oil change lubing chain
brandonroyer1...
PostPosted: 12:19 - 23 Nov 2010    Post subject: oil change lubing chain Reply with quote
hello i do not own a bike yet but i am worrying about when should i change the oil and cleaning and lubing the chain what products should i use and does anyone know any good videos of people doing it the right way i live in the uk
coolhands
PostPosted: 12:55 - 23 Nov 2010    Post subject: Reply with quote
Hi! Hand
I've got a similar problem - I've never been in Outer Space, yet I worry about how to clean my visor when I am up there? Anyone got any advice? Thinking
DrDonnyBrago
PostPosted: 13:21 - 23 Nov 2010    Post subject: Re: oil change lubing chain Reply with quote
When you buy a bike, buy a Haynes service manual for that bike.
There is a wealth of valuable information in a manual, including how to change oil and what oil to use, how to adjust your chain tension, all other basic servicing etc.
Get some paraffin (£5 for 4L in B+Q - sold as lamp fuel), use this with a rag and a soft toothbrush to clean your chain, then use a paintbrush and some engine oil to lube it afterwards.
There are a host of 'special' chain lubes for sale, engine oil is probably the most widely used and is exceptionally cheap (especially if it has already been used in the engine!).
daxo
PostPosted: 23:43 - 08 Jan 2011    Post subject: Reply with quote
can I use some used motorcycle engine oil to lube the chain ?? or should I buy halfords' chain wax or some WD40?
the chain is not new and it is starting to show sign of rust (just a bit)
how can I make the chain work for a bit more ? only done 8000km....
nothing wrong with it at the moment btw apart from starting the rust attack
multijoy
PostPosted: 23:52 - 08 Jan 2011    Post subject: Reply with quote
Yes, could do and no, on the basis that WD40 may eat the o-rings. The former is, of course, free.
hornetmike
PostPosted: 00:11 - 09 Jan 2011    Post subject: Reply with quote
I've heard you can use gearbox oil too?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
daxo
PostPosted: 00:16 - 09 Jan 2011    Post subject: Reply with quote
I though it was the same thing on motorbikes...
if I will go and buy car gearbox oil then I think its cheaper buying proper chain wax right?
I just wanted to know the cheapest way to lubricate the chain....I'm keep looking in the forum and dont find any answer yet....
multijoy
PostPosted: 00:27 - 09 Jan 2011    Post subject: Reply with quote
Cheapest way is to use the stuff from the oil change. Get a paintbrush, paint it on.
The disadvantage with using oil rather than a dedicated chain lube is that it's quite thin, so you don't want to put too much on, and you'll need to reapply it pretty regularly. It'll fling as well, so might make your rear wheel a bit grubby. As far as I can tell, any oil (within reason!) will work for chains, subject to the fling/reapplication points.
On the upside, you've already paid for oil from the oil change it so it's costing you nowt!
2 strokes need gearbox oil, the gearbox in most (and I stand to be corrected!) 4 strokes is lubricated with the engine oil.
daxo
PostPosted: 00:31 - 09 Jan 2011    Post subject: Reply with quote
I'll give it a try with used engine oil...
I found the debate I was looking for
andym
PostPosted: 02:01 - 09 Jan 2011    Post subject: Reply with quote
and if anyone is looking for some spare used oil I took almost 2 litres out of my bike the other day.... only done about 1000 miles too Wink
TanacoiusD This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
andym
PostPosted: 13:49 - 09 Jan 2011    Post subject: Reply with quote
TanacoiusD wrote:
I bet you make a thread next week asking what to lube your chain with .... Wink
I don't think that'll will be happening any time soon, I've got 2 large cans of chain lube heh heh heh
The last post was made 15 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.25 - MySQL Queries: 13 - Page Size: 73.13 Kb
