how to test a coil? and what ouputsshould i see?
badas
PostPosted: 10:03 - 07 Dec 2010    Post subject: how to test a coil? and what ouputsshould i see? Reply with quote
Need to test my coil on a honda mtx 125 (1990) today to make sure its working...
I have looked arround the net and got a rough guide but wanted to know what BCF methods you guys use?
Also what outputs should i be getting from the coil?
Ive lost my workshop manual and struggle to successfully download an online version Sad
thanks
Lynxx
PostPosted: 19:35 - 08 Dec 2010    Post subject: coil test Reply with quote
to test my coils i always just unhook them and then hook a battery to the coil, wrap the ground around the metal of the coil or green terminal. then wrap another ground around the spark plug, then hit the hot wire onto the other terminal of the coil, you should see a spark hop across if its any good. batery may be dead too though so test it first.
Current: 1992 Suzuki GSF400V - 1984 Honda MTX200 (SOLD) - 1975 Honda Xl350 (SOLD) - 1993 Honda CB250 (SOLD)
Lynxx
PostPosted: 19:37 - 08 Dec 2010    Post subject: coil Reply with quote
another easyer way to test it is to just get a strand of wire and run a wire straight from your MTX,s battery to the positive wire on the coil. it should give you a shock if you hold onto the spark plug momentarily as you tap the wire onto the battery if your ground, coil or battery is any good
badas
PostPosted: 22:58 - 08 Dec 2010    Post subject: Reply with quote
don't quite fancy shocking myself from a coil or spark plug .... Razz
had to replace the battery today though as found it was only at 10 volts, the lead plate was also stripping down to copper inside the battery on a few cells and one or two of the cells sempt pretty shagged as they were bubbling badly when charged...
bought a new battery today, charging fine at the moment in time so will get to fit it into the bike tomorrow.
fingers crossed the battery was the source to the problem as i can't afford to spend much more on the bike atm Sad
Lynxx
PostPosted: 23:02 - 08 Dec 2010    Post subject: coil Reply with quote
well a coils only about 7 pounds new for my MTX but a coils a coil anyway. wont make any difference if its for a kawasaki or a honda. and battery being low wouldnt help you at all mate Smile my battery at the moment the ground wire is shorted it isnt even hooked up and it starts without it. your problem is either magneto, coil, Ground or CDI. battery doesnt do anything on a MTX except keep the lights running when the engine is shut off. could of told you that before you baught it
badas
PostPosted: 23:07 - 08 Dec 2010    Post subject: Reply with quote
still need a decent battery to have the thing running at its best and to properly test other electrics though Wink
what coil did you end up getting and don't suppose you have a hains manual for the bike?
it is a honda mtx 125 ain it?
cheers
Lynxx
PostPosted: 23:10 - 08 Dec 2010    Post subject: mtx Reply with quote
yeah it is a MTX125 i have and no dont have a manual but i do have a PDF manual thats in french that i cant read. i can tell you how to test your mtx just by looking at my mtx, i know Hondas wiring color code like the back of my hand
badas
PostPosted: 17:29 - 12 Dec 2010    Post subject: Reply with quote
just bought a new HT lead as the old one was prety shagged to be honest and tested both ends with a ohms setting and getting some good numbers....
so then went and tested using a multimetre the two points inside teh cap where the spark plug connects and the HT lead and got no numbers on the multimetre....
how should i test that the sparplug cap thing isn't broken inside?
thanks
The last post was made 15 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 59.49 Kb
