| I-Bunder |
 I-Bunder Two Stroke Sniffer
| 0ddball |
 0ddball World Chat Champion
| chris-red |
| Mark65 |
 Mark65 World Chat Champion
 Posted: 12:07 - 30 Dec 2010 Post subject: |
Ive just resprayed my swing arm, cleaned and sanded original finish, 2 coats of red oxide, 2 coats of black enamel, paint was plastikote, its just drying now, will it be ok, who knows but it looks better than the original.
Mark ____________________ 07 Yamaha YBR125, 07 Honda CG125 , 15 CBR300R (Chocolate Crank, Deaded), 16 CB500FA, 19 Honda Forza 300, 70 Suzuki SV650 |
| I-Bunder |
| Mr Krispy |
 Mr Krispy Two Stroke Sniffer
| Bull |
 Bull Nitrous Nuisance
| flat spot |
 flat spot World Chat Champion
| chris-red |
| 0ddball |
| chris-red |
| Ingah |
 Ingah World Chat Champion
| Mr Krispy |
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 13:00 - 31 Dec 2010 Post subject: |
I would get it powder coated  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| chris-red |
| Bull |
| Teflon-Mike |
 Posted: 18:46 - 01 Jan 2011 Post subject: |
Round me, Shot-Blast Acid-Dip and Powder-Coat, is approx £50 for a frame, £25 for a swing arm.
Compared to rattle-canning.... it's good.
For a 'blow-over', job, two coats of paint on a typical tube-frame and arm, your looking at two three cans of paint, that's about £25's worth. Chuck in a couple of rotary wire brushes and a flap-wheel, and the cheap electric drill you'll invariably kill, loading the bearings side on, where they aren't very strong, and then the hassle and elbow-grease..... its an awful lot less hassle, and not that much more expensive! BUT, you will have to replace bearings etc. AND having got a really nice looking finish o nthe frame, and then spent money on new bushes... the costs start ramping, as you look at the bits you are about to bolt onto your nice shiney new frame, and think... "Hmmm I think I'll paint that first!" or "Thats a bit manky, I'll get a new one of them" and so it goes on, and what started off as a £100 tart up job, rapidly becomes a Two-grand Restoration! (see Snowies' Pup thread on Show & Tell for how it goes!)
Alternative is to brush paint.
Thirty years on dirt bikes, Finnigans Smooth-Rite has done me proud!
You need to thin it a bit, but brush on, and it goes 'smooth' so doesn't leave too many brush-marks. It stays a little bit 'plastic', and resists stone chip, or in my case, heavy bashing against trees, rocks, and anything else that I manage to find to run into on a week-ends romping! And you slap it on around whatever's there, so keeps it all simple. NOT the best looking finish, but better than rust, its functyional, and ecconomical. Big tin is about £12, and after fdoing whole bike frame and swinger, there's usually enough left in the tin for a couple of seasons, touching it up, during post season rebuilds! (Like when even a 'tough' resiliant paint fisih wont resist the consequences of severe numptyness!)
Poweder coating isn't the 'ultimate', though. 'Normal' powder coating, like wot they do garden gates in, tends to go hard and brittle and crack, after about six to ten years, at which point it starts to let moisture under the coating, letting the metal beneath rust and lift the coating off. If damaged in use, similar thing can happen, and its a lot harder to treat than paint. Hence not using it on the dirt bikes. Some show-builders prefer paints, for adherance and finish, and how they can control the application, often using twin-pack paints that are baked to cure, like a plastic coating, but with adherance to metal of paint, but, thats talking seriouse money. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| I-Bunder |
 Posted: 23:06 - 01 Jan 2011 Post subject: |
thank guys for the advice probs going to get the swing arm powder as it gets a lot of shit. but wiil end up spraying the frame as to much hasle to strip the hole bike and does need to be as heavy duty.
cheer  |
| stevo as b4 |
 Posted: 23:35 - 01 Jan 2011 Post subject: |
Yeah power coating and or stove enamelling has their adavantages, but as said you need the bike to be 100% stripped and your going to have to remove bearings and blank off areas that you don't want to get coated, including bearing housings and things like threaded boss's etc.
For working at home or just doing part of a bike, then i too favour using Smoothrite/Hammerite type paints. I find than you don't need to rub down the old paint too far or strip the frame to the bare metal. Just a combination of a stiff wire brush and a quick key with quite rough sandpaper is enough to get a good paint adhesion IMO. You can use a rough grade paper, because if you use these paints un-diluted then they are quite thick, which means they cover up scratches well IMO.
You can do several coats by thinning the paint with a thinners solution, but if you just need or want to do a single coat, then brushing it on with a single thick coat using a decent brush seems to work well. I've also found good results with smalled parts by dipping them whole in a can of smootherite and hanging them up to dry. Things like caliper brackets, footpegs, and lamp brackets i've done this way before.
You can also get Hammerite/Smootherite paint as a spray can, and providing you mask up well, then they work well, but the finish is not quite as tough as brush on paint. if your going to do things like wheels and are prepared to do at least 3coats, then spray paints can give good results with a bit of work and prep. Plasticote and PJ paints are also good spray type paints.
Of course if you have a bare frame and know someone with a spray shop with professional facilities, the having parts professionally painted is another option, giving very nice results but it's more cost and time consuming than the other methods if your paying someone to do it. |
| RamonTR |
 RamonTR Two Stroke Sniffer
| Mark65 |
| Avora |
 Avora Renault 5 Driver
 Posted: 19:26 - 22 Feb 2011 Post subject: |
I just hammerited my swingarm, its basically just to get me on the road until I can afford powdercoating when I strip the entire bike down after summer. Looks good, but I was slapping the paint around abit so I have some runs. That said, will still look good once its back on the bike. Not a big job to get the swingarm off anyhow, just takes some time.  ____________________ Kawasaki AR125 B8 - Getting ready for a summer time soon! |
The last post was made 14 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
