New r1 shock on older r1
Damon
PostPosted: 20:39 - 14 Dec 2010    Post subject: New r1 shock on older r1 Reply with quote
Hi all,
I need to sort out the rear shock on my race bike. I have seen rebuild services for £100, but I have also seen a 2008 brand new rear r1 shock for the same price. Does anyone know if the newer shock will fit my 2001 R1 without any major modification?
Thanks all, Karma given as always Karma
Bikeless
PostPosted: 20:46 - 14 Dec 2010    Post subject: Reply with quote
Not sure but if no-one gives a definitive answer,try phoning Andy White at KAIS suspension,he should know.
woodyfjr
PostPosted: 10:25 - 15 Dec 2010    Post subject: Reply with quote
I would have thought the damping, spring and length would be totally different so I wouldn't bother.
Also try and get a good after market shock as they are far superior.
Try these people: https://www.dpsracing.co.uk/shock_servicing.php very good at rebuilding standard shocks to higher spec.
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
Damon
PostPosted: 11:58 - 15 Dec 2010    Post subject: Reply with quote
Thanks lads!
craigT19
Jolly Green Giant
PostPosted: 21:01 - 15 Dec 2010    Post subject: Reply with quote
Pretty sure the 08 shock will be too long, the newer r1 had a much longer swing arm than it's earlier versions and because the swing arms on the newer ones was basically upside down the shock attached lower in the chassis.
I expect it can be done, just with some work.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Noxious89123
PostPosted: 00:54 - 16 Dec 2010    Post subject: Reply with quote
You'd probably be better off getting your current shock played with by someone like K-Tech, rather than swapping it for a different "bog standard" shock.
PostPosted: 10:45 - 16 Dec 2010    Post subject: Reply with quote
Go to a bike meet/dealer find an 08 r1 and measure the shock.
The last post was made 15 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.09 - MySQL Queries: 13 - Page Size: 51.98 Kb
