more GP100 problems!
cb1rocket
PostPosted: 14:52 - 09 Dec 2010    Post subject: more GP100 problems! Reply with quote
Yes i know, its not been great so far.
Anyway its running ok and the full range of the throttle is usable and the bike rides fine.
However when slowing down there is a load of backfire through the carb! What is up with it? Is my timing off? Too advance?
Help!
Lynxx
PostPosted: 16:07 - 09 Dec 2010    Post subject: backfire Reply with quote
guesing its a 4 stroke ? could be the valve/ rocker arm clearances or the timing could also be the carb on the other hand. i dont know to be honest i would just check the valve clearances and timing if its easy to do, if its 4 stroke just take off the little covers on the rocker cover (above the head) and put the engine to Top dead centre then put a feeler gauge inbetween the exhaust or intake valves and the rocker arm/s (what ever one is loosest) then set them to the correct settings, rotate the engine over 360 degrees to Top dead centre then do the same for the intake or exhaust (what ever you did not set) may help you and at most will take an hour to do the job and also may help your performance if they are sloppy or to tight on clearance.
Current: 1992 Suzuki GSF400V - 1984 Honda MTX200 (SOLD) - 1975 Honda Xl350 (SOLD) - 1993 Honda CB250 (SOLD)
cb1rocket
PostPosted: 18:12 - 09 Dec 2010    Post subject: Re: backfire Reply with quote
BLUEX5 wrote:
Anyway, away from planet derp - Check the timing and also bare in mind it could be an airleak. Does the bike idle properly and settle down quickly after being revved?
Cheers Blue
Will have to check the timing other than that the bike idle sweet as a nut and pulls hard in every gear.
Revs do settle down quickly so that should be a good sign i hope.
Running retarded I would imagine loss of power and popping backfiring at any revs. Although retard timing starts easier.
I hope its not too advance cos I don't wanna hole the piston. (newly rebored)
Its only started doing this when i unblocked the main jet. Yes it was blocked to buggery!
cheers
Lynxx
PostPosted: 18:25 - 09 Dec 2010    Post subject: gp Reply with quote
the last gp100 i seen was 4 stroke with 2 valves, or maybe it was a gp125?
truslack
PostPosted: 18:29 - 09 Dec 2010    Post subject: Re: gp Reply with quote
GP125 is pretty much the same bike, with a larger capacity.
cb1rocket
PostPosted: 18:33 - 09 Dec 2010    Post subject: Re: gp Reply with quote
both are 2 smokers!
Lynxx
PostPosted: 18:39 - 09 Dec 2010    Post subject: gp100 Reply with quote
Alright sorry for wrong info on the subject, must have got muddled up, its not like i google the bike up every time i post a comment.
The last post was made 15 years, 287 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 62.23 Kb
