Hi new here and need help please :D
mtx
PostPosted: 15:20 - 09 Dec 2010    Post subject: Hi new here and need help please :D Reply with quote
Hiya folks ! im new here , and im having a few problems with my mtx125 , just wondering if anyone could have answer's to some questions i have, firstly gearbox oil what type off oil need's to be used , and how much off it and how do i adjust the carb mixtures ? cheers thankyou tommy
PostPosted: 15:25 - 09 Dec 2010    Post subject: Reply with quote
Gearbox oil not sure on (and the manual is in hidden around somewhere). Suspect it is a plain 10W40.
As to carb mixtures, where do you think it is out? Depending on the throttle position you need to adjust the idle mixture screw / idle air screw, the needle position / change the needle itself or change the main jet.
Beamexican
PostPosted: 19:01 - 09 Dec 2010    Post subject: Reply with quote
The manual i've got at home says 10w/30
I've been using silkolene light gear oil in mine for about 2 years now on the recommendation of a local honda dealers mechanic who has worked on them from when they were first released.
Not sure how that compares to 10w/30 or if its the same(keith may be able to shed some light on this) but i change it every 2000 miles and never had a problem in over 20000.
Rick
PostPosted: 19:13 - 09 Dec 2010    Post subject: Reply with quote
According to the Silkolene web site their light gear oil is equivalent to a 10W40.
stirlinggaz
PostPosted: 19:29 - 09 Dec 2010    Post subject: Reply with quote
always used rock oil lite or 10w40 (the right cheap stuff)
the carb iself is fairly easy to set up.............
just remembered i gave away my wsm, but im sure there a copy available somewhere,.........
cheers,
GAZ
Beamexican
PostPosted: 19:48 - 09 Dec 2010    Post subject: Reply with quote
Cheers keith always wondered that but never got round to checking,
OP i forgot to say specified amounts are 500ml if your just changing the gear oil or 600ml if your refilling from empty i.e. engines been apart.
Rick
mtx
PostPosted: 21:14 - 09 Dec 2010    Post subject: Reply with quote
cheers guys ! thanks for you help
The last post was made 15 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 51.76 Kb
