| Johnny Forgotten |
 Johnny Forgotten Derestricted Danger
| Robby |
 Robby Dirty Old Man
 Posted: 13:28 - 02 Aug 2004 Post subject: |
Yeah, sounds very like a bad earth, classic problem with Zeds.
Either that or the condenser(s) are knackered. To test then , switch the ignition on then move the closed set of points apart with a biro or something, if a spark jumps the gap, your condensers are shot. If unsure, just replace them, they are cheap.
You can test the coil windings using a multimeter, readings would be found in a workshop manual (a worthwhile investment if you own a bike of this vintage.)
One thing that doesn't follow is that if you are getting a spark at the points, there should be a spark somewhere else too (the spark at the points and the one at the plugs are essentially the 'same' spark, just further along the circuit. So, if there is a spark, where is it earthing?
I would recommend cranking the bike over in the dark and having a look for sparks earthing somewhere they should not be ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Johnny Forgotten |
 Posted: 18:17 - 02 Aug 2004 Post subject: Probably the condenser... |
THanks for the replies! I can tell I'm going to have fun on this forum.
I did a lot of searching on the net for electrical articles relating to this bike, and I sort of came to the conclusion that my problem is most likely the condenser. Now that you've suggested that, stinkywheely, I think I'm on the right track because I checked all the earths (coil to frame, battery to frame etc) and none are rusted or corroded. I'm just going to buy a condenser, install it, and go from there. I'll let y'all know how it goes later in the week! Cheers, J.F.
PS I discovered that the factory coils should have a 4ohm resistance between the poles, and come to think of it, I was seeing the sparks at the points when they were in the OPEN position!! Kool, I think you've helped me figure it out!
CHEERS |
 Posted: 23:58 - 02 Aug 2004 Post subject: |
All my mates who kept Z650s fitted them with boyer electronic ignitions and dynacoils (and usually a sealed battery for the boyer to chew on). Complete bastards to set up but maintainance free when done, the spark you get from them is TWICE as fat. Not cheap though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Johnny Forgotten |
 Posted: 02:12 - 04 Aug 2004 Post subject: |
You just gotta break it down to its componant parts.
Your alternator charging coils generate current and load up the primary windings of the ignition coil in paralell with the condenser when the points are closed.
The points open, the charge in the primary coils drops away to earth. This generates a huge voltage in the secondary ignition coil winding which travells along the HT lead and earths accross the plug electrode.
SPARK
Something is stopping this happening or diverting the current to earth where it is not supposed to be. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Johnny Forgotten |
| Johnny Forgotten |
 Posted: 17:07 - 08 Aug 2004 Post subject: |
You really need a workshop manual, otherwise the readings are pretty meaningless anyway.
You should be testing between the two wires to test the primary winding (usually tens of ohms) and betwen the HT lead and earth to test the secondary winding (usually kiloOhms). The earth is usually where the coil bolts onto the frame.
Sorry, I don't have a manual and can't help you with the exact figures. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Johnny Forgotten |
| Big Pete |
 Big Pete Spanner Monkey
| Johnny Forgotten |
 Posted: 23:00 - 10 Aug 2004 Post subject: |
You have my sympathy. The wiring on old jap bikes is a fucking nightmare, I am doing up a vintage suzuki, I eventually lost the rag with it and tore the whole loom out, I am making a new one to my own design.
Top tip. Your computer is equipped with MS Paint, this allows you to draw boxes and straight lines in all colours. Spend an hour doing yourself a full-colour wiring diagram, in your case, I would just do the parts relevant to the ignition/charging system. Laminate it and pin it to the wal in the workshop. Makes things a lot easier to visualise and spending the time doing the diagram helps you understand what is going on.
Good luck!
This is the one I did for my Jawa 350 (nothing like the zed, just to illustrate the concept): ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Johnny Forgotten |
The last post was made 22 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
