Kwikfit installed exhaust badly & are blaming engine mou
mrtEE
PostPosted: 16:39 - 04 Jan 2011    Post subject: Kwikfit installed exhaust badly & are blaming engine mou Reply with quote
Despite various reservations about their competence I had an exhaust mid section and catalytic converter fitted to my Xsara VTS by Kwik Fit as they were able to do it before xmas and at a reasonable price (well, competitive only after mucho haggling).
However unfortunately this has been a nightmare. When my girlfriend went to collect the car the exhaust was knocking against the underneath of the car at the front under acceleration. They took the car back in for adjustment and were unable to stop the exhaust doing this.
They told her that this was happening because one or more of the engine mounts were knackered causing too much movement.
I have since had a couple of mates (not trained mechanics but long term modifiers of cars) look at the engine whilst revving it and they reckon there is hardly any play in the mounts. THe car has only done 75k and I have not previously had any problems with an exhaust hitting the car under acceleration and no issues that you would normally associate with worn engine mounts.
The car has since been back a couple more times and still they are unable to resolve the issue and are insisting I need new mounts.
Do you think a Citroen dealership would be likely to tell the truth about if the mounts are OK and write me a letter saying this? Or would they also rip me off and tell me they need replacing in the hope of getting money from me?
Anything else I can do such as get head office involved?
Ta.
SlimRick
PostPosted: 16:41 - 04 Jan 2011    Post subject: Reply with quote
They may well be on their way out, but if it wasn't knocking before they fitted the new exhaust, it shouldn't after they've fitted it - surely the old exhaust would've made the noise too if it was the mounts.
Flip
PostPosted: 16:45 - 04 Jan 2011    Post subject: Reply with quote
My brother got a Milltek system fitted to his Focus by Demon Tweeks. It rattled etc, they looked at it again. Same problem. Possibly three times actually and not fixed. He rang Milltek and they sorted it for him (although he had to drive all the way up there to get their tech to fit it properly).
I don't suppose it's a Milltek? Could be worth ringing the manufacturer if it's not a cheap one.
mrtEE
PostPosted: 16:50 - 04 Jan 2011    Post subject: Reply with quote
Its not a performance exhaust, just an OEM replacement.
THere were no symptoms when the old exhaust was fitted and no rattling at all which makes me think the mounts are ok.
The 2 people that have looked at it said the play in the mounts looked normal.
PostPosted: 16:55 - 04 Jan 2011    Post subject: Reply with quote
Revving the engine in neutral won't put much strain on the engine mounts. Only likely to see any real movement when the car is in gear and pushing against the road.
However, are you in the AA, RAC or the like? If so give them a ring and see if they can provide an official opinion for you.
D O G
PostPosted: 17:04 - 04 Jan 2011    Post subject: Reply with quote
Sometimes the pattern exhausts aren't exactly the same. The pattern exhaust I fitted to our Honda had a cylindrical central silencer - which occassionally taps the heat shield, when the OE one was bullet shaped, and had enough clearance.
That may contribute to the issue - but since you don't have the parts to compare you may have bother - unless you can compare a std one to the pattern one you have on.
Engine mount may contribute to the problem - my Clio has this problem with exhaust hitting the heat sheild caused by one of the mounts deteriorating. Note that the engine doesn't move lots in the bay - it just sits in the wrong place.
mrtEE
One of the people that inspected the car did so in neutral, the other one was with the bonnet open, me driving forwards towards them whilst they inspected the engine.
I do have some breakdown cover that came with my car insurance, but are they likely to come out on a call out to inspect a potentially worn component?
Ta.
Hetzer
PostPosted: 17:23 - 04 Jan 2011    Post subject: Reply with quote
Good old Kwik-Fit, it's never ever ever their fault. There's a reason they have chimps working for them, it's because they pay peanuts.
Fisty
PostPosted: 17:25 - 04 Jan 2011    Post subject: Reply with quote
Take it to quick fit and block the entrance with your car untill the agree to fix it.
Fatter and faster than Fret
mistergixer
PostPosted: 17:29 - 04 Jan 2011    Post subject: Reply with quote
If you went to Kwik-Shit, i'd expect you also need 4 new tyres, new pads and disks and a new battery too.
Almost every car on the road is a rolling death-trap it would appear.
Rolling Eyes
Space Monkey #7
Tonka
PostPosted: 17:36 - 04 Jan 2011    Post subject: Reply with quote
Shocked They did exactly (I mean exactly) the same with mine. It's a Freelander, but without the propshaft (it was taken off deliberately) and they insisted that the knocking noise was the engine mounts and as a result of the missing propshaft. They quoted me some stupid prices and had taken the car to bits and wouldn't put it back together! I had a small tantrum and they threw it back together and I limped 5 minutes up the road to another garage.
Luckily I had a contact through the bike who had just employed a new car mechanic, so I got them to look at it and it turned out that KF hadn't fitted the exhaust properly. I'm not certain (it's about 2.5 years ago now and I am seriously stupid when it comes to cars! Embarassed ) but is there a catalytic manifold or something like that? If there is that is where my exhaust system had not been fixed correctly . He took one look, twiddled a few bits and hey presto all sorted.
They really are very bad and can't be trusted. Evil or Very Mad
swanny
PostPosted: 17:39 - 04 Jan 2011    Post subject: Reply with quote
as above, i had an issue with m,y golf after a new exhaust, they took out one of the retaining clips and let it hand a bit looser and the problem was fixed. Its one of the problems with pattern.
take it to a reputable small garage who will be only too happy to prove that kwik fit are a bunch of chimps..
I rang their head office who took a report, and then moved everyone from that garage, they treated my missus like a piece of dirt, trying to get the whole works done when she went in for a wheel baring. However as with most fast paced outlets, they serve that many customers that they do get a lot of complaints, and your best way is to ring them and stay calm and act more froma concerned point of view, rather than accusing them..
Hope this helps.
M SWANNY.. see a sig !
Hetzer
PostPosted: 17:45 - 04 Jan 2011    Post subject: Reply with quote
swanny wrote:
and your best way is to...
Find the manager and tell him he can either sort it or engage in a war that will involve his car, his house, and him out the back if he fancies his chances.
Chalky.
PostPosted: 17:50 - 04 Jan 2011    Post subject: Reply with quote
Kick up a shit storm. Although it is possible that the mounts were on their last legs, and fitting the exhaust was the final straw for them.
Maybe they are trying to reduce the living costs of the country, and stop their employees lining the pockets of the scum at the top. Laughing
Ed Case
PostPosted: 17:54 - 04 Jan 2011    Post subject: Reply with quote
I used Kwik-Fit once in Stafford, crap job, bolted the tail-pipe solidly to the car, loud as Hell in the motor then the bracket snapped. Bunch of tossers.
D O G
PostPosted: 18:03 - 04 Jan 2011    Post subject: Reply with quote
Really Confused can't see how fitting an exhaust would do any significant damage/wear and tear to a mount tbh.
Chalky.
PostPosted: 18:13 - 04 Jan 2011    Post subject: Reply with quote
If the bolts are very rusted it might take a bit of force to shift them, bouncing the manifold all over the place and rocking the engine around?
Unlikely I know, but possible?
PostPosted: 18:21 - 04 Jan 2011    Post subject: Reply with quote
The mounts have to cope with a massive amount of torque to move the car.
Hetzer
PostPosted: 18:50 - 04 Jan 2011    Post subject: Reply with quote
No, they pay their employees peanuts to have them con customers into having large amounts of uneccessary expensive work done so the top bods can live the life of O Reilly.
69.9mph
PostPosted: 19:04 - 04 Jan 2011    Post subject: Reply with quote
I've been in the motor trade for a long time.
Don't ever go to Kwik-Fit.
This advice has cost you nothing.
Chalky.
PostPosted: 19:29 - 04 Jan 2011    Post subject: Reply with quote
I reckon you said in another thread something along the lines of people are being paid too much?
Should we lower wages to lower living costs, or raise wages in line with living costs?
Hetzer
PostPosted: 19:31 - 04 Jan 2011    Post subject: Reply with quote
Say what?
There are too many people at the top being paid too much, with too many people at the bottom being paid too little. The few having the biggest and the bestest and the mostest of everything at the expense of the many.
Chalky.
PostPosted: 19:39 - 04 Jan 2011    Post subject: Reply with quote
Was was that phrase of yours... hmmm....
Oh yes!
Its button has been pressed!
Perhaps some of the people with lots of stuff being paid lots work harder than others with less. But lets just group them all together anyway. Wink
Bru
PostPosted: 19:43 - 04 Jan 2011    Post subject: Reply with quote
I 'third' the pattern-part possibility, that a differently-shaped pipe/box could be contacting the underside of the vehicle. There is far more flex in the exhaust system than in the engine mounts.
You could get under the vehicle and take a photo, then (try and) compare the shape with that of the original; go to a good motor factors, if not the dealer, who should have a microfiche image of the correct exhaust component.
I have the same issue with my car, because I purchased (and fitted) a non-standard catalytic replacement from a motor factors. I also have a part-severed rear engine mount, but it is plain that the fault lies with the new exhaust component, as it lies against part of the heat shield, whereas the original (OEM) part sat pretty much in the middle of the exhaust channel.
If the exhaust is rattling, then you should be able to spot where it is closest to the body. Confirm also that you received an OEM part.
T0MMY
That's just life, we're just animals like any other, you shouldn't expect too much from people Laughing
I've had a couple of Xsara VTSs (underrated cars) and I've replaced full exhausts on both of them. The pattern exhausts never fit properly and tend to be both loud and fragile. Also, engine mount failures are very common in these cars. I'd say they could be telling the truth but also would agree that you should never go to Kwik Fit Wink
Incidentally I would trust the main dealers even less than Kwik Fit, they really will rip you off. I've only been to them twice in my life and both times they tried to utterly shaft me.
The last post was made 15 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 132.38 Kb
