Secondary battery for accessories
Bike Bunker
PostPosted: 02:45 - 13 Dec 2010    Post subject: Secondary battery for accessories Reply with quote
Secondary battery for accessories....
ok ive just come close to finishing my project sports bike and have considered a few electrical items...e.g neons (well LED strips)+heated grips...
only thing is the bike has a permanent light that you cant turn off in fact it has two..a small central on the front nose cone and the usual light only thing yo can adjust is high beam...figured this will use the battery...so thinking about adding a secondary battery for my gadgets and gizmo's that i can just make a secure position under my seat for and remove and charge when i need to??
would this pose any problems ?
Also unrelated any advice on paint my wheels they have about three layers already from previous owners so was considering just getting them powder coated by a pro?
PostPosted: 03:26 - 13 Dec 2010    Post subject: Reply with quote
If you're flattening the battery, it means you're using more power than the bikes charging system can produce. The battery only charges using whatever power is "left over" after all the accessories have been powered up.
Adding a second battery will not fix this. I would say using a good quality, known brand, sealed battery would be the most efficient way of making use of the charge available.
LEDs draw a very minimal current (10 or 20mA). A fully charged motorcycle battery would run a strip of say 10 LEDs for more than a month. So, discount LEDs from your energy consumption worries on a modern motorcycle unless you're getting into hundreds of them.
Replacing filament bulbs with LED ones (eg stop and tail lights) will free up power for use elsewhere.
To be totally honest though, unless you're doing something totally mad like running a microwave off an inverter (an inverter can hoover power very quickly and using 240V AC on a motorcycle always struck me as slightly dodgy at best), you'll be working hard to run out of power. It's things running when the engine is off that will run down your battery.
If you're planning on running loads of electrical gizmos off the battery with the bike off, some sort of slave battery might be a good idea. Never seen it on a bike but I do know it's commonly used on camper vans. They have some sort of switching gizmo that makes sure the main battery is fully charged before it starts to charge the leisure battery.
You then get into having to fit all that wiring in, finding space for another battery and adding a shitload of weight which then begs the question, why did you buy a sports bike?
TL;DR : A modern bike will power heated grips and (within reason) as many LEDs as you want with the engine running.
Bike Bunker
PostPosted: 12:17 - 13 Dec 2010    Post subject: Reply with quote
Great reply Karma
Braught a sports bike becuase of the looks and some element of speed although some trail's bikes are faster at the same cc...
and the bike has a fair big of storage (enough for a battery well even two Mr. Green ) so thats not a problem and it would be a huge batery would it so it wouldnt have much added weight to make a difference maybe 1 or 2 mph of top speed Rolling Eyes
Damon
PostPosted: 12:39 - 13 Dec 2010    Post subject: Reply with quote
Ash Mash wrote:
Great reply Karma
As stinkwheel said there is no real point of adding another battery. Unless you plan on running the gadgets/lights without the bike running or wiring in a AC inverter you shouldn't need a second battery.
What exactly do you plan to wire onto the bike?
Bike Bunker
PostPosted: 13:53 - 13 Dec 2010    Post subject: Reply with quote
Damon wrote:
Ash Mash wrote:
Great reply Karma
Thiers 5 steips of 15 LED's to go in the fairing ....(would like to use when bike isnt running maybe)
and its a circuit so i dnt want to dismantle it and remove some incase i mess it up...
and then heated grips Smile
This is going out the window now bike stopped working aha
PostPosted: 14:02 - 13 Dec 2010    Post subject: Reply with quote
Well, your LEDs are going to be drawing in the region of 150mA in total.
Most bikes these days have a 14Ah battery.
Your battery (assuming it's fully charged to start with) would run 75 LEDs constantly for well over 3 days.
Also, you are a tart. Go on, admit it, you really wanted a goldwing didn't you?.
https://www.goldwings-northwales.org.uk/blog/wp-content/uploads/2009/09/Goldwing-light-display.jpg
PostPosted: 14:03 - 13 Dec 2010    Post subject: Reply with quote
Weight is virtually irrelevant to top speed.
However adding a 2nd battery just gives you a bit longer before the battery is flat. If you have enough of a charging system to cope with the load then no advantage, if you don't then just means you will be walking a bit later.
Your strips of LEDs will probably draw negligible current while the heated grips will probably draw 2~3 amps. Suspect your charging system will be fine unless you are doing lots of short journies at low speed.
The last post was made 15 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.14 - MySQL Queries: 13 - Page Size: 60.63 Kb
