decent air compressor ?
Ariel Badger
PostPosted: 23:04 - 18 Dec 2010    Post subject: Reply with quote
9.5 CFM will do all you need IMHO Thumbs Up Very Happy
Raffles
PostPosted: 23:30 - 18 Dec 2010    Post subject: Reply with quote
Wolf used to be a good brand of power tools to buy. Of recent times that has not been the case. Just remember the old maxim:-
You buy cheap, you buy twice.
Dazbo666
PostPosted: 23:50 - 18 Dec 2010    Post subject: Reply with quote
Could also check out MachineMart, Tool Station, Screwfix... or B&Q it??
Word of the day : DILLIGAF
Quote Me Happy
PostPosted: 10:19 - 19 Dec 2010    Post subject: Reply with quote
I've got a similar one - the 50 litre version
https://www.ukhs.tv/Workshop/Air-Compressors/Sioux-50-Air-Compressor-and-5pc-Kit
Served me well so far, you might find 25 litre a bit small but it will do the jobs you want most likely.
robs321
PostPosted: 11:05 - 19 Dec 2010    Post subject: Reply with quote
I have one like that but its ment to be 13cfm, I find it runs out of puff to quicky using a rattle gun! They are fine to pumping up tyres and I use mine for spraying bike parts.
Fisty
PostPosted: 11:41 - 19 Dec 2010    Post subject: Reply with quote
Does it have to be new?
I picked up a nice single phase Hydrovane last week, much better than a piston compressor and much quieter.
Fatter and faster than Fret
tutton
PostPosted: 01:19 - 20 Dec 2010    Post subject: Reply with quote
I have a sip 9.5 or 13cfm i forget with 50L tank, used around 5 times for pumping tyres and a ratchet on sump bolts for sale if your intrested is in somerset, could probably get it couriered if required?
PostPosted: 14:46 - 20 Dec 2010    Post subject: Reply with quote
Mine is a 50L tank and something around 7~8CFM. I would regard 50L as minimum and would prefer something bigger. Would certainly want more flow as well.
Pabbers
PostPosted: 18:07 - 20 Dec 2010    Post subject: Reply with quote
Is 116 psi max output enough to power an air tool?? Confused
PostPosted: 19:44 - 20 Dec 2010    Post subject: Reply with quote
Should be (although the tank probably drops to about 80psi before the pump cuts back in). Few compressors have a higher pressure than that. Make sure it can supply enough air, including the actual lines and connectors being up to the job.
ZRX61
Victor Meldrew
PostPosted: 20:05 - 20 Dec 2010    Post subject: Reply with quote
But with that tiny little tank it's next to useless....
They're not one night stands, they're auditions.
tutton
PostPosted: 01:14 - 21 Dec 2010    Post subject: Reply with quote
Replied to pm yesterday to make me a reasonable offer and got no reply...
The last post was made 15 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 96.25 Kb
