car thread, sorry. 94 civic 1.6 DOHC vtec
lukamon
PostPosted: 21:22 - 10 Dec 2010    Post subject: car thread, sorry. 94 civic 1.6 DOHC vtec Reply with quote
basically my idle bounces up and down from 1k - 1500. i have changed for _known_ good items: throttle position, iacv, FITV, and have checked all the vaccuum lines i can see from on top of the inlet mani by pulling them off and starting the car with my finger over the hole on the mani. its recently had the head off but was doing it before that anyway. new distributor too. i put the new dizzy where the old one was by marks, but turning it to either extent of adjustment only makes it bounce slower / faster.
now for the wierd bit: if idling anong with no throttle in 1st or second, the engine will "pull" and start accelerating (slowly) when you hit say 1350 rmp it _cuts_ out really jerkily and when it gets to 1k it jerks back in again, and repeat. car otherwise drives fine no loss of power ect. no check engine light and no codes with the conector jumped either.
help! Sad
killa wrote: Im an ass man myself
Livefast123
PostPosted: 21:36 - 10 Dec 2010    Post subject: Reply with quote
Sounds like an air leak.......somewhere
Current ride - Yamaha MT-07
MaybeGuy
PostPosted: 21:40 - 10 Dec 2010    Post subject: Reply with quote
its an FI with all these gay sensors.
my money is on airflow sensor
fiery tupp
PostPosted: 21:41 - 10 Dec 2010    Post subject: Reply with quote
It does sound like vaccum & you have checked pipes , but I had one doing similar & a tiny leak in a pipe on manifold had me going for daft ages Confused
If you can't fix it with a hammer , use your head .
stonesie
PostPosted: 21:57 - 10 Dec 2010    Post subject: Reply with quote
Brake cleaner, spray it about all around near the inlet manifold and vac pipes, when you find the leak the engine revs will rise and smooth out as it burns the brake cleaner Thumbs Up
lukamon
PostPosted: 22:43 - 10 Dec 2010    Post subject: Reply with quote
just changed the MAF sensor - no affect.
MaybeGuy
PostPosted: 22:45 - 10 Dec 2010    Post subject: Reply with quote
cam timing or low compression on 1 or more pots.
if not, im out of ideas
lukamon
PostPosted: 23:01 - 10 Dec 2010    Post subject: Reply with quote
only thing i seem to not have touched now is the maP sensor. dont have another of those though.
PostPosted: 23:13 - 10 Dec 2010    Post subject: Reply with quote
First guess would be the idle control valve, but if that is OK then I would go for an air leak.
My guess with the idle hitting 1350 and then dropping is that the car is set up to cut the fuel when the throttle is closed and the revs are high (common way to save fuel). The air leak lets the revs rise until 1350rpm when it cuts the fuel and the revs drop.
lukamon
PostPosted: 04:06 - 11 Dec 2010    Post subject: Reply with quote
If i block off the vacuum pipes and then put my hand over the intake i get a good song vacuum that lasts for quite a while. It still does it though! Argh!
0l0dom0l0
PostPosted: 10:49 - 11 Dec 2010    Post subject: Reply with quote
I watched a video with another honda (cant remember the make) doing exactly the same thing. Have a search around and see what you can find. I can't remember what the problem lol. Atleast you know your not the only one Smile
lukamon
PostPosted: 15:04 - 11 Dec 2010    Post subject: Reply with quote
If i unplug the iacv, it steadied at 1200 with the bypass screw as far in as it'll go :\
lukamon
PostPosted: 14:29 - 12 Dec 2010    Post subject: Reply with quote
FIXED
throttle plate was either stuck open fractionally or bent, not a clue how/ why. but that was what was making the engine rev and cut fuel at 1.5k.
The last post was made 15 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 76.63 Kb
