosted: 03:49 - 28 Nov 2010    Post subject: Reply with quote
try this bloke https://www.breakingpoint.co.uk/Yamaha.html
and this forum as a few cat owners here
https://www.therevcounter.com/forum.php
also was the fazer not the same?
PostPosted: 10:23 - 28 Nov 2010    Post subject: Reply with quote
Absolute pigs to get hold of, got one off ebay, just took a few weeks of looking.
If what they say is true )3HE engine) then this..
https://cgi.ebay.co.uk/YAMAHA-FZR600-1990-3HE-ENGINE-ALTERNATOR-CASING-/270669642748?pt=UK_Motorcycle_Parts&hash=item3f052afbfc
I'd snap it up...they sell fast
MaybeGuy
PostPosted: 10:27 - 28 Nov 2010    Post subject: Reply with quote
so difficult...
https://cgi.ebay.com/ebaymotors/Yamaha-YZF600R-Generator-Cover-4TV-15415-00-00-_W0QQcmdZViewItemQQhashZitem4154a8e033QQitemZ280593227827QQptZMotorcyclesQ5fPartsQ5fAccessories
also confirms that the generator is mounted to the cover.
i also wouldnt worry in the slightest about the flywheel being damaged, only the generator coils, and they're much easier to replace.
or...
https://cgi.ebay.co.uk/YAMAHA-FZR-600-GENERATOR-COVER-GENUINE-YAMAHA-PART-/320622957075?pt=UK_Motorcycle_Parts&hash=item4aa69e1213
PostPosted: 10:31 - 28 Nov 2010    Post subject: Reply with quote
I did edit my post Laughing
When i had a crashed FZR in the garden, took me a few weeks to find it, could only find the hardened casings for £100+
PostPosted: 12:31 - 28 Nov 2010    Post subject: Reply with quote
If there's no oil inside there just slap soemthing over it to keep dirt and moisture out until you find a replacement. I'd cut the bottom off an old pot and fix it on there with RTV.
Casper
PostPosted: 22:09 - 28 Nov 2010    Post subject: Reply with quote
https://edinburgh.gumtree.com/edinburgh/78/69308278.html
Ariel Badger
PostPosted: 23:43 - 28 Nov 2010    Post subject: Reply with quote
This will keep the muck out
PostPosted: 10:34 - 30 Nov 2010    Post subject: Reply with quote
At £90 you are pretty close to the cost of a heavy duty aftermarket cover.
However surprised they are that much new. Last FZR end cover I bought (other side) was a lot less than that.
The last post was made 15 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 132.82 Kb
