| dragstaar |
 dragstaar World Chat Champion
 Posted: 22:39 - 27 Nov 2010 Post subject: Has my bandit been frozen to death? :( |
Hey all
I have a Bandit 600 (2000)
Well, I went out this morning, started my bike up on the choke, and she fired up first time. Full tank of fuel, fresh from the night before. A lot of the bike was iced over.
So i ride off, choke turned off, and she started to make that spluttering noise that you have when you start to run low on fuel. there wasn't a noticable difference in the acceleration though. And it got me through my whole 20 mile commute. Every now and then, when i cut off the throttle then opened it again, there'd be a small backfire.
I noticed the noise was only there at low revs (2-3k)
On the way home (i kept my bike indoors in the heated office ) she sounded okay.
I don't have a garage, and wanted to know whether this had anything to do with the temperature plummet, i think it was -2 last night where i live. Is it okay to ride the bike that cold?
thanks in advance |
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| Ingah |
 Ingah World Chat Champion
| Paddy Blake |
 Paddy Blake World Chat Champion
| weasley |
 weasley World Chat Champion
| defblade |
 defblade World Chat Champion
 Posted: 01:22 - 28 Nov 2010 Post subject: |
Yep, carb icing.
Seems some do it, some don't..... my 650 oil-cooled does Sounds nice running on 3 (maybe I have a Triumph hankering...?) but things get a bit shit on 2
Check the carb heaters are working first - the wire to mine was disconnected (probably when I was wiring the heated grips ) which didn't help!
Wynns Dry-fuel can help according to t'internet and indeed it did make things much better, but I was using half a bottle per tank which would run expensive.... I've been given a bottle of the pro-fst by a helpful bloke who's got fuel injection now but it's been snowing since so no report!
Also, turning the bike off and letting the heat soak through the carbs for 10 minutes can sort it for a while, but a bit of a sod on the way to work.
Dealer reckoned it was worth cleaning out the carb bowls too as water can sit under the petrol in those and play up too.
Carb icing happens when cold/damp air is being sucked through the carb rapidly, causing temp drops and then ice forming and potentially blocking jets etc. Seems to happen more in UK than most places as we're colder and wetter Still doesn't explain why only some bikes on a particular model suffer but them's the breaks. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 08:19 - 28 Nov 2010 Post subject: |
It does sound like carb icing, mine has suffered from it occasionally.
As has been said check the wires are connected to the carb heaters, if it starts again lower your speed and keep the revs up (it works for me).  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| defblade |
| dragstaar |
| defblade |
| MarJay |
 MarJay But it's British!
| defblade |
| MarJay |
| Walloper |
 Walloper Super Spammer
| Moo. |
 Moo. World Chat Champion
| dragstaar |
 Posted: 19:38 - 28 Nov 2010 Post subject: |
| Moo. wrote: | My carbs iced up, throttle stuck open :o scary as hell xD |
OMFG! this!
This happenned to me today! was approaching the junction, at the end of my road, choke still on, throttle stuck! yanked the clutch in, the bike started roaring at 10K at 8am on a residential road. Scared me shitless though.
| MarJay wrote: |
The reason why this cannot occur in air colder than 0 degrees celsius is that the moisture in the air has already frozen, and cannot freeze to the sides of the Venturi. This means that in very cold weather bikes that suffer from carb icing are generally not affected.
Your carbs are not frozen when the bike isn't running... So I doubt it is carb icing to be honest, especially if the air temperature is -2. |
So if it ought to have sorted itself out after a few mins, then its not carb icing then, is that what you're saying? Well my commute is 30 mins long. and the carb icing affected me all the way there. So is it not carb icing then?
Funny thing is, this has happened 2 days in a row now, withfreezing weather. But each time, the problem is in the morning, but not when i bring it home.[/quote] |
| dragstaar |
| dragstaar |
| HD |
 HD World Chat Champion
| tahrey |
 tahrey World Chat Champion
 Posted: 17:54 - 01 Dec 2010 Post subject: |
there might be something in the air, mine was doing this in the garage earlier. right bugger to get going, and not happy off choke for quite a while, and sounding sort of different. never heard it backfire before neither, even last winter, but it did today. maybe leftover summer fuel with a bit too much water in it (condensation or just legally allowed) or some other additive that doesn't like cold? it's been standing a while.
water being generated somehow (maybe even ice inside the pipework that's melted) could explain an icing effect. or even air that's not quite frozen, but quite close to it, and so relinquishes its vapour readily as it goes through the fridge-cooler-esque venturi... there's a reason most carburetted machines have carb heaters after all. could even be the fuel freezing if it gets REALLY cold from effective windchill.
I don't know about the specifics of it at all, suspended moisture etc (hey, you get clouds on freezing days, so maybe water vapour acts differently to liquid water? or it might be a lot of molecular-sized bits of airborne ice that only clump together into snow or hail under the right conditions, same as rain forming?) ... just seen a good few claims of this stuff happening on very cold and freezing days over on a car forum I used to frequent.
Simple enough test, really - does it run fine at low speeds, but then splutter or even die if you go faster... thus using higher revs and wider throttle, pushing more air through at higher speed? And slowly but eventually recover if you slow down (more than what you're forced to, that is)? The classic thing was someone trucking along the motorway at 70-80, then being forced down to 50 in the inside lane on full throttle, but being able to get back to a cautious 60ish if they suffered 45 or so far a while.
The other thing might be unhappy ignition leads/coils. I've personally suffered variants of this on injection engined cars which were traced to leads or coils which would have been borderline but operating satisfactorily in dry, warm weather, but couldn't keep up the pace once things got wet or cold (changes the insulator conduction - particularly if it's slightly cracked so rain or condensation can get in... if it's ice, it'll melt and turn to water after a while because of engine heat, they're a lot closer to the block than the carb). One of them didn't run on all cylinders until revved quite hard (regardless of throttle opening), the other just lost power and saw me dragging along at 60mph in 4th on WOT, having been easily cruising 90 in 5th before the rainstorm hit. |
| Robby |
 Robby Dirty Old Man
The last post was made 15 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
