Riding with a broken chain?
Would you ride with a broken chain side plate?
Stay at home and stay alive
85%
 85%  [ 42 ]
Risk it, Ride it
14%
 14%  [ 7 ]
Total Votes : 49
Stalk
PostPosted: 20:17 - 11 Dec 2010    Post subject: Riding with a broken chain? Reply with quote
Mini-Stalk has broken one of the side plates on his chain (Yam SR 125)
and is considering riding it until replacement arrives. Would you ride with a broken sideplate?
Should add that it is snapped in half, and I would not ride it.
Cheers for opinions
Stalk.
Itchy
PostPosted: 20:19 - 11 Dec 2010    Post subject: Reply with quote
Nope I wouldn't.... as an extreme measure I might remove the link and then reconnect it again if I had a chain splitter etc, but otherwise nope.
doggone
PostPosted: 20:22 - 11 Dec 2010    Post subject: Reply with quote
I think a few of us will have been doing maintenance and spotted something like this that's been merrily whizzing round for many miles, but it would be most unwise to carry on riding when you know about it - other than gently get home if possible.
A chain flying off even at 30mph can do expensive damage to the bike and possibly the rider.
Plus you might be stuck in a dangerous place with traffic mercilessly whizzing past your ear.
Dan79
PostPosted: 20:26 - 11 Dec 2010    Post subject: Reply with quote
Even if he gets away with the chain falling off cleanly without making contact with him or damaging the bike when it splits (which it will) sods law this will happen whilst he's being followed too closely by a HGV - bike will suffer total loss of power, lorry driver won't see any brake lights, splat. I wouldn't risk it, find some other way of getting about in the meantime.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
weasley
PostPosted: 21:03 - 11 Dec 2010    Post subject: Reply with quote
Get out there with bolt croppers or an angle grinder and remove any doubt.
PostPosted: 21:10 - 11 Dec 2010    Post subject: Re: Riding with a broken chain? Reply with quote
Would consider shortening the chain by a link, or possibly even welding the cracked link as an extreme measure.
No chance I'd try riding it as is - if I was being VERY careful, maybe a couple of miles to the local bike shop, then fit it outside there.
neil.
PostPosted: 21:20 - 11 Dec 2010    Post subject: Reply with quote
NEVER, although this exact same thing has happened to me and I did ride it shortly at up to 40mph before I actually found out what had happened - I heard a big clunk and then knocking that got more frequent with speed. I actually thought it was something in the engine big end/clutch. I was on a busy dual carriageway with nowhere to pull over so I had to ride for a mile or so before I could pull into a car park where I could investigate. Then I discovered the broken chain, called out my breakdown recovery and fixed on a new master link, then I bought a decent DID chain.
I will never buy IRIS ever again, or recommend them to anyone - I had regularly cleaned, lubed and adjusted this chain and it only lasted about 8'000 miles. The DID chain I had before lasted over 15'000 miles and my current DID is still going strong after 12'000 miles or so with plenty of adjustment left.
stonesie
PostPosted: 21:27 - 11 Dec 2010    Post subject: Reply with quote
I would wait for a replacement chain, but if I was desperate to use the bike (my only transport or something) I would track down a split link and replace the knackered one with that as a temporary measure, wouldn't trust the chain if one link had gone like that......
Oh, and...
https://i564.photobucket.com/albums/ss88/SilentWolf8979/Humor/pics_or_it_didnt_happen_retro_poste.jpg
neil.
PostPosted: 21:56 - 11 Dec 2010    Post subject: Reply with quote
https://cdn.bikechatforums.com/files/image_005.jpg
PostPosted: 22:45 - 11 Dec 2010    Post subject: Reply with quote
Its on a split link too!!!! Its going to fail, its just a matter of time. You could just go to the local bike shop and buy another split link to replace it with... It'll cost about a quid and will be far better than riding it like that!!
PostPosted: 22:46 - 11 Dec 2010    Post subject: Reply with quote
Replacement split link won't cost much at all.
stonesie
PostPosted: 23:07 - 11 Dec 2010    Post subject: Reply with quote
In the unlikely event that you wanted a link to do that, that is the one you would pick Thumbs Up
Back to the real issue, how shitty is the OP's lads chain if the might of a 125 has made it shit itself Question
fiery tupp
PostPosted: 23:23 - 11 Dec 2010    Post subject: Reply with quote
Hetzer wrote:
Is this a serious question or a wind-up?
It would put the wind - up me Shocked
If you can't fix it with a hammer , use your head .
Mini_Stalk
PostPosted: 00:49 - 12 Dec 2010    Post subject: Reply with quote
nope this is not a wind-up.
Just to prove how stupid i am when it comes to my own personal saftey i have a blow out on my tyre, i went home that night took the inner tube out found the hold fixed it with super glue 6 plasters and some sergial tape, pumped up the tyre and then when out on it.
SR 125 Rat
PostPosted: 01:13 - 12 Dec 2010    Post subject: Reply with quote
Why not get a puncture repair kit Confused. About £1 in Asda or Tesco.
Personal safety you've got a low (though significantly higher than before) chance of hurting yourself if it goes wrong.
Likely effort of dealing with a broken down bike definitely doesn't seem worth it for the very small hassle of doing it 'properly'.
A different case, but there was someone that posted on here a while ago. Everyone told him that putting a CR500 engine in a 50cc chassis would need a lot of strengthening.
He ignored that. He ended up around a tree, dead.
Given the wrong situation with the current weather; either of the things you mention could end the same if you're not so lucky. Or maybe you'll end up paraplegic being fed by a tube and having someone wipe your arse for you.
I take enough risks, but I try and make sure they're semi-sensible ones considering the possible outcome. Doesn't seem worth it for ones very easily avoided.
andym
PostPosted: 03:30 - 12 Dec 2010    Post subject: Reply with quote
Just thought I would add a little comment here, more about the whole chain splitter etc, (I wouldn't ride with a split link like that... if I knew about it).... but I removed a link from my chain using nothing more than a straight edge screwdriver and hammer.... anyway I'll bugger orf now and wait for my bike to explode or something.
baldy
PostPosted: 03:57 - 12 Dec 2010    Post subject: Reply with quote
I wouldn't ride it unless you want it to rip you a new arse hole when it snaps and flings up.
Just fit a new split link for a few quid, and then go and buy some chain oil.
One day i will rule the world, just not today.
flat spot
PostPosted: 11:44 - 12 Dec 2010    Post subject: Reply with quote
If anyone is confused about using the term Darwinism. Well folks we could see it in action anytime soon.
Marmalade
PostPosted: 12:51 - 12 Dec 2010    Post subject: Re: Riding with a broken chain? Reply with quote
Cheers for opinions
Stalk.
Why buy a new chain for a broken split link?
Simply remove link, weld it back together and refit, job done.
Or go and buy one at any motorcycle spares shop for a couple of quid and stay alive
Mini_Stalk
PostPosted: 13:00 - 12 Dec 2010    Post subject: Reply with quote
i think there might be some confusion, dad has told you wrong i havent broken the split link i have broken another link, my split link is fine.
SR 125 Rat
Mini_Stalk
SR 125 Rat
PostPosted: 13:05 - 12 Dec 2010    Post subject: Reply with quote
If it's an outer link, you can still use a splitlink to replace it, by the way.
27cows
PostPosted: 17:07 - 12 Dec 2010    Post subject: Reply with quote
I had to back in the summer for about three miles with a broken link. That was on a very small bike with virtually no power and that link wouldn't have lasted much longer. To knowingly ride a bigger bike with a broken link would be the very height of stupidity.
PostPosted: 17:27 - 12 Dec 2010    Post subject: Reply with quote
I would use a new split link to replace a failed link if I could find a matching one, but I would consider why the original link failed and whether the rest of the chain is useable.
As to riding on a broken link. Unless it was at walking pace for a very short distance as a last resort then no way.
PostPosted: 19:11 - 12 Dec 2010    Post subject: Reply with quote
The chain in the picture shows a break in the split link...
The last post was made 15 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.82 - MySQL Queries: 15 - Page Size: 131.54 Kb
