honda bros hell!!!
onamissionman
PostPosted: 10:02 - 10 Jan 2011    Post subject: honda bros hell!!! Reply with quote
hey ! i live on a greek island and dont speak the local lingo so finding it hard to get ansews : i have a mk 1 honda bros 650 with only 6000km on the clock while riding it had this horid ticking noise apear wich turned out to be the grudgen pin had worn in the little end on an angle when stripping it i noticed the crank moved side to side only bout at a guess bout 10mm in my mind this is the coarse of the odd wear on the con rod . apparently this is end float ? so duz any1 no what the end float is supposed to be and how to adjust it as i dont want to spend all that money and it happen again PLEASE HELP!!! MY LEGS WERNT MADE FOR WALKING BUT BIKE BALLEST !!!
Syris the Indomitable
PostPosted: 19:07 - 10 Jan 2011    Post subject: Reply with quote
From what I have read end float adjustment is an Austrailin or Americam colloquialism for valve adjustments which sounds about right to me. (Could be wrong)
I could be wrong but the maths don't add up to me unless this bike has been ridden without any engine oil, or the bike been round the clock in terms of milage.
There is supposed to be a little lateral movemnt of the comrod.
6000km with a worn gudgen pin and 10mm lateral movement which equals 1cm lateral movement of the comrod.????????????????????
Arrrr!!!!, Leg it!!!
The ticking sound will probably have been the cam shaft valve clearences which are easy to set with a spanner an a set of feeler gauges.
Valve clearances:
# Inlet: 0.15mm ± 0.02mm cold.
# Exhaust: 0.2mm ± 0.02mm cold.
Link with similar issue. https://www.biker.ie/forum/showthread.php?t=32363
Link to usefull maintenance. https://homepage.eircom.net/~hondabros/VALVE_CLEARANCE.html
https://homepage.eircom.net/~hondabros/index.html
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
salty21
PostPosted: 19:21 - 10 Jan 2011    Post subject: Reply with quote
i may be mistaken but i tought lateral movement was ok aslong as it has no play within the bearing, as in hold the bottom of the crank and check for play side to side.
fiery tupp
PostPosted: 19:32 - 10 Jan 2011    Post subject: Reply with quote
The end float, I think is the side to side clearance space as you say , which it has to have , to a certain degree . Some I think have shims in , whether they can be adjusted ??? I dont know .
Honda should be able to give you the specs for the limits of them . Neutral
If you can't fix it with a hammer , use your head .
hornetmike
PostPosted: 19:37 - 10 Jan 2011    Post subject: Reply with quote
big end bearings ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
The last post was made 15 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 45.26 Kb
