Restricting a VFR 400 NC 30. Alternatives to FI
Swifte
PostPosted: 16:43 - 08 Dec 2010    Post subject: Restricting a VFR 400 NC 30. Alternatives to FI Reply with quote
I've finally come to the conclusion I'd like to buy and try out an NC 30 (despite all the negatives).
I don't want to restrict with FI fraud international kits.
Does anyone know or have the part numbers I need to restrict a VFR 400?
I know for example (from this forum) that you need the following part numbers to restrict a CB 500 (my current bike) correctly:
Carb insulator LH: 16221MY5710
Carb insulator RH: 16211MY5710
Larger main jets:
Jet #125: 99101GHB1250 (two required)
The above costing a total of around £35-40 from David Silver Spares.
On another note I'm looking to spend more than £1500 on a VFR 400 but would like to find a pristine example with low mileage, what should I be looking when buying a VFR 400?
0l0dom0l0
PostPosted: 17:58 - 08 Dec 2010    Post subject: Reply with quote
Just have a watchful eye on ebay. I know there was a kit on there not to long ago. You will only need the 4 washers that go in the inlets as the jets will be fine.
Same as any other bike really, just make sure its got a decent service history and a good owner. 400's in general tend to get abused so just double check everything. Also if it had been sat, you can almost guarantee that the brakes will be binding or sticking. As well as other stuff.
Don't rush into anything, but go into stuff with an open mind!
0l0dom0l0
PostPosted: 18:01 - 08 Dec 2010    Post subject: Reply with quote
Result. Just checked ebay.
https://cgi.ebay.co.uk/33-bhp-Restrictor-Kit-Honda-VFR-NC30-/220708092783?pt=UK_Motorcycle_Parts&hash=item33633a3b6f
Swifte
PostPosted: 18:06 - 08 Dec 2010    Post subject: Reply with quote
I'm going to be getting the bike in a few months after christmas, I just wanted the part numbers.
I know you can order the rubber inlets with the washers already in them direct from Honda or David Silvers you just have to have the part numbers.
I did this with the CB 500.
Thanks but I was really after the part numbers like for the CB500 (you can find and order those parts of davidsilvers).
I know you had to up the main jets on a CB 500 from this forum. Do you have to up the jets on the VFR?
0l0dom0l0
PostPosted: 18:18 - 08 Dec 2010    Post subject: Reply with quote
You won't find the washers already in the inlet rubbers for the VFR. Doesn't work like that. The CB 500 Kit your talking about was a kit from Honda themselves. For the VFR 400 they don't make one.
So basically what I am saying is the part numbers your looking for don't exist.
You don't have to up the jets on the VFR no. Best thing to do is once you have fitted the kit is get it dynoed and check the AFR to make sure its not badly lean, if so then you might want to up the jets a couple of sizes. I don't think you will need to though.
ChowderV4
PostPosted: 19:58 - 08 Dec 2010    Post subject: Reply with quote
ebay or 400greybikes
i got mine for 8 quid off ebay and got my dad (engineer) to write a headed letter to insurance company saying he had fitted them, or get a garage to .
Worked fine and that peice of paper from fi international has no legal power at all its just a rip off.
V4 Is The Law
PostPosted: 22:15 - 08 Dec 2010    Post subject: Reply with quote
While I can't be certain, I would be astounded if Honda made a kit to restrict the VFR400. While it was officially imported in tiny numbers for a short while (most are grey imports) this was getting on for a decade before the 33hp restrictions came in, and there would be loads of other bikes Honda would (but don't) make kits to restrict long before the NC30 became worthwhile for them.
ChowderV4
PostPosted: 13:47 - 09 Dec 2010    Post subject: Reply with quote
there are kits out there, but basically they are 4 washers with a certain diameter hole on the middle that sit in the rubbers in between the carbs and the headers.
V4 Is The Law
PostPosted: 14:14 - 09 Dec 2010    Post subject: Reply with quote
Yes, from people like FI who charge a fortune, not from Honda. The Honda CB500 bits the OP refers to do the same job as the FI kit for the CB500 but at a tiny fraction of the price.
PostPosted: 14:20 - 09 Dec 2010    Post subject: Reply with quote
If you actually want the bike to be legal then you'd best get it dynoed to check. I can't see any point in slapping some washers in and hoping for the best - worst case, you crash or get nabbed and your insurer or plod discover that the bike is still producing >25kW, like that poor bugger on the SV650 forums.
So why not have a chat with the guys at a local dyno place? See if they know appropriate washer sizes, or know anyone who knows, or how they'd feel about you turning up with a bunch of washers, a drill and round files, and doing several runs over a day to dial it in?
Alternatively, if you can't be bothered getting it dynoed, why bother even restricting it? You'd have no grounds for believing that it was legal - might as well be done for riding Otherwise Than In Accordance at full power than at 26kW.
ChowderV4
PostPosted: 14:22 - 09 Dec 2010    Post subject: Reply with quote
i would just try to get them second hand, i got mine for 8 quid off ebay , i rrefuse to pay more that £10 for four washers
V4 Is The Law
PostPosted: 14:25 - 09 Dec 2010    Post subject: Reply with quote
Trouble with doing that is after a load of runs and a days effort the bill could easily be the same as buying an FI kit.
I know someone who runs a dyno place and who easily has the skills and tools to fabricate the washers and to test them to get the right size but says it isn't worth the time and effort to screw around doing that even compared to the hideous cost of the FI kits.
ChowderV4
PostPosted: 14:27 - 09 Dec 2010    Post subject: Reply with quote
Rogerborg wrote:
If you actually want the bike to be legal then you'd best get it dynoed to check. I can't see any point in slapping some washers in and hoping for the best - worst case, you get crash or get nabbed and plod discover that the bike is still producing >25kW, like that poor bugger on the SV650 forums.
So why not have a chat with the guys at a local dyno place? See if they know the washer sizes, or know anyone who knows, or how they'd feel about you turning up with a bunch of washers, a drill and round files, and doing several runs over a day to dial it in?
i thought this was the ay to go too, i installed the washers myself and took it to my local dyno for a run costing £40!
reading said it was producing 29bhp, so everything was all good.
I got a print out of the dyno run and sent a copy to my insurer as proof of restriction.....but they didnt accept it!
even though it stated my bke registration ad the exact power it was producing. they wanted a written letter from either fi international (wasnt gunna happen) or my local garage to say they were fitted, it seemed all they wanted to know was that the restrictor washers were fitted not what power it as actualy making.
So i just got my dad to send them a headed company letter just saying that he fit them , and they accepted that.
so i wasted £40 on a dyno run i didnt need.
V4 Is The Law
0l0dom0l0
PostPosted: 16:09 - 09 Dec 2010    Post subject: Reply with quote
I bought a kit off ebay like everyone else does and got my bike dynoed. Came out at 29 bhp. Perfect. Got a print out and that way if you get stopped you can flash the dyno graph.
If the insurance company had said that to me I would have told them to piss off.
At the end of the day just buy the kit off ebay for a few quid. As both keith and myself have pointed out is that honda do not make the kits so you won't find one through honda.
I spend hours and hours researching the whole restriction business as my parents were convinced that I needed to get a certificate blah blah but I refused to pay 200 quid to have some washers fitted and sign a piece of paper totalling a value of about £1.
I got my bike dynoed as for the 35 quid it was going to cost me it was going to save so much hassle later on.
PostPosted: 16:20 - 09 Dec 2010    Post subject: Reply with quote
Then your insurers are being daft pricks. Why give them your business?
And if you made a big claim, do you think they'd still believe your bit of paper, or would it suddenly become a question of what your bike was actually producing?
If you actually care about riding in accordance with your license, then I don't think dynoing a bike is a waste of money. Remember the SV650 chap thought his bike was legal, until plod showed him otherwise.
However, if you're really just after the appearance of legality, then I wouldn't even waste money on washers, let alone a dyno run or an Fi scam certificate - just go with an insurer who takes your word for it, and ride your luck.
PostPosted: 16:29 - 09 Dec 2010    Post subject: Reply with quote
Having read through that guys tale I am not sure that he wasn't diddled. The bike was pretty close to 33hp, certainly well within the range that can be adjusted by playing with manual correction figures on some dynos (seen a 20% correction factor applied to a dyno run before now resulting in an RS125 showing about 35hp). And I would doubt any rear wheel dyno produces a figure that would match with the far more controlled testing that a legal case should require.
0l0dom0l0
PostPosted: 19:34 - 09 Dec 2010    Post subject: Reply with quote
He was released with his bike without charge. The whole thing was a big mess to be honest and was down to a lot of mis communication. I felt really sorry for that guy.
Its entirely up to people if they want to ride with or without their bikes restricted as long as they are prepared to take the consequences. I don't think however we should be encouraging any new rider to ride without restriction. I for one wouldn't want to go through the hassle of being in a accident where the person was unrestricted and therefore uninsured.
We have given all the advice we can. The 4 washers only cost a few quid, and all I was saying with regards to the dyno was it just reduces hassle later on. I was fully aware that I didn't need to get the bike dynoed, but for the few quid it cost and also the piece of mind that the bike was for sure under 33bhp it was worth it. Also in a case like the sv650 you would be more likely be able to argue your case by showing how different dynoes read different things etc.
PostPosted: 19:38 - 09 Dec 2010    Post subject: Reply with quote
It was difficult to work out what happened in the end, but I didn't see anything to suggest that they didn't bill him for the confiscation and storage of the bike, or reimburse him for the loss of use.
0l0dom0l0
PostPosted: 19:41 - 09 Dec 2010    Post subject: Reply with quote
Yeah, it was a long time ago. They also should have compensated him for the damage to his bike. It was involved in a fire at the dyno place. I cant remember if he got anything for that. I will have a read through later!
The last post was made 15 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 112.68 Kb
