will a dif engin fit
boody1 This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
CaNsA
PostPosted: 02:24 - 12 Jan 2011    Post subject: Reply with quote
Try asking your question properly, using proper words.
Oh and the spell checker is awesome!
MaybeGuy
PostPosted: 08:43 - 12 Jan 2011    Post subject: Reply with quote
awaits the 'im dyslexic' cop out for not trying at primary school
DrDonnyBrago
PostPosted: 09:18 - 12 Jan 2011    Post subject: Reply with quote
If you can't spell engine, I sincerely doubt that you are capable of changing one.
boody1
PostPosted: 09:57 - 12 Jan 2011    Post subject: thanks Reply with quote
well thanks for the help not i was always told if you have nothing nice to say dont say anythink i was looking for help not criticism so if you did not know why bother comenting
PostPosted: 10:07 - 12 Jan 2011    Post subject: Reply with quote
You'll have to suck it and see. The 156/157FMI in your bike is a close copy of the CG125 lump internally, but the mounts and ports may not be 100% compatible.
Also, as Rob says, the electrics may also be an issue - the crankshaft position sensor from whatever CG125 engine you manage to source might not be compatible with the Hongdou's CDI.
The short answer is that it'll be close, and you can probably make it work, but you should consider carefully whether it's worth your while.
What's up with your current engine? Parts for the 156/157FMi are readily available.
boody1
PostPosted: 10:40 - 12 Jan 2011    Post subject: Reply with quote
it sounds like a singer sewing machine an the clutch is slipping pluss it keeps slipping into newtral from first by itself i already have a full cg doner bike thats well past doing anything to
PostPosted: 10:55 - 12 Jan 2011    Post subject: Reply with quote
Right, then measure up the mounts on the CG engine with the Hongdou frame, swap the Hongdou CDI to the CG engine and vice versa to see if they work, then get all manly on it.
boody1
PostPosted: 11:18 - 12 Jan 2011    Post subject: Reply with quote
thanks will check it out
CaNsA
PostPosted: 13:06 - 12 Jan 2011    Post subject: Reply with quote
So I am abusive for offering advice about how to get the correct info......
You are asking for help, the least you could do is use the spell checker that is available, use the correct words and pay attention to grammar.
I find your posts confusing. Ah well never mind.
nowhere.elysium
The Pork Lord
PostPosted: 13:24 - 12 Jan 2011    Post subject: Reply with quote
Sounds more like it'd be easier to sort the clutch out. Most 4-stroke 125 engines sound like a sewing machine, it's part of their charm. If you want it to sound beefier, change the exhaust.
The engines on these Chinese bikes are all internally very similar, as Rogerborg has said. the 156FMI is, to my eye, closer to the RV125 engine than the CG125 externally speaking, that is), so you'll definitely need to check out the mounts.
Again, as has been mentioned already, the wiring loom isn't likely to be the same, so that'll be more work.
[url=https://www.china-parts.co.uk/]These guys[/ur] sell whole new engines, along with all the parts to put together a whole bike, if it so took your fancy.
boody1
PostPosted: 13:34 - 12 Jan 2011    Post subject: Reply with quote
thanks for the info phoned a local garage an he recons he has done it before an will only charge £100 to do it witch sounds better that me botching it but thanks again
TattooArtista
PostPosted: 13:37 - 12 Jan 2011    Post subject: Reply with quote
honestly, people need to relax a little bit, this forum has become a place i dont recognise anymore
nowhere.elysium
The Pork Lord
PostPosted: 13:40 - 12 Jan 2011    Post subject: Reply with quote
A garage said they'd change the engine over for £100? That's inordinately cheap.
Well, your profile suggests you've only been here 4 months. People tend to get cranky over the winter. It's a pretty normal pattern.
colin1
Captain Safety
PostPosted: 14:51 - 12 Jan 2011    Post subject: Re: thanks Reply with quote
You are clearly new here and don't know how it works.
TattooArtista
PostPosted: 14:59 - 12 Jan 2011    Post subject: Reply with quote
Well, your profile suggests you've only been here 4 months. People tend to get cranky over the winter. It's a pretty normal pattern.[/quote]
yes on this account, I'm not going through the whole explanation of starting a new account, my last account was 2006,
so yeah my last statement still stands.
PostPosted: 15:02 - 12 Jan 2011    Post subject: Reply with quote
This place has always been intolerant of poor spelling and grammar. That's why it's so heavily built into the karma system.
Personally I would much rather the OP had made some effort with their posts. If they can't be arsed to use the spell checker, then why should I be arsed to give them any meaningful advice?
nowhere.elysium
The Pork Lord
PostPosted: 15:15 - 12 Jan 2011    Post subject: Reply with quote
Fair enough. Regardless, the initial post was damn near indecipherable. Given that the sole method of communication here is going to be by writing clearly, it pays to apply a bit of effort to making oneself understood.
TattooArtista
PostPosted: 15:22 - 12 Jan 2011    Post subject: Reply with quote
yeah i agree i guess, just seems people wait to jump on people who make mistakes,it gets boring, kinda like the old powerband jokes and the bloody cool story bro pics
CaNsA
PostPosted: 15:25 - 12 Jan 2011    Post subject: Reply with quote
Sorry dude, but you asked for it......
https://www.threadbombing.com/data/media/68/cool_story_bro_2.jpg
nowhere.elysium
The Pork Lord
PostPosted: 15:26 - 12 Jan 2011    Post subject: Reply with quote
Well, in defense of the CSB images, some people do need to learn that this isn't twitter, and we don't care about every banal detail of everyone's lives. As far as I'm concerned, there's no problem with expressing disdain for something that doesn't captivate one's attention.
The powerband thing, yes, that always was crap. It doesn't come up very often these days, though.
As for waiting in the wings to jump on people who make a mistake of some description; it happens regardless of which forum you're on. Yes, BCF is a little less forgiving than when I started, but on the up side, it does weed out some of the dross. Not all of it by a long shot, but it's self-moderation at work, really.
The last post was made 15 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 130.66 Kb
