Bulb problems ...
huskie69
PostPosted: 20:35 - 10 Jan 2011    Post subject: Bulb problems ... Reply with quote
A few weeks ago, I took delivery of some new dual filament 55w BA20D halogen bulbs as a replacement for my current 35w as I was pretty disappointed in the light output of the 35w.
I finally got round to fitting the new bulb last night (after losing my main beam the day before:)).
The extra power output was instantly noticeable and I rode to work this morning with an almost HID looking beam lighting my way.
However, on the way back this evening, I noticed the full beam didn't seem to be that bright compared to normal beam. I switched between the two a few times, then 'flashed' (to get both beams working together). That's when it all went dark...
After a major panic as I couldn't see fuck all and narrowly missing the kerb, I switched over to sidelights and pulled over. I didn't have a spare, it was pissing down and cold so decided to drive the remaining 7 miles on sidelights - luckily no coppers about! I made it home and went to inspect the damage.
The holder that the bulb sits in appeared to have melted around the bulb and the bulb had fused to the plastic. It took 2 hours to remove and I was tempted to just give up and bodge it on a few occasions!
Have I made a mistake going for a halogen replacement? I wasn't expecting it to get so hot, and reading other posts where riders have been unhappy with the light output from their chinky bikes they went for halogen replacements.
'10 Skyjet SJ125-23 - Crashed Sad > '09 YBR 125 > '53 Suzuki SV650 - Died Sad > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R
Willson
PostPosted: 20:47 - 10 Jan 2011    Post subject: Reply with quote
My guess is that it's got to hot for the holder... try getting a replacement one that's a bit more resilient, or back to the old lamp it is. But that's just my guess... I'm no expert in that field...
Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold
Odie
Fit a relay
huskie69
PostPosted: 21:10 - 10 Jan 2011    Post subject: Reply with quote
Odie wrote:
Fit a relay
Oh bollocks, I completely forgot about relays! - thanks for pointing out my electrical uselessness!
Willson
PostPosted: 21:28 - 10 Jan 2011    Post subject: Reply with quote
+1, I'm also a bit useless it would appear.
Raffles
PostPosted: 21:36 - 10 Jan 2011    Post subject: Reply with quote
How would fitting a relay stop the plastic holder from melting?
neil.
PostPosted: 07:54 - 11 Jan 2011    Post subject: Reply with quote
That bulb was too powerful and hot for the holder - your bike's headlamp assembly is designed for 35 watts of light/heat so stick with that. Halfords do a halogen 35/35w ba20d that is pretty good. https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263257_langId_-1_categoryId_165582 The best we'll get on our little bikes without having to replace the entire headlamp assembly.
alains
PostPosted: 11:09 - 11 Jan 2011    Post subject: Reply with quote
download a tuttorial to transform Ba20d into H4 fitting
https://www.geneva-racing.ch/~alains/Ba20dH4.doc
then you may fit HID kit (in this case buying sockets is not necessary)
PostPosted: 12:04 - 11 Jan 2011    Post subject: Reply with quote
Relay won't help with the bulb holder but might save damage to the rest of the wiring.
You have used a bulb that draws over 50% more power than standard, so likely it generates a hell of a lot more heat. Then using the headlight flash you have pushed that up even higher (not sure what your dip beam filament is).
With headlights the difference between dip and main beam often isn't how bright they are. The difference is where the filament is in the bulb, and the few mm difference plus the shield over the dip beam filament means the light is aimed in a different place.
huskie69
PostPosted: 12:34 - 11 Jan 2011    Post subject: Reply with quote
I really didn't expect it get that hot, even drawing twice as much current - I assumed that given the effieciency of halogen lights, most of the energy would be output as light rather than heat.
Anyway, the HID conversion sounds like a nice idea but to be honest I don't really want to spend any more time, money or effort on this bloody machine as I don't intend on keeping it longer than I have to.
I have a standard BA20D 'globe' bulb on order as a replacement for the original (and to keep as a spare), and I'll also pick up a halogen 35w from Halfords as Neil suggested and see how that works out.
PostPosted: 12:41 - 11 Jan 2011    Post subject: Reply with quote
Not sure the extra heat from a halogen bulb would be enough where the wiring connects to cause a problem on its own. Honestly don't know. Could be interesting to have a play with a halogen and normal bulb and a temperature probe to see where and what the temperature difference is.
neil.
PostPosted: 13:25 - 11 Jan 2011    Post subject: Reply with quote
I have found the Halfords bulb lasts ages and is quite a bit brighter than the krypton globe shaped bulb. It hasn't melted the bulb holder and I have run them for over 2 years and over 25'000 miles, going through 3 of them. I have tried the cheap halogen bulbs from eBay but they don't last more than a week for me (must be sensitive to vibration), so not worth it.
Efficiency-wise, filament bulbs less than 5% efficient (it varies depending on the gas/filament material used - see https://en.wikipedia.org/wiki/Incandescent_light_bulb#Efficiency_comparisons ), so not very efficient at all. I would say a 3 watt Luxeon LED is on a par in terms of brightness.
iooi
PostPosted: 17:44 - 11 Jan 2011    Post subject: Reply with quote
HID generates even more heat than a halagen bulb. So if you have already mealted stuff, don't push it any further.
alains
PostPosted: 10:27 - 13 Jan 2011    Post subject: Reply with quote
you're wrong , it's a cold bulb
huskie69
PostPosted: 11:39 - 13 Jan 2011    Post subject: Reply with quote
I've settled for the 35w/35w halogens from Halfords - they're not great but they're a damnsite better than the originals.
There is a gap of 3 years, 107 days between these two posts...
Andy9934
PostPosted: 21:12 - 29 Apr 2014    Post subject: Reply with quote
I wouldn't normally bump a thread this old but it's the second result for BA20d to H4 on google.
I bought a cheap (£3) LED H4 bulb on ebay and was able to simply pull the LED bit from the base. Upon inspection I noticed that it would be VERY easy to separate the two parts with a soldering iron.
alains
PostPosted: 09:07 - 30 Apr 2014    Post subject: Reply with quote
sorry for the wrong link (i've split in 2 french-English)
new one is https://www.geneva-racing.ch/~alains/Ba20dH4en.doc
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.14 Sec - Server Load: 0.44 - MySQL Queries: 15 - Page Size: 99.9 Kb
