| MARTIN RD125LC |
 MARTIN RD125LC Derestricted Danger
| Blau Zedong |
 Blau Zedong Banned
| MARTIN RD125LC |
| MarJay |
 MarJay But it's British!
| evoboy |
 evoboy World Chat Champion
 Posted: 21:15 - 05 Jan 2011 Post subject: |
Its difficult to tell what needs doing without actually hearing/seeing/riding it.
Are you sure your just not asking too much from a 125cc 2stroke and trying to make it pull a high gear at a low speed?
I cant see it making much power below 4k revs.
My 250 twin 2 stroke has K&N's and you can hear the air rushing in at low revs, but it still pulls clean without bogging/hessitating. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| MARTIN RD125LC |
| MARTIN RD125LC |
| MinhDinh |
 MinhDinh World Chat Champion
 Posted: 21:23 - 05 Jan 2011 Post subject: |
Have you tried phoning a good mechanic on what he thinks the problem is and how much it will cost? Then do it yourself! ____________________ Hit the G spot.  |
| MARTIN RD125LC |
| evoboy |
 Posted: 21:43 - 05 Jan 2011 Post subject: |
Does it run any better low down if you use the choke? ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| MARTIN RD125LC |
| evoboy |
 Posted: 21:58 - 05 Jan 2011 Post subject: |
Are you adding the choke a small amount while riding the bike?
Air screw is only gonna help at small amounts of throttle input.
It could be the needle height, but try the choke idea first. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| MARTIN RD125LC |
| Old Git Racing |
 Old Git Racing World Chat Champion
| Vincent |
 Vincent Banned
| stevo as b4 |
| MARTIN RD125LC |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
| MARTIN RD125LC |
| Kickstart |
 Kickstart The Oracle
 Posted: 16:33 - 06 Jan 2011 Post subject: |
The air screw will have a tiny effect. It pretty much just allows a small amount of air through a fueling circuit at idle throttle openings. If you are using any reasonable amount of throttle then its effect is tiny. It is just really adjusting the mixture at idle and on throttle positions only just off idle. If you at doing 4.5k then I would expect you have the throttle reasonably far open, so the jet that is relevant for the mixture is the needle.
The RD is a non power valved performance 2 stroke, and that (especially combined with the Allspeed exhaust) is going to mean it has stuff all low down power. I would expect it to be very weak until the power band (at a guess, around 6k~7k) at which point it will take off like a scalded cat. Without using the revs (which you can't really use while running in) I would expect it to be left for dead by a CG125.
| MARTIN RD125LC |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:32 - 06 Jan 2011 Post subject: |
| bikersupermoto wrote: | martin, dont worry too much about high revs, 2 stroke engines are designed to rev high, they make their power at the top end of the rev range not in the bottom or mid revs.
hence the saying - screaming 2 strokes! |
Lol! - What was the RD125LC red-lines at 11K?
It's actually the bee-in a bean-can sound, from an expanison chamber exhaust that makes them sound so screaming, that and the fact that at whatever revs, there's one pop a rev, rather than every two for a four stroke.
CB125TD, actually 'screams' far higher than the two-strokes. Red-lines at 12K, and it dissapears off the scale at around 13,500! Being a twin, its also popping ones a rev, but much smaller pops!
Really does 'scream', but dumping into a straight pipe rather than a resonance chamber, doesn't sound so 'tinny' (just tortured!) Power actually comes in at aroun 6K on the CB too, like a two-stroke.
HOWEVER: as said, RD125LC pre-Powervalve didn't like to do much unless you had 6K dialed in on the tacho, and kept it between there and 9K.
Running an 'open' filter, isn't great on them. Not as bad as earlier piston ported two strokes, but not great.
When the piston starts to fall on a 2T the reed valve is closed by the compression in the crank-case, and the air that was being dragged through the carb, stoppes suddenly, and sends a shock wave back through the carb.
On the old piston ported engines, with no reed-valve, the first part of the power stroke, compressing charge sucked into the crank-case could actually push some back out through the inlet tract, back through the carb.
As the air passed BACK through the carb, it would suck mure fuel up the jet, same as if it was passing the right way, and a 'shock wave' does a similar thing.
If you have a large air-box, this 'back-flow' can be cought in it, so when the piston starts to rise again, the enritched charge that has passed forwards through the carb on the first suck, then back again on the back-wash, gets sucked through a third time, enritched even more, before actually getting burned in the engine.
One of the things that makes 2T's so jet sensitive. (Happens on 4T's as well, but with much greater cycle time between 'sucks' often not as badly.
On the old piston ported 2T's, they used to use really long inlet tracts to reduce the effect, and make jetting simpler, and big bell-mouths.
When the reed and disc valve bikes came along, and expansion chanbers, ideas about resonance tuning started to get more attension, and it was realised that the air-filter and air-filter box weren't actually such an impediment to engine breathing as first thought, and could actually 'help'.
Anyway. For your redicament, what you are hearing is 'induction roar' as the air at certain loads is slow enough to cause turbulance and resonance that's audible.
If the engines otehr wise 'fine' I wouldn't worry about it. That induction noise is nothing to do with the mixture, so provided its jetted and set up correctly, I wouldn't mess with it.
Adding an air-box or shroud, might help it run better as well as reduce the turbulance effect, and make it closer to 'standard' and possibly a way to find ecconomy, or perhaps correct a flat-spot, if you find one, but until then, old addage, if it aint broke, dont fix it! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Shaft |
 Shaft World Chat Champion
 Posted: 00:58 - 07 Jan 2011 Post subject: |
^^^^This.
But I would go out of my way to find a replacement airbox.
I worked on a few of these when they were new (I was a bit of a 2T nerd then) and they didn't like having their induction system messed with; all you ever achieved was to remove whatever of the miniscule low range power it had and make it a git to ride in traffic.
Going back to a standard airbox might give you half a chance of getting some clean throttle response under 3K.
IIRC derestricting 125LCs was a pretty involved task and changing the airbox was a no-no. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 01:34 - 07 Jan 2011 Post subject: |
Think I have just remembered a 125LC 'quirk'... LC Nuts may elaborate, or correct me here. But from memory, the stock air-box had a tapered 'fin' in it, which a lot of elcie-Boys cut out with a stanley-knife, in the belief that it was part of the restriction pack, but in actual fact was a pretty 'key' flow corrector. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Shaft |
 Posted: 01:47 - 07 Jan 2011 Post subject: |
| Teflon-Mike wrote: | Think I have just remembered a 125LC 'quirk'... LC Nuts may elaborate, or correct me here. But from memory, the stock air-box had a tapered 'fin' in it, which a lot of elcie-Boys cut out with a stanley-knife, in the belief that it was part of the restriction pack, but in actual fact was a pretty 'key' flow corrector. |
I think you're right T-M, I was trying to think of the 'popular' mods of the time, but it was a long time ago and the old grey cells aren't what they were
What my addled brain keeps coming back to is, the standard airbox is the best, unless you're going ballistic, ie full on race tune (SS was the man!!) which means you can't pull away unless the rev counter says 7...... ____________________ Things get better with age; I'm close to being magnificent........
The last post was made 14 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
