| andym |
 andym World Chat Champion
| N cee thirty |
 N cee thirty Banned
| fiery tupp |
 fiery tupp Trackday Trickster
 Posted: 15:42 - 07 Dec 2010 Post subject: |
Haynes dont do a manuaul for 125 intruder & yes I think you would have to take tank off to get to carb propperly try this link for pdf , it may take a few mins to show ? & may help with stripping carb ? ( if its the right type & year ) https://www.scoot.bg/arhiv_na_opisanie_motori/125cc%20(VL125%20A4121%202000).pdf
 ____________________ If you can't fix it with a hammer , use your head . |
| andym |
| CarlosCBR |
 CarlosCBR World Chat Champion
| andym |
| c_dug |
 c_dug Super Spammer
| andym |
| c_dug |
 c_dug Super Spammer
 Posted: 18:04 - 07 Dec 2010 Post subject: |
Assuming that the oil in the airbox has just been vented into there from the crank case then it has nothing to do with the carbs at all.
Not sure cleaning out the carbs will do much to help the issues you are having either to be honest Either way since you have got it that far apart I guess you may as well carry on
Can't be any more help with taking your bike apart as I have never worked on an intruder before. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| andym |
| andym |
| cloric_tzr |
 cloric_tzr Brolly Dolly
| Teflon-Mike |
 Posted: 21:04 - 08 Dec 2010 Post subject: |
If your engine worked on regular 95RON fuel, no reason it would worn ANY better on 97 RON 'Super'.
all it has is a couple of extra RON points which mean it can stand a higher compression ratio and a tad more advance on the ignition without 'pinking'.
If it didn't pink on 95, wont pink on 97, and your wasting your money on the stuff.
Next up; fluids in air-box.
Slimy stuff sounds like oil.
Flamable stuff, petrol
Neither is a good sign.
Most modern bikes have vent-hoses on the gearbox and engine that are fed into the air-box, so any oily vapour from the motor is sucked and burned, rather than dumped as slim on the road.
Likewise the carburettor over-flows.
Lets presume that the petrol was from the vent-pipes, that means that the float bowl (or bowls, does it have one or two carbs?) is over filling.
Means incrorrect float height; worn float valve, or sticking float valve, or.... I cant be arsed..... you need to clean the carburettor(s) and inspect all the niggly bits!
That's a certain. Still many other maledies that could be giving you grief, but petrol in air-box -> over-filling float-bowl venting to air-box.
Incorrect float hight will make the motor run rough. Enritchment from having neat fuel in the air-box make will make it rougher.
You need to sort and eliminate that one first. There may be other problems, but thats your starting point.
Next up; spark-plugs, at the very least, with fuel in the air-box and pottentially an over-flowing float bowl, your motor will have been running bludy ritch, I'd expect your sparkers to be as black as the ace of spades.
THEY need to be pulled, and at the very least cleaned and gapped, if not replaced.
If you have any facility for adjusting spark timing, that should also be done to eliminate variables.
THEN, if its not running better, we can start looking at other stuff.
And the mayonaise in the air-box, could mean that teh engine's been over filled with oil at some point, or been layed over far enough for som eoil to flow into the over-flow.... OR worryingly, that the bores are worn and you have 'blow-by' past the piston rings, allowing combustion pressure into the crank-case making it 'blow' a little oil through the over-flow.
Check the oil level, top up, to mark, and KEEP AN EYE On it. This can give advanced warning of major motor maledies.
Report back when carb cleaned and inspected.
Yes, you probably will have to take the petrol tank off to get at teh carb(s). May be possible without, but usially a lot easier with the tank out the way.
You'll also need to disconnect the throttle cable, and the choke, and the fuel-line. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| andym |
| cloric_tzr |
The last post was made 15 years, 154 days ago. Instead of replying here, would creating a new thread be more useful? |
