| sgc1000000 |
 sgc1000000 Derestricted Danger
| dragstaar |
 dragstaar World Chat Champion
 Posted: 14:26 - 01 Dec 2010 Post subject: |
Although it is suspicious, there may be a logical explanation. My bike has a different ignition key because i left my keys in the ignition, and some annoying kids stole them, so i needed a new ignition barrel
You can get a cheapo ignition from ebay
here
They're not too hard to fit. But i suggest you do some standard checks on the rest of the ignition system before you fork out. |
| sgc1000000 |
| ORourke |
 ORourke Two Stroke Sniffer
| sgc1000000 |
| skatefreak |
 Posted: 17:00 - 01 Dec 2010 Post subject: |
Hey,
If you havnt already paied for the bike i would reccomend walking away...
The NSR's can be an absoloute ball ach when it comes to electrics and if he is saying a new wiring loom it would certainly make me think very hard...
Wiring loom is only about £30 on e-bay, a barrel/tank/lock set would be around £50 if yr bothered about only needing one key.
There is a chance the bike will run without a battery connected (my old 4t would) but i am yet to try it with the NSR. All the terminals (round thingys under the seat near the battery) need to be connected to complete the circut and for things to work properlly.
Again, how much are you paying for this? It could prove to be a fair bit of work
What kind of condition is it in cosmetically/mechanically?
-Jvr |
| ORourke |
| sgc1000000 |
| dragstaar |
 Posted: 19:10 - 01 Dec 2010 Post subject: |
Heres a rough guide as to what you need to do to get the ignition barrell off. Technically, the barrell should be a quick switchover, however it does look like there may be something else involved, especially if you can bumpstart it.
Take off your fairings. Its not 100% vital to do this, but it helps to be able to get at the barrell from different angles. It'll make so much easier if you take 5 minutes to unscrew some bolts and take off the fairings
Put your tools down, look at the bloody thing, find where the cabling is leading to. take note of the way it is wired, and the way that each connector fits, write it down if you have to. This will be your chance to expect the rest of the wiring too, seeing as you have the fairing off.
Now, generally speaking, the ignition barrel will be held in by the top yoke, so you'll have to take that off. This means removing it off of your forks.
unscrew anything fastening the barrel and holding it in place. Once again, take note of how it fits. Now switch it with the new one. make sure you have it the right way round!
Clip the barrell into the wiring, and test it. if it starts, then put everything back together!
If it doesn't start, then get a meter and check the system. Start with the whole system, and make sure the circuit isn't broken, If it is, then start narrowing down the amount of circuit that you're testing until you isolate the problem.
As said above, there could be a whole host of issues. The bike does seem dodgy, not to put you off. but do be prepared to find that it isn't the ignition at fault.
To be perfectly honest, i'd do the meter checking before i buy a barrel or take shit apart. it'll save you hassle if you know that the barrel is definitely the solution to the problem |
| sgc1000000 |
| alains |
 alains World Chat Champion
| sgc1000000 |
| ORourke |
| sgc1000000 |
| sgc1000000 |
 Posted: 17:53 - 07 Dec 2010 Post subject: |
| salty21 |
 salty21 World Chat Champion
 Posted: 20:06 - 07 Dec 2010 Post subject: |
looking at that i would just replace the loom, someones had some serious fun in there and your problem could stem from any one of those bodge jobs.
You could test and check all the wires but in my experience, once you start to tamper with a loom the problems snowball and spread like cancer so for the sake of £30 it's well worth replacing the lot. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
94 CB400 Super Four ---- 2000 VTR SP1 (sold) ---- 08 ninja p8f(sold, meh) ----05 CBR600rr  |
| sgc1000000 |
| andym |
 andym World Chat Champion
| salty21 |
 Posted: 21:49 - 07 Dec 2010 Post subject: |
chances are, that wiring is at fault and not the barrel itself (unless the barrel is destroyed) so you may as well get the loom swapped for a decent one and go from there as that may be all you need to do. ____________________ 04 NSR 125(sold) ---- 03 CBR 600rr(sold) ----90 pan euro ST1100 ' ' ----02 CG 125
| sgc1000000 |
| skatefreak |
| sgc1000000 |
| DANNYBOI |
 DANNYBOI Two Stroke Sniffer
| Beelzebob |
 Beelzebob Spanner Monkey
| sgc1000000 |
The last post was made 15 years, 314 days ago. Instead of replying here, would creating a new thread be more useful? |
