Not my day....
tatters
Exxon Valdez
PostPosted: 21:14 - 04 Aug 2004    Post subject: Not my day.... Reply with quote
both of my bikes KR1-S and VFR400 are now seriously fooked, KR1-s last month decided to blow up just after buying it and tonight coming home from work on my VFR (nc 24) the chain snapped at about 80mph taking the engine casing / Hydraulic clucth cover ripping all bolts out and Fracturing the bolt holes and to top it off the clutch rod bent and has bugered the seal so the engine is leaking oil from two areas.
Embarassed l think this maybe the end of my biking days for a long while Crying or Very sad
Shade_BW
I'm better than you
PostPosted: 21:16 - 04 Aug 2004    Post subject: Reply with quote
Bummer
If you like this post, rate it!
Karma is there for a reason.
WildGoose
White Van Man
PostPosted: 21:22 - 04 Aug 2004    Post subject: Reply with quote
sorry to hear it mate
small/old/imported bikes = win Rolling Eyes
Robby
Dirty Old Man
PostPosted: 22:00 - 04 Aug 2004    Post subject: Reply with quote
Told you NC24s are shit.
You might as well just cut your losses on those two, ebay them as is, spend the cash on a cb250 or something else fairly cheap and solid, and save up for something nice that works.
marc_yorks
PostPosted: 22:02 - 04 Aug 2004    Post subject: Reply with quote
Sorry to read about your bad luck,i got on my bike tonight to find the back tyre was flat,i gingerly rode it to the garage round the corner and the bike was running like a sack of poo poo Sad
More expense....
tatters
Exxon Valdez
PostPosted: 22:15 - 04 Aug 2004    Post subject: Reply with quote
no problem with the bike just the crap "iris O ring chain" only done 600 miles on it and check slack and lube it this morring Mad might get a other engine for about £200 or l will flog it , no way l,m selling the KR1-S just brought all the bits for that and my cylinders are coming back from re-plating next week and its a classic bike l expect to keep for many years.
just dug my old mountain bike out of the shed that l have,nt used since l was 15, to use for work etc.
Robby
Dirty Old Man
PostPosted: 22:18 - 04 Aug 2004    Post subject: Reply with quote
I had an iris chain on my nc24. It was 7 quid cheaper than the others. Did ok though.
I would advise against getting a spare engine for it. Just cut your losses.
Phoenix
Twisted Firestarter
PostPosted: 22:59 - 04 Aug 2004    Post subject: Re: Not my day.... Reply with quote
Exactly the same has happened to my NC30, the cover bolt holes are bust, the clutch rod bent and the seal buggered. Seal was easy to replace, get it from Bat Motorcycles or Elliots, the Clutch rod I had a spare from another engine, but the bolt hole I've still not managed to sort out yet. You say it's leaking oil from 2 places, the Clutch rod seal and where else? Did the actual engine casing crack? if so the engine will need rebuilding or replacing.
tatters
Exxon Valdez
PostPosted: 23:05 - 04 Aug 2004    Post subject: Reply with quote
the casing is also cracked, l brought the bike about 2 months ago for £900 and have spent about £300-400 on it (reg/chain&sprockets etc), l will probley just get rid off it for a few hundread it was the best nc24 l have ever seen very low mileage and was in mint condistion, looking at a honda four-hundread-four now
Dr Nick
PostPosted: 23:20 - 04 Aug 2004    Post subject: Reply with quote
What is it with Chains snapping this summer, its happened to at least 5 members of this forum in the past month or 2 Confused .
On another not i have a Hornet engine for sale im sure you could shoehorn into your nc24 Wink .
is that it
1cyl
PostPosted: 23:46 - 04 Aug 2004    Post subject: Re: Not my day.... Reply with quote
Join mine and Dr. Nick's Club, mine cost me £200 to fix, if its super serious just do what he did and buy a new engine.
Good luck with both mate, nothings more depressing than seeing a damaged bike in the garage.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
PostPosted: 23:53 - 04 Aug 2004    Post subject: Reply with quote
Don't worry too much, should be able to be fixed without too much hassle and cost. Snapped chains are a bit of hassle, had one on a R6 go back in March this year in the fast lane on the M4 at interesting speeds. Nice Neutral
And at least it'll cost less to fix them both than it cost to fix the TL engine. Doh!
baldy
PostPosted: 23:59 - 04 Aug 2004    Post subject: Reply with quote
I think that everyone should buy a honda c90, no more repairs Thumbs Up
(I have boaght one Shocked )
One day i will rule the world, just not today.
tgabber
PostPosted: 01:06 - 05 Aug 2004    Post subject: Reply with quote
Maybe there should be a forum certificate for snapped chains?
"It's all about dislocating expectation"
Kawasaki KMX125 -> Aprilia RS125 -> Kawasaki ZZR600
aqualung1
PostPosted: 01:19 - 05 Aug 2004    Post subject: Reply with quote
excellent choice.. leaveit in corner whaen have another bike, and it will always be there for you
(he says looking for dirt cheap second bike, fancy and enfield, still dont know why)
The last post was made 21 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.52 - MySQL Queries: 13 - Page Size: 88.7 Kb
