lifesavers
shooter
PostPosted: 15:08 - 13 Dec 2010    Post subject: lifesavers Reply with quote
hello
did my cbt last week. i'd heard the term lifesaver before, i always assumed it was pretty much the same as checking your blind spot in a car, i.e. you're looking over your shoulder and just slightly behind you, so you would see a car thats to the side and just off your back wheel.
the instructor though told me you have to look right along the road behind you. obviously you can't turn your head that much on its own, so i was having to turn my whole upper body to look behind me, and doing this made me feel like i wasn't safe as i was unbalanced and had to take my eyes of the road in front for longer than i was comfortable with.
what are your opinions? how far behind do you have to look?
also, is there any difference between a lifesaver and a shoulder check? do they mean the same thing or is a lifesaver the more extreme version of the shoulder check?
thanks
PostPosted: 15:30 - 13 Dec 2010    Post subject: Re: lifesavers Reply with quote
Your instructor is wrong and you feel unsafe doing that for the simple reason that it is unsafe.
A lifesaver is a glance to the side to make sure there is nothing trying to get along side you. If you want to see whats going on behind you then use the mirrors.
If you have to turn the whole of your upper body you'll be turning the bars as a natural result and that can only end in bother.
A life saver and shoulder check at the same thing when your moving. When stood at the side of the road a shoulder check is a good look behind you which can be done safely because your not moving, followed by a life saver before you pull away.
supZ
PostPosted: 15:51 - 13 Dec 2010    Post subject: Re: lifesavers Reply with quote
shooter wrote:
also, is there any difference between a lifesaver and a shoulder check? do they mean the same thing ?
they are the same thing.
your instructors an idiot.
looking behind you.. thats what mirrors are for.
a lifesaver/shoulder check is just that, checking to the left or right of you just over your shoulder (i.e. blind spot) before you move over/turn/etc..
your thoughts were correct, no idea what the instructors on
there are times when you'll want to look right behind you but your normal shoulder checks are not one of them
CBR954RR - Daily toy
CBR600RR - Trackbike
PostPosted: 15:59 - 13 Dec 2010    Post subject: Reply with quote
I'd charitably assume that your instructor was only talking about checking right behind you when you are stationary, before pulling away.
If a moving lifesaver required looking right behind you, then none of us would have passed our tests.
Do try to practice shoulder checks whenever possible though. Bike, car, supermarket, get your awareness up. Also remember to check the inside when pulling away from lights and junctions, to catch cyclopaths chancing their luck.
shooter
PostPosted: 21:49 - 13 Dec 2010    Post subject: Reply with quote
thanks for all the replies!
he actually told me i should look at least 100 metres down the road behind me Shocked
needless to say i failed my CBT first time and it almost put me off biking for life, but glady i re-took the course today with a really good instructor and passed Very Happy
Vman
PostPosted: 22:39 - 13 Dec 2010    Post subject: Reply with quote
When I did my CBT, the only time my instructor told me to perform that style of check was before doing a u-turn.
Glenben92
PostPosted: 23:36 - 13 Dec 2010    Post subject: Reply with quote
chin to shoulder. any more and you are, as you said, jeopardising control of the bike. as your body twists your arms wanna twist, which turns the bar. Can get away with a bigger turn while stationary but still not adviseable and certainly not required. chin to shoulder will be fine. your CBT instructor should have went through a procedure showing you exactly where and how big your blind spot is (its surprisingly large)
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
lihp
PostPosted: 00:45 - 14 Dec 2010    Post subject: Reply with quote
Another good way to remember is that if you have to turn your body, you're looking too far.
Darth
PostPosted: 12:38 - 15 Dec 2010    Post subject: Reply with quote
My tuppence worth as i dont think anyone has written anything which 100% matches what i was taught.
Lifesaver - Basically checking your blindspot. Should be performed as the final action before changing lanes, turning into junctions. Both sides if pulling off from lights etc.
Shoulder checks - quick look to both sides if pulling away from lights etc.
Now I was also taught to always perform a rear observation before pulling off from a stationery position (i.e - when first pulling away, form side of the road etc) This was a completely different move and involved twisting around as far as necessary to look down the road behind you. If all was clear then you could look forward again and pull off.
Not saying that is correct but is what i was taught and passed my test with a few years back.
SweenyT
PostPosted: 13:13 - 15 Dec 2010    Post subject: Reply with quote
I agree with all of the above.
I would only look that far (100m) behind when stationary at the side of a road anything more than a chin-shoulder check (lifesaver) whilst riding will de-stabilise the bike and be potentially quite dangerous. Also it takes longer to do a shoulder check than a lifesaver which means less time to react to situations occurring in front of you.
Just my twopenny's worth Wink
Current ride - 2005 Suzuki GSX-R600 K4 - 2x 2014 Honda NC750s long term courtesy bikes - 2003 Fazer FZ6 written off as idiot reversed into me - 2009 YBR125 - still have from new
GSTEEL32
PostPosted: 14:26 - 15 Dec 2010    Post subject: Reply with quote
Lifesavers and shoulder checks arn't the same thing...
Lifesavers are executed in a stationary position when you are about to cross the path of any road traffic. Therefore this is done when attempting a u-turn, or pulling across oncoming traffic when turning right into a junction (but only from a stationary position). You look down the road behind you, and as you've mentioned, the angle of your handlebars may change but your doing it from a stationary position, so it makes no odds. What your doing is making sure no cars or bikes pull around your right hand side and take you out when you set off. Your not looking to check anything on your left hand side.
Shoulder checks are exactly what they say. Its a chin to shoulder movement checking an area of the road which you are moving into. So, change lane.. shoulder check...... pulling off into a left or right junction on the move .... shoulder check....... coming off a roundabout... should check.....
Everything else is a mirror check..... speeding up or slowing down... mirrors..... observing traffic following you... mirrors.... general observations... mirrors... finding space to change lane... mirrors
Darth
PostPosted: 15:50 - 15 Dec 2010    Post subject: Reply with quote
I am not gonna give you a karma hit but... bollocks! Your definitions i agree with but what you are calling them i do not.
What you are calling a shoulder check is a lifesaver. It may also be called a shoulder check in some parts but to me it is definately a lifesaver.
What you are calling a lifesaver is not a life saver! This is what i was told a is a rear observation.
I know there are a few instructors on here -please will one of them put this to bed for good???
blurredman
PostPosted: 16:55 - 15 Dec 2010    Post subject: Reply with quote
As I understand it, lifesavers are when you are on the move and are looking at the general direction of your shoulder.
Shoulder checks, are when you are stationary, and for those. You look further than you would a lifesaver.
The last post was made 15 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 82.79 Kb
