suzuki ay50 wr head gasket replacement
iamspim
PostPosted: 01:25 - 07 Dec 2010    Post subject: suzuki ay50 wr head gasket replacement Reply with quote
So I got my scooter back from the garage after having a mechanic look at it for a couple of hours (100 bloody quid!) and he says it needs a head gasket replacement.
Now I basically have a ped that I have already spent too much money on and I really need to fix this myself, is it an easy job? I have some basic mechanical knowledge and all the time in the world, but can't find a manual for this scooter anywhere.
Can I do this myself, getting the top end off and buying the gasket set on ebay for about 10 quid?
I have kidnapped your signature, pay the ransom of one million Ugandan dollars for it's safe return!
iamspim
PostPosted: 01:42 - 07 Dec 2010    Post subject: Reply with quote
it wont run and the guy i left it with tried loads of stuff with the carb and reeds etc and when he gave it back he said its probably the head gasket as he'd tried most other things, dunno what else it could be that he wouldn't have tried in 2 hours.
connornrg
PostPosted: 12:24 - 07 Dec 2010    Post subject: Reply with quote
i doubt it is the head gasket as many of my bodge mates dont even use them =) do a compression test!
Bikes (Not Bikes Really Just Shitty Mopeds)
**04 - Piaggio NRG MC3**02 - Yamaha Aerox 50/100**07 - Piaggio NRG Power - Shit.**
fiery tupp
PostPosted: 12:50 - 07 Dec 2010    Post subject: Reply with quote
You can sometimes get away with not using a head gasket from scratch,( NOT recommended ) on an old field bike is the only way I would try, but if one is allready on the head & has blown ,It has to be replaced . THis said I think you should get someone who knows a bit to check it , the so called mechanic sounds dodgy & should have done a compression check to confirm its the head or rings & not just guessing for a £100 tosser Thumbs Down
If you can't fix it with a hammer , use your head .
Gazdaman
I did a trackday!!!
PostPosted: 13:28 - 07 Dec 2010    Post subject: Reply with quote
Agreed, do a compression test, you can buy a cheap compression tester from eBay. Find out what it should be from Google.
If the measured reading is far below, then either it's the head gasket, or work piston/rings or work barrel.
Changing a head gasket isn't particularly difficult, especially if it's a 2 stroke. As long as you take your time, and ideally have a manual with you.
But a head gasket blowing is fairly unusual, it's more likely to be piston rings or work barrel in my opinion if compression is low.
Gaz
The last post was made 15 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 53.55 Kb
