gilera dna 50cc no fuel getting to spark plug
dna50
PostPosted: 01:47 - 14 Jan 2011    Post subject: gilera dna 50cc no fuel getting to spark plug Reply with quote
iv just put a new piston and rings in my gilera dna 50cc two stroke and it wont start however i have sprayed carb cleaner into the carb and it fires up however it only runs if i continue spraying carb cleaner otherwise will just turn off straight away. i have checked and there is fuel getting into the carb and the carb was cleaned out recently and is fully working i have put a new spark plug in and it just seems to stay dry its not getting any fuel. can anyone help?
hsaeed
G and J recovery
PostPosted: 12:43 - 14 Jan 2011    Post subject: Reply with quote
have you put the rings in correct,,
if water cooled wat was the o rings in head like did u change them,
as water gets onto piston
u say you strip carb to clean, is the choke stuck on
glen
dna50
PostPosted: 12:56 - 14 Jan 2011    Post subject: gilera dna 50cc no fuel getting to spark plug Reply with quote
which o rings? i changed the headgasket, yes the rings were put in right as they have to locate in with the pins on the piston so u cant really go wrong with them. when i spray carb cleaner into the carb it starts up and runs fine but its basicly running on carb cleaner. if the 2 stroke system wasnt functutioning properly im sure it woudnt start right?
hsaeed
dna50
PostPosted: 12:58 - 14 Jan 2011    Post subject: gilera dna 50cc no fuel getting to spark plug Reply with quote
and after i cleaned the carb and refitted it the bike was running perfect until i stripped the engine to change rings and piston
hsaeed
G and J recovery
PostPosted: 12:59 - 14 Jan 2011    Post subject: Reply with quote
call if you want 07706480551
glen
lukamon
PostPosted: 04:01 - 15 Jan 2011    Post subject: Reply with quote
Off the top of my head from my dna:
Vaccuum tap. Check theblack rubber (not clear fuel line) hose from the bottom of the fuel tank is plugged into the manifold as the suction opens the tap. Also check the one way (in line) fuel valve and the fuel pump is working
killa wrote: Im an ass man myself
The last post was made 15 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 47.9 Kb
