could i really have killed my battery so quick?
FLV
PostPosted: 20:05 - 01 Dec 2010    Post subject: could i really have killed my battery so quick? Reply with quote
I have a low mileage fz6, not had it long so i dont know loads about it.
I had no issues whatsoever untill I fitted headed grips.
The morning after i fitted the grips, I rode 5 miles to work, grips on full.
After work, rode 1.5 miles to fuel up with the grips on full.
Grips and engine off whilst fuelling.
Bike wouldnt start, but did bump start.
Then I rode the bike 12 miles, grips off to try to charge the battery.
3 days later - last night, I started the bike and ran it for 10 mins (no grips) to warm the engine as I was going to do an oil change.
Now oil change time (needed a filter tool), flat battery again. Bump started.
Can the battery be totally screwed or is more likely just never got its charge back?
cheers
parp...brap....parp
FLV
PostPosted: 21:32 - 01 Dec 2010    Post subject: Reply with quote
they're wired in according to the destructions. Straight to the battery, they're HG digital ones
parp...brap....parp
xpetop
PostPosted: 22:46 - 01 Dec 2010    Post subject: Reply with quote
Can you not run them through a relay to shut them off if the battery power gets too low?
Also the cold can zap a batteries power
FLV
PostPosted: 22:59 - 01 Dec 2010    Post subject: Reply with quote
probly could if this electrickery made any sense to me
parp...brap....parp
xpetop
PostPosted: 23:14 - 01 Dec 2010    Post subject: Reply with quote
Have a read here mate
https://www.xrv.org.uk/wiki/index.php/Fitting_heated_grips
https://www.bikerforum.co.uk/forums/garage/4222-how-fit-heated-grips-via-relay.html
https://www.r1200gs.info/howto/relay.html
Hope this helps
alan
dragstaar
PostPosted: 00:36 - 02 Dec 2010    Post subject: Reply with quote
give the battery a full charge, then ride for a couple of days with no grips. i.e. physically disconnect them
Then ride with your grips and you'll soon find out whether your grips are an issue.
Cold can kill a battery, esp if you leave it outside.
The last post was made 15 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 56.52 Kb
