Broken Tax Disk Holders
bryhhh
PostPosted: 12:57 - 02 Aug 2004    Post subject: Broken Tax Disk Holders Reply with quote
First post, so treat me gently Wink
A month ago I found my tax disk holder had snapped, so I replaced it, along with the tax disk only to find this morning that the same has happened again. I had the first one mounted on the swingarm, the second one I mounted on the front mud gaurd screw. I'm guessing that vibration was the cause of the breakage rather than somebody nicking it, as the tax disk that was fitted expired over the weekend.
So the question is where is the best place to fit the damn thing? I have a CBR600, and I'm struggling to find any good locations to fit them as all the fairing bolts are inset. Comments appreciated from any other CBR6 owners.
For info, I've been using this motrax disk holder. I might try one of these these next, as the lug (where my two last ones broke) looks a bit stronger.
Tarmacsurfer
PostPosted: 14:22 - 02 Aug 2004    Post subject: Reply with quote
Hi, and welcome Smile
I always use the cheap stick on plastic beasties, 80p and they attach solidly to the inside of the screen making it damn near impossible to remove the holder and leave the disc in one piece without alot of hot water and careful peeling. Never lost a disc yet to either thieving or just general misplacement.
I'm immortal. Well, so far.
bryhhh
PostPosted: 14:34 - 02 Aug 2004    Post subject: Reply with quote
I always thought all those stick on ones had a slot on the back that allowed easy removal of the disk. I guess I thought wrong! I'll pop into the local halfords on the way home from work and have a nosey round.
Thanks.
PostPosted: 17:17 - 02 Aug 2004    Post subject: Reply with quote
Chances are that someone has been snapping them off and stealing your tax disc. A stolen tax disc is of no use to anyone these days as they use a database to check if a vehicle is taxed before they even stop it.
So why steal them? you may well ask. Because they are Fecking idiots, that is why.
Clear, sticky backed plastic. 60p per metre at all good hardware stores. The traditional place used to be stuck round the frame downtube or the fork leg before all these new-fangled holders came about.
Mine is stuck on the back of the numberplate, you can see it clearly if you know where to look.
marc_yorks
PostPosted: 20:22 - 02 Aug 2004    Post subject: Reply with quote
Idea
just a little tip for all the people who's tax discs get wet with general moisture,go to a printers or stationary shop and get them to laminate your tax disc,stops moisture messing them up.
hustler
PostPosted: 21:01 - 02 Aug 2004    Post subject: Reply with quote
Hmmm, mines currently in my jacket pocket. That reminds me I need to go and buy a holder Shocked
As I said to that guy with the crutches and full camouflage gear, you can hide but you can't run.
clemsta
PostPosted: 21:20 - 02 Aug 2004    Post subject: Reply with quote
My tax disc is also in my pocket, i used one of them clear plastic CD wallets and put it in it and taped up the edges.
It cannot be ripped now and it keeps it dry.
bryhhh
PostPosted: 21:34 - 02 Aug 2004    Post subject: Reply with quote
Thanks for the tips. I've got a stick on holder and put it behind the screen.
If this one goes missing, I'll know for sure that it's some little w**ker that keeps nicking them. Perhaps I should have added a few razor blades Twisted Evil
The last post was made 21 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 56.09 Kb
