| MTM281 |
 MTM281 Derestricted Danger
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
| MTM281 |
 Posted: 19:47 - 08 Jan 2011 Post subject: |
Thanks for the quick reply,
It does it all the time at about 6000 rpm, it hasn't been sitting for that long maybe a week, its done about 1400 miles.
I didn't have this problem before getting it cleaned though.
| 0l0dom0l0 wrote: | Hello
Sounds like it could be a dirty carb. Does it do it all the time or just occasionally? Its possible its suffering from carb icing. Also has the bike been sitting atall?
With regards to neutral, it could be down to a number of things. The easiest way to 'fix it' is to go for neutral when you rolling slightly. So you might have gone from second to first coming to a set of lights and just creep up to the lights with the clutch in and try to go for neutral. It normally works.
I'm assuming its the 125 if its the 4t?
If so they are very new bikes and you shouldn't be suffering from problems like that already. Its possible it needs a good service. How many miles has it done?
From here I would, give it a good service. This means: Oil, Oil filter, Plug (which might help the jerkyness btw), Air filter (depending on miles), Chain tightened and lubricated, clutch cable adjusted properly, gear linkage assembly lubricated.
That should sort it and all of that you can do without taking it to a garage. I think it might cost you about £25 for all that?
Hope that helps |
____________________ ... |
| fiery tupp |
 fiery tupp Trackday Trickster
 Posted: 20:20 - 08 Jan 2011 Post subject: Re: Derbi GPR Issues |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
 Posted: 20:41 - 08 Jan 2011 Post subject: |
id agree with 0l0dom0l0 (had to copy an paste that lol)
also dunno if u got access to a garage thats dry ? ... if u do, id keep the bike in there as much as poss when ur not using it ... coz if it wasnt doing all this before u washed it, its poss water has got into the airfilter/carb and / or the electrics and upset them.
a warm dry garage might help to dry it out.
also, definitely fit a new spark plug - can fix a lot of probs as the plugs burn out or foul up and its also your cheapest option - cpl £.
id also take out the air filter and dry it out if its damp ... even repalce it if its dirty.
good luck an let us know how u get on with it.
nice bike btw  ____________________ tinybikes |
| 0l0dom0l0 |
| MTM281 |
 Posted: 21:10 - 08 Jan 2011 Post subject: Re: Derbi GPR Issues |
Lol ive gotta stay in his good books though he splashes out so often and i always seem to get the hand-me-downs, but his hand-me-downs are only a few days old lol. I'm hoping for his r6 in a few months lmao.
Thanks for all the help guys. ____________________ ... |
| HD |
 HD World Chat Champion
 Posted: 21:14 - 08 Jan 2011 Post subject: |
Maybe water in the air filter then?
And as for neutral I can't put it straight in. Just rock the bike forward and back a bit and it should slot in  ____________________ Rusty '02 Vito Camper + CBR600F3 |
| cheekythomas |
 cheekythomas Crazy Courier
| MTM281 |
The last post was made 15 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
