Cost of a tropical tank....
PostPosted: 11:06 - 02 Dec 2010    Post subject: Cost of a tropical tank.... Reply with quote
...in electricity.
To heat, filter/pump and light it?
Considering getting my old tank up and running again. It's around 100litres if my memory serves me correctly. 36 " x 12" x 18".
Any ball park figures on a monthly increase to your bill would be grand. Thumbs Up
oldpink
PostPosted: 11:33 - 02 Dec 2010    Post subject: Reply with quote
about the same as burning 1 - 2 x 100w lights
I take it it has a floro lamp which is generally 40 - 60 watts and the heater
if you fill the tank with warm water to start with it will only require a small amount of power to keep the temp up
it may be a bit more say 150w if you have a powerful filter and or air pump
but those are generally low wattage 30 - 50 watts but I doubt it will be any more than 200w in total
instigator
PostPosted: 12:26 - 02 Dec 2010    Post subject: Reply with quote
About £12 per month tops.
TimNorwich
PostPosted: 13:14 - 02 Dec 2010    Post subject: Reply with quote
It can all vary, if you only have the light on 6hours a day, as opposed to the full 8-9hrs most have it will be cheaper. The heater isn't much of a problem as that only kicks in when the water drops below a certain temp.
I don't think it will be £12 a month, that is quite pricey. I doubt you'll even notice it in the bills, you could try cut back elsewhere if you're really worried.
cagiva gezzer
PostPosted: 19:41 - 02 Dec 2010    Post subject: Reply with quote
The filter in my 125L is only a couple of Watts. The large, 3,000L/hr pump in the pond is only 60Ws.
Add in a couple of strip lights for a few hours and it'll be <100Ws most of the time, with the heater on for a small amount sometimes.
The amount of heating depends on the temperature of the room.
MinhDinh
PostPosted: 19:48 - 02 Dec 2010    Post subject: Reply with quote
Not sure but check the wattage of your bulbs.
Unlikely to be halogen and at 100 litres, most likely 28 W or something.
The heater isn't much either, maybe 6 quid a month at a guess. 20P a day!
Hit the G spot. Wink
The last post was made 15 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 47.81 Kb
