| Coxyzxr |
 Coxyzxr Brolly Dolly
| Shaft |
 Shaft World Chat Champion
 Posted: 01:39 - 07 Jan 2011 Post subject: |
My old trick used to be squirting some light machine oil (can you still buy '3-In-1'?) down the plug holes and turning the thing over a few times, every week.
I've saved a few engines that way. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Coxyzxr |
| Shaft |
 Posted: 20:41 - 07 Jan 2011 Post subject: |
Depends on how it's been stored really.
If you've left it with no plugs in and the inlet tracts open, there's the potential for moisture and all sorts of debris to be in there.
After a year, if there was going to be any corrosion damage, it will already be done, so the best you can do is minimise it by using the oil/hand turning thing and loosely stuffing some rags into any open holes.
The only way you'll know if it's damaged is to either take the top off it, or borrow a bore scope and have a squint down the plug holes; other than that, put some decent oil in it before you fire it up, then cross everything and pray to your chosen deity! ____________________ Things get better with age; I'm close to being magnificent........
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| Coxyzxr |
| stevo as b4 |
| Shaft |
 Posted: 02:04 - 08 Jan 2011 Post subject: |
That's the risk you take when you lay up an engine for a long time and don't lubricate it; maybe the rings stuck, or the bores pitted slightly (there's still moisture in the air in the cylinders, even if they're sealed) and the rings picked up, in the same way a fork seal can tear on a tiny pit on a stanchion.
Engines don't take kindly to not moving for extended periods of time; sometimes you get away with it, sometimes you don't, but keeping them lubricated and turning, increases your chances of not having any problems.
Coxyzxr, for the effort and cost involved, just pour some oil down the bores and keep the bloody thing turning, it certainly won't do any harm and it might save you a packet, in the long run. ____________________ Things get better with age; I'm close to being magnificent........
| 0l0dom0l0 |
| stevo as b4 |
The last post was made 15 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
