kmx 125 gets hot at low rpms
sam_w
PostPosted: 12:42 - 30 Nov 2010    Post subject: kmx 125 gets hot at low rpms Reply with quote
when riding at lower rpms for long periods of time my temp guage seems to go up to the half way point maybe a bit higher but once i open the throttle up a bit it seems to cool down and go back to normal opertain temperature. if have the bike idling for a while eg. stuck in a non moving traffic my temp gauge will start to rise. any ideas what the problem may be? i have recently changed my coolant. i bled the air as the manual says opening up the bleed screw on the cylinder until coolant starts to seep out freely. is it possible i still have ai trapped in the system. thanks in advance
0ddball
PostPosted: 12:48 - 30 Nov 2010    Post subject: Reply with quote
Doesn't sound like there's any problem. As long as it isn't going right into the red.
The temp will rise and fall depending on speed. Thats why most cars and bikes have a fan on the radiator. If travelling slow for too long there isn't enough airflow through the radiator so the temp starts to rise. When it gets to a certain temp the fan kicks in to bring it down.
sam_w
PostPosted: 14:20 - 30 Nov 2010    Post subject: Reply with quote
it never used to do it though. it only seems to have started since i changed the coolant
DrDonnyBrago
PostPosted: 14:43 - 30 Nov 2010    Post subject: Reply with quote
You are probably just paying more attention to it after changing it.
All bikes warm up when stationary and cool down when moving.
The last post was made 15 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 8.27 - MySQL Queries: 13 - Page Size: 39 Kb
