Seepdometer Way Out
Adam.I
PostPosted: 08:31 - 13 Dec 2010    Post subject: Seepdometer Way Out Reply with quote
I have been meaning to post this for a while. My speedometer is wrong. When going at an indicated 22 MPH, I am actually travelling 30 MPH. I have tested this using them roadside signs informing the rider/driver of their speed as approached. Every bike and car I have owned has indicated a speed above the actual speed e.g. my GSX-R indicated 32 MPH at 30. Riding when it indicates below is a bit of a problem. Any ideas what is wrong?
Veni Vidi Vici
iooi
PostPosted: 08:55 - 13 Dec 2010    Post subject: Reply with quote
Where is the speedo driven from ?
front wheel or gearbox.
Noxious89123
PostPosted: 19:47 - 13 Dec 2010    Post subject: Reply with quote
If it's from the gearbox, then it's probably worth checking that your running the stock sprocket sizes. Anything else will put your speedo out.
This doesn't apply to a front wheel driven speedo.
PostPosted: 19:56 - 13 Dec 2010    Post subject: Re: Seepdometer Way Out Reply with quote
My RS250 was like that.
As above, if it's driven from the sprockets and you've upgeared, that'll do it.
If it's electronic, you can get a speedo healer device that will sort it.
iooi
PostPosted: 21:02 - 13 Dec 2010    Post subject: Reply with quote
But non std wheel size will Thumbs Up
Noxious89123
PostPosted: 21:34 - 13 Dec 2010    Post subject: Reply with quote
Yup, or a non standard tyre.
But 22mph to 30mph is quite alot!
PostPosted: 21:39 - 13 Dec 2010    Post subject: Reply with quote
Not TOO far off the difference between a supermoto and dirt front wheel. We need to know what bike it is to get a better idea Thumbs Up.
Adam.I
PostPosted: 08:00 - 14 Dec 2010    Post subject: Reply with quote
Forgot to mention, it is a Suzuki Bandit 600 K2. It has got standard size tyres and I haven't changed the front sprocket. Previous owner may have so I will check that this weekend. If that fails, any other suggestions?
Veni Vidi Vici
hmmmnz
PostPosted: 09:02 - 14 Dec 2010    Post subject: Reply with quote
some one has changed the sprockets, its 73% out so probably closer to 70% of the original sizes
original sizes are 15 and 47
if they had gone 2 down on the front and 2 or 3 up on the rear, that would just about be right for what you are getting on the speedo
the humans are dead
I kick arse for the lord
PostPosted: 09:27 - 14 Dec 2010    Post subject: Reply with quote
But shouldn't down gearing make the speedo overread?
And it's reasonably less likely they would have up-geared that much, I'd have thought.
Adam.I
PostPosted: 11:56 - 14 Dec 2010    Post subject: Reply with quote
That's what I thought, gearing down will cause the speedometer to over read. This is under reading, and by a massive amount, around 30-40%.
Veni Vidi Vici
PostPosted: 12:02 - 14 Dec 2010    Post subject: Reply with quote
That is a long way for the speedo to be out. Especially as I would expect it to read something close to 33 at a true 30.
Given how much it is out I would suspect that someone has made a mess of an mph / kmh conversion. Maybe an import with kmh clocks which someone has fitted a speedo healer to, and then swapped or modified the actual clocks.
Running ~50% higher gearing would give about that speedo difference, but that would be a massive change to gearing.
Adam.I
PostPosted: 17:28 - 14 Dec 2010    Post subject: Reply with quote
I'm fairly sure it is a UK model, will confirmation of this be On the V5?
Veni Vidi Vici
PostPosted: 18:12 - 14 Dec 2010    Post subject: Reply with quote
Not necessarily. Only way it will say there if it was registered outside the UK first.
The last post was made 15 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 84.53 Kb
