Had an accident, advice please.
calyx
PostPosted: 14:21 - 11 Dec 2010    Post subject: Had an accident, advice please. Reply with quote
Hi,
A twat turned into a driveway while I was overtaking him. He indicated, indicator blinked once and he turned the steering wheel. All this took 1 second. maybe less. I managed to slow down to 5mph before crashing into his bumper.
I was doing 15mph, he was doing 5.
Witness says it is 50/50. Car driver blames me.
I have 2 questions.
1) Can my pillion be a witness?
2) What was the name of that bike insurance claims company? Mr. Green
I almost forgot the most important part:
https://img257.imageshack.us/img257/1743/crasha.jpg
Boris - London
Cheeseybeaner
PostPosted: 14:37 - 11 Dec 2010    Post subject: Re: Had an accident, advice please. Reply with quote
calyx wrote:
Hi,
I have 2 questions.
Speak to Rider Support Services in Putney, they did me well.
Your pillion may be a witness but is not impartial as he was on your vehicle rather than a by stander though his/her acount may be useful it would not be considered fully credible as an opposite account to the driver's.
You could argue he failed to keep proper look out before turning and failed to indicate properly before turning. If you were positioned alongside his vehicle before he indicated and turned its his fault but proving that without a bystander would be difficult so it may be that liability is split.
If you are seeking a claim though I'd speak to RSS pronto.
It looks from your image though more as if you rear ended him in while he turned in which case liability would probably be considered fully yours as you didn't keep adequate stopping distance.
yuri2085
PostPosted: 16:03 - 11 Dec 2010    Post subject: Reply with quote
I don't think stopping distance is relevant. If it was a safe overtake then it's not his fault. ie. overtake at reasonable speed, lane positioning etc.
In fact please think for a second, if it was about stopping distance then there is no such thing as a safe overtake, even on a motorway.
If someone cuts in front of you then you are no longer a safe distance away!!!
PostPosted: 16:07 - 11 Dec 2010    Post subject: Reply with quote
It's gonna go 50/50 at best, your pillion doesn't count as a witness neither does anyone in the other guys car.
Depending on the damage I would try to avoid going through the insurance, speak to the other guy see if he will consider not going through the insurance to avoid both of you losing your no claims.
weasley
PostPosted: 16:58 - 11 Dec 2010    Post subject: Reply with quote
I vote 50:50 too.
He should have taken reasonable care to make observations before making the manoeuvre. However you should have anticipated the possibility of the move. One assumes that he was driving at a speed that allowed the manoeuvre (ie, not 30 mph). You're in a residential road and overtaking - there is some onus on you to be alert to these possibilities.
PostPosted: 17:03 - 11 Dec 2010    Post subject: Reply with quote
I think calling the guy a twat is a bit rich. I'd say 50 50 is exactly where the blame lies.
I'd hazard a guess that you could have avoided him with better obs.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
colin1
Captain Safety
PostPosted: 18:01 - 11 Dec 2010    Post subject: Reply with quote
I was in a similar collision that I would have thought would be 50 50. I was more in the wrong than you but it went all in my favour, so I think you should be ok unless the driver lies about how long they had their indicator on.
In my case, they didnt turn into a driveway, but into a sideroad, so me filtering past I should have expected the possibility that someone might want to turn in there. In your case, the driveway is less obvious than a sideroad.
However what may have gone in my favour was, the driver had only just joined the main road, and was treating a staggered crossroads as if it were a crossroads. They had probably done the same several times a week for years without having someone come alongside them.
Bottom line is, even if they did indicate, they should have checked their wing mirror before turning. Hardly any car drivers do it, but it's their responsibility.
MattJ
PostPosted: 18:27 - 11 Dec 2010    Post subject: Reply with quote
As someone who has their car test on Monday, I can tell you that people are now taught to ALWAYS check their right wing mirror before turning right, specifically in case somebody is overtaking you (mainly bikes). He obviously didn't do that, so he did not check it was safe to do the manoeuvre. Hope that helps you, I do not think you were in the wrong. If you were overtaking unsafely then that means you should always have to join traffic again every time you approach a junction.
calyx
PostPosted: 02:01 - 12 Dec 2010    Post subject: Reply with quote
My hand was on the brake lever when this happened. I reacted in less than half a second. Seen him moving right, brake hard, didn't lock tyres, he indicates and turns at the same time, still not locked, he turns more, bang.
I don't think I could do any better than this. Especially with a screaming pillion at the back Laughing
Boris - London
Ingah
PostPosted: 02:14 - 12 Dec 2010    Post subject: Reply with quote
I agree actually. Overtaking a car passing a side road is a bit Confused but in suburbia every house has a driveway and a sudden maneuver without warning is going to be their fault. It sounds like you took every reasonable precaution. However, proving this chain of events is going to be significantly harder, although if your independent witness states the length of time that the indicator was on etc (without muddying up, missing some of, or withholding the details) then the insurance companies will hopefully arrive at the right answer eventually Wink (after all, it's only the witness statement of events that's important, their opinion of blame is meaningless unless they're qualified to make such judgements).
Unlucky imo.
Personally, it annoys me how drivers feel that they can get away with not checking their mirrors - it's sad that people even feel this is suitable as a defense. How the hell can it really be someone else's fault when they've pulled a sudden maneuver AND failed to make adequete checks/observations! (it seems the equivalent of running across a busy road blindfolded)
Edit - One exception to the above i've just thought of: If he'd slowed down and then you overtook him just after he'd slowed, then i'd forsee you getting partially blamed. When a vehicle slows down suddenly from ~30 to ~10, you should really be asking yourself why, rather than diving for the quick overtake Laughing
-- Ingah
-LG-
PostPosted: 02:31 - 12 Dec 2010    Post subject: Reply with quote
I would say its his fault, I was told when I was learning to drive to signal around 10 car lengths before I plan on turning (unless there is a road before it, then its as soon as possible with as much notice as possible).
londonbill This post is not being displayed because the poster is banned. Unhide this post / all posts.
iooi
PostPosted: 08:52 - 12 Dec 2010    Post subject: Reply with quote
MattJ wrote:
As someone who has their car test on Monday, I can tell you that people are now taught to ALWAYS check their right wing mirror before turning right,.
BLIND SPOT......
I hope you are also taught to look over your shoulder before moving. I know my daughter is......
OP.
Was the guy turning the lead car or in a line of traffic, did the guy behind you stop as they would be needed to confirm what the guy did.
L4Isoside
PostPosted: 11:27 - 12 Dec 2010    Post subject: Reply with quote
When I was driving I was taught to check for blind spots when manoeuvring etc, but I don't think I was for turning? (Only mirrors)
To me it does sound like 50:50, even in my CBT I was taught never to overtake when there is a junction/side road etc to the right... this almost caught me out once Shocked
hope it doesn't go too badly but your probably better off settling it out side the insurance.
SinceNow
PostPosted: 12:10 - 12 Dec 2010    Post subject: Reply with quote
Try BLD they are helping me with my claim right now.
https://www.bldgroup.co.uk/
PostPosted: 12:18 - 12 Dec 2010    Post subject: Reply with quote
Not only is a lot of what they teach in a CBT questionable, but this was a driveway, not a side road. Wouldn't be overtaking at all in most British urban areas if you avoided that.
I'd call up a claims company and see what they say - generally they'll only take it if they're pretty sure they'll win anyway.
calyx
PostPosted: 15:57 - 12 Dec 2010    Post subject: Reply with quote
Red is me. Blue is the car.
Traffic was very heavy and they were doing 10ish. This guy was doing 10 as well. There was no oncoming traffic. (that's why he turned)
I overtook 3 cars before crashing into this car. I mean, I was there for a good 10 seconds.
It was dark. No rain, clean conditions.
https://img146.imageshack.us/img146/2430/crash2s.jpg
Boris - London
calyx
PostPosted: 16:04 - 12 Dec 2010    Post subject: Reply with quote
Thanks for that. I am in contact with these guys. Hopefully they'll help.
Boris - London
instigator
PostPosted: 16:09 - 12 Dec 2010    Post subject: Reply with quote
Your fault.
You are responsible for looking after yourself, not anyone else.
Chalk it down to experience and move on.
Hetzer
PostPosted: 16:10 - 12 Dec 2010    Post subject: Reply with quote
Mirror, signal, maneouvre.
Not
No mirror, signalmaneouvre.
He's 100% at fault.
willis1337
PostPosted: 16:44 - 12 Dec 2010    Post subject: Reply with quote
Not
He's 100% at fault.
Provided that you weren't going at an excessive speed then I would say 100% his fault too, due to failing to observe before turning. However without an independent witness it's going to be a 50/50, as doubtful he would admit not looking, or signalling too late. Definately no independent witness?
I suspect he will say you were hooning it up the outside going too fast etc etc. while he was doing a sedate 25mph and mirror - signal - manoeuvre, then whack, speeding biker hits him in the side whilst killing 000,000's of kittens.
PostPosted: 17:02 - 12 Dec 2010    Post subject: Reply with quote
Can you provide a picture that's zoomed out a bit more? It's hard to tell what the road layout leading up to and after that spot is. That looks more substantial than just a driveway, it looks like you've left one section with a traffic island and heading to another, and if you had already overtaken 3 cars, it looks like you were thinking more about passing even more cars than what the next one the list was doing.
Sure, people should signal clearly, and check their mirrors, but you're responsible for your own fate when on a bike, so 50:50.
L4Isoside
PostPosted: 18:12 - 12 Dec 2010    Post subject: Reply with quote
I don't unless I have to, I save the high speed riding/ overtaking for the more open roads. Confused
calyx
PostPosted: 18:58 - 12 Dec 2010    Post subject: Reply with quote
There is an independent witness. She says it is half half. But her statement means more than what she thinks.
If she tells the truth I'll be fine. What concerns me is if she says "he indicated, biker overtook, bang". This kind of statement would cause me losing my ncb.
instigator wrote:
Your fault.
I know. I should never overtook. Actually I should buy a car.
Not
He's 100% at fault.
When I contacted my insurer first thing they asked was "did he indicate?". I think this means something.
Maybe you are allowed to kill people when you indicate Confused
Yes Sir!
https://maps.google.co.uk/?ie=UTF8&ll=51.607232,-0.124489&spn=0.000976,0.002411&t=k&z=19
And A to B(ang)
https://maps.google.co.uk/maps?f=d&source=s_d&saddr=Bounds+Green+Rd%2FA109&daddr=Bounds+Green+Rd%2FA109&hl=en&geocode=FeF2EwMdMxf-_w%3BFX13EwMdGRb-_w&mra=dme&mrcr=0&mrsp=0&sz=20&sll=51.607298,-0.125145&sspn=0.000488,0.001206&ie=UTF8&t=k&z=20
Boris - London
I'm presuming you don't commute through a busy town/city, then.
If I can't filter, I'll just take the car as that's the main advantage the bike has - that I get there three to four times quicker!
The last post was made 14 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 134.09 Kb
