How to tighten spark plug cover.
121game121
PostPosted: 21:56 - 13 Jan 2011    Post subject: How to tighten spark plug cover. Reply with quote
How would i tighten my spark plug cover, its come loose a few times ive riden it.
Mrs Vale46
PostPosted: 22:13 - 13 Jan 2011    Post subject: Reply with quote
Spark plug cover? do you mean the HT lead?
121game121
PostPosted: 22:46 - 13 Jan 2011    Post subject: Reply with quote
Not sure what its called technically. But the cover that goes over the spark plug and gives it its electrical charge.
Carl_steveo
PostPosted: 22:47 - 13 Jan 2011    Post subject: Reply with quote
Yep the HT lead, have you pushed it on really hard. Mine clicks when I do it.
Current: Honda Nsr 125
Live: Sunderland
fiery tupp
PostPosted: 22:57 - 13 Jan 2011    Post subject: Reply with quote
If its the the plug cap , loose on the HT lead ? screw it in tighter
If its the cap loose on the plug , you should be able to bend the metal clip inside the cap in a bit , with a thin screwdriver , or get a new cap Neutral
If you can't fix it with a hammer , use your head .
andym
PostPosted: 23:41 - 13 Jan 2011    Post subject: Reply with quote
new cap is only a couple of quid too Thumbs Up
clarkkent1987...
PostPosted: 13:57 - 15 Jan 2011    Post subject: Reply with quote
There are many different styles and types of spark plug caps. Make sure you use the spark plug cap that perfectly matched the angle between the spark plug wire and spark plug itself. And also, for clarification HT lead is different from the Spark Plug Cap. I had attached the images for you to identify HT lead from Spark plug cap. See the images below. Back to your spark plug cap maybe its not in good contact. So, the steps you should take is to make sure that when you screw the coil wire on the new cap you feel that the wire Butt up to the end of the Blind Hole in the Cap. (The Wire will start to turn with the Cap, at which point you should stop immediately - Do NOT try to overtighten.) Wink
custom dirt bike graphics
The last post was made 15 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 55.03 Kb
