| kevinh23 |
 kevinh23 Two Stroke Sniffer
| Lynxx |
 Lynxx Scooby Slapper
| kevinh23 |
| kevinh23 |
 Posted: 20:07 - 08 Dec 2010 Post subject: |
| Lynxx |
| kevinh23 |
| G |
 G The Voice of Reason
 Posted: 20:28 - 08 Dec 2010 Post subject: Re: wheels |
| 2010Lynx wrote: | proply not, if it has motard wheels they are probly aftermarket or from another bike.. the swing arm and triple trees may also be modifed for the motard wheels. if you want it stock with offroad get the stock rims, breaks, spacers and sprockets and hope it fits.. check photos of your bike when it was stock to see if it has been modified. if it is modded it will probly need other parts too.
I doubt anything near that level of modification has been done for that bike For a start, we can see the forks are in a standard dirt configuration - supermoto specific forks tend to have the wheel directly inline with the fork, as you'd find on a road bike.
A standard rear wheel will probably slot straight in. Unless you're doing motocross (in which case, bad choice of bike), go for an 18" rear wheel - this is the standard that came with the bike anyway.
Chain should be exactly the same too.
For the front, your only choice is 21" and again this is standard for the bike.
It's possible you can use the same brake disc, but ideally you want to go for a smaller one.
It's hard to tell from the pictures if that's the standard caliper or not. It's quite common to use the standard calliper spaced further out, however often people will put wider calipers on.
A 4 pot caliper rather than sliding 2 pot probably won't work with the dirt front wheel - the spokes don't angle in as much, so there's not as much clearance. |
| Lynxx |
| kevinh23 |
| G |
| kevinh23 |
| kevinh23 |
| kevinh23 |
| Lynxx |
| G |
| Gazdaman |
 Gazdaman I did a trackday!!!
 Posted: 21:28 - 08 Dec 2010 Post subject: |
https://www.gaz-racing.co.uk/images/vehicle_1148.JPG
This is what standard looks like mate.
https://www.gaz-racing.co.uk/images/vehicle_1149.JPG
Looks like your front brake disk is bigger too, so we might need to swap the bracket etc over aswell.
Gimme an email on [email protected] or PM on here, and we'll work something out. It'll probably be a case of meeting up and swapping stuff over until both bikes work.
EDIT: From my research so far, the 410 has unique sized wheels, apparently even ones from the 610 don't fit. Could be eBay sellers not knowing what they're on about though.
Gaz |
| Gazdaman |
| kevinh23 |
| Gazdaman |
The last post was made 15 years, 288 days ago. Instead of replying here, would creating a new thread be more useful? |
