ducati wheel bearing size
yankeedoodle
PostPosted: 21:05 - 04 Dec 2010    Post subject: ducati wheel bearing size Reply with quote
hi guys
hope someone can point me in the right direction. does anyone know what size bearings the duke 999 takes? Just need the inside and outside diameter for both wheels.
thanks Smile
Bandit 600
PostPosted: 22:02 - 04 Dec 2010    Post subject: Reply with quote
I've just searched the uk ducati forum. No joy.
You can search the american one Wink
They're £5 each if that helps at all.
Pat
woodyfjr
PostPosted: 11:39 - 05 Dec 2010    Post subject: Re: ducati wheel bearing size Reply with quote
yankeedoodle wrote:
hi guys
thanks Smile
If you prise the water seals out there will be code on the edge and then you should be able to find the size.
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
Ed Case
PostPosted: 11:46 - 05 Dec 2010    Post subject: Reply with quote
Bearing races are manufactured to international standards except for specialist applications with peculiar requirements. Where bikes are concerned the vast majority are common-or-garden sizes and given reasonable care (no invasive power-washing) should pretty much last the expected life of the bike. The only sure-fire way of knowing for certain is to get them out and read the numbers on them, they will almost certainly be off-the-shelf items at a decent bearing supplier. Get good stuff, FAG,SKF or a recommended brand, avoid un-named gear in plain boxes, they're cheap for a reason. I've had WOP bikes for the thick end of thirty years and what the 'book' says isn't necessarily true.
Bezzer
PostPosted: 12:24 - 05 Dec 2010    Post subject: Re: ducati wheel bearing size Reply with quote
I'm betting this is for a project so he doesn't have the wheels yet and just trying to find out if he can use them.
That right Matt Question
hmmmnz
PostPosted: 12:41 - 05 Dec 2010    Post subject: Reply with quote
using this for the part number i find this and from that i found this
or the short answer is 25x47x12mm bearing
its all about using your google cross referencing skills Mr. Green
the humans are dead
I kick arse for the lord
yankeedoodle
PostPosted: 18:25 - 05 Dec 2010    Post subject: Reply with quote
cheers guys.
mick, yes you would be right but shh!!! Very Happy
hmmnz, thankyou for taking the time to research it. I asked a couple of ebay sellers what diameter the 999 spindle was and they reckon 32mm. hopefully thats right because id rather the bearing be too big for the spindle than too small
Bandit 600
woodyfjr
PostPosted: 19:25 - 05 Dec 2010    Post subject: Re: ducati wheel bearing size Reply with quote
Ok I didn't realise.
Some bearings are specially ground out to except larger diameter spindle/axle.
yankeedoodle
PostPosted: 19:30 - 05 Dec 2010    Post subject: Re: ducati wheel bearing size Reply with quote
woodyfjr wrote:
Ok I did realise.
appreciate it all the same woody thanks mate
Bandit 600
hmmmnz
PostPosted: 04:42 - 06 Dec 2010    Post subject: Reply with quote
yankeedoodle wrote:
cheers guys.
32mm for a spindle?? they must be smoking crack, you obvisously realise how big 32mm is, far too big for any bike ive ever seen, especially as something as lightweight as a 999
the humans are dead
yankeedoodle
PostPosted: 08:27 - 06 Dec 2010    Post subject: Reply with quote
yes i know how big 32mm is.but the gsxr spindle im curently using is 28mm so its only 4mm bigger and the gsxr one isnt heavy at all
Bandit 600
woodyfjr
PostPosted: 08:54 - 06 Dec 2010    Post subject: Reply with quote
The larger the spindle size the better/lower the rolling resistance and load.
Remember the Melling Norton those bearings were massive the id must have been 80mm.
The last post was made 15 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 76.62 Kb
