Kwik Fit & Brake Pads
mistergixer
PostPosted: 21:50 - 14 Jan 2011    Post subject: Kwik Fit & Brake Pads Reply with quote
The MR2 needs a new set of pads fitting to the fronts, looking around my local Euro CarParts (??) shop will do a set of 4 Pagid pads for £70.
However, i noticed Kwik Fit are offering pad change plus free pads for the life of the car - although the website doesn't appear to list any prices.
I wouldn't generally trust Kwik Fit monkeys, but surely they can't fuck-up something as simple as fitting a set of brake pads. Surely?
Anyone got any experiences of them and their 'brake promise'? Any idea of prices? If it's not that more expensive than DIY i'm tempted to take it in just to avoid the arse of it all.
Space Monkey #7
WildGoose
White Van Man
PostPosted: 22:19 - 14 Jan 2011    Post subject: Reply with quote
Try www.buypartsby.co.uk for prices.
Someone recommended them on here a while back and they came out cheapest for a set of front pads and discs for my civic.
Brake system is the most vital part of your car, doesn't matter how simple it should be, I wouldn't trust kwik fit to go anywhere near it.
They might do the pads fine, buy grolly something up too tight so it never comes off the next time. Or slip and damage some other component, or rigid brake line.
Too many 'ifs'.
My list of "can repair my brakes" gets smaller all the time.
Found car brakes easier to do that bike brakes, its just a miserable time of year to be doing it yourself, I think.
[EDIT] Thinking about it, pushing the pistons back in to accomodate the newer and therefore thicker pads, needs to be done with care. In my manual it says you can damage the seals in the master cylinder (which is not something I ever considered in the past) if you just let it backflow. You have to clamp/pinch the line, and let the excess fluid bleed out at the nipple.
Fuck trying to explain that to kwik fit.
Flip
A friend of my brothers had his tyres done there recently. He told him that he noticed the brake pads were shot and and needed replacing. He said OK replace them. He was given a bill and in return produced a receipt for free pad brakes for life (or whatever) that were only fitted 2 months previous. New brakes were fitted (for free) and the bloke was dragged into the office. Laughing I have no idea of the price though.
Raffles
PostPosted: 22:21 - 14 Jan 2011    Post subject: Reply with quote
You are NOT going to get away with just brake pads at Kwik Fit. When their ''technicians'' inspect your brake pads they will invariably notice that you need new brake discs, wheel bearings, shock absorbers, steering rack etc.
Avoid Kwik Fit like the plague.
Flip
PostPosted: 22:23 - 14 Jan 2011    Post subject: Reply with quote
Raffles wrote:
You are NOT going to get away with just brake pads at Kwik Fit. When their ''technicians'' inspect your brake pads they will invariably notice that you need new discs, wheel bearing, shock absorbers, steering rack etc.
Just tell them to fuck off init. Smile
mistergixer
PostPosted: 22:47 - 14 Jan 2011    Post subject: Reply with quote
There is always that option.
Space Monkey #7
swiftb
should be able to pick up a set of pads for around £25, very easy job to do. Id imagine Kwik Fit ramp the price up a little if theyre offering free pads for life, there a money making organisation and not stupid, free pads for life 'sounds' good but in reality most peoples pads probably outlast the amount of time they own the car.
DIY. Thumbs Up
mistergixer
PostPosted: 22:53 - 14 Jan 2011    Post subject: Reply with quote
Interesting. Never heard that before, nor have i ever had a problem with using a big piece of wood, hammer handle etc to lever the piston back in gently.
Years ago, the first time i ever changed brake pads on my own (without the assistance of Mr.Gixer senior), i just could not get the piston back in far enough to get the new pads in. Eventually, in despair i rang up the old man for advice and assistance.
He said 'you have taken the lid off the brake fluid reservoir, haven't you?'
Embarassed
Space Monkey #7
PostPosted: 22:58 - 14 Jan 2011    Post subject: Reply with quote
I have heard it (and also that it can damage the seals in the ABS) but not sure I believe it. Pressure when pushing the pistons back is a fraction of that used when you stand on the brakes hard.
However the other claim is that pushing the fluid back can push debris back into the ABS pump which can be damaged by it.
Easy enough to crack off the bleed nipples when you push the pistons back.
And with rear disks with a handbrake where you need to rotate the pistons back in I find it easiest to just take the calipers off so I can put them on the floor then push down hard while rotating the pistons.
jimspeed
PostPosted: 23:26 - 14 Jan 2011    Post subject: Reply with quote
damaging the master cyl seals can happen mainly on vauxhalls and we replaced many mk3 astra master cylinders that had been buggered up by the likes of quick fit/fast fit etc, its not really a problem for most cars now tho but we tend to clamp the flexi pipe and open the bleed nipple to allow the fluid out of the caliper as it then means fresh fluid is being introduced into the sytem too.
as for letting quick fit do any sort of brake work.......
if you are not happy doing them yourself find yourself a small local garage to to it most will be happy to fit them even of you supply the pads yourself,
some abs modules now require plugging to diagnostic equipment to bleed if the become air locked too just for giggles Rolling Eyes
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
swiftb
PostPosted: 23:38 - 14 Jan 2011    Post subject: Reply with quote
as jimspeed said astra-f's are renowned for 'flipping' seals in the master cylinder. The way we used to prevent this was to bleed the brakes with a pressure bleeder. Only car ive ever had it happen on to me and it was saved by same said pressure bleeder. The usual lid of reservoir and slowly forcing pistons back rarely causes any issues.
EDIT: (pressure bleeder not vac bleeder) Thumbs Up
jimspeed
PostPosted: 23:41 - 14 Jan 2011    Post subject: Reply with quote
astra-f thats the one I can never remember which are which lol, cav's too. some were ok with a vac bleed but a lot we threw away (well expensive too something like £110 each or something back in the day)
binge
Emo Kiddy
PostPosted: 23:45 - 14 Jan 2011    Post subject: Reply with quote
Pads for life at kwik-fit is a genuine offer.
Providing the disks are above the manufacturers minimum spec, then they will replace your pads free of charge.
I dont know where a lot of you guys take your cars (In terms of Kwik-Fit garages), but some of the stories I hear on this forum are somewhat comical, if a little hard to believe.
Not been with the company for around a year now, but for the 5 years I worked in, and supervised a number of different centers around Kent, I didn't once come across anything as bad as some of the things I hear on this forum.
Anyway, as long as you ask to see around the car, they will happily show you the disks, measure them in front of you etc.
One thing that used to truely FUCK me off with some customers though, was with brake disks.
Of course, as a company, it was, and still is their job to up-sell. That doesnt necessarily mean rip off, it just means up-sell... advise...
A lot of the time, it's down to the fitters capabilities of putting their point across to the customer, as apposed to what they are actually trying to say.
If I was doing brake's on the front of a car (Or rear), And the disks were literally a fly's knackers above the minimum thickness, then I would advise the customer has the disks changed too. Simply because the disks will be way below minimum before the pads wear out again. Which of course can cause the rotor to crack etc.
Rule of thumb, is generally expect 2 sets of pads, to one set of disks.
Not strictly true on some cars, especially bigger motors. And also automatics, as they eat brakes, usually fuck the disks before they wear out, purely as they get so hot.
But yeah, back to the topic. Although a set of pads will cost between £60 and £100 at Kwik-fit. They are indeed covered under the lifetime warranty.
I'd personally go to unipart, or euro-car parts, and then fit them yourself.
Keith, I prefer to use my wind-back tool when doing brakes on cars with wind back rear (or front on certain citroen's) calipers.
Ben
defblade
PostPosted: 23:51 - 14 Jan 2011    Post subject: Reply with quote
Really? Where does that debris come from? 'cos it must have been through the pump already if you're just pushing the piston back
I bought a re-winding tool first time I met these - turns out it's very good at pushing BMW single-piston fronts back in, too.... in the pissing rain all Wednesday evening (caliper jammed on Saturday Sad 2.5 hours to replace one caliper and both discs and pads in the dark in the rain not too bad tho....)[/b]
PostPosted: 23:59 - 14 Jan 2011    Post subject: Reply with quote
Possibly rubbish from the rubber flexi lines. As said I am a bit dubious, but it is easy enough to crack the bleed nipple off and at least gives you a chance (OK, forces you to Razz ) to bleed the system.
I have a couple that just push the pistons back and they are great. Only one I have for the pistons that turn is just a socket with the correct cutouts for the piston. Hence you need to turn it with a ratchet while pushing, which is just about impossible on the car.
jimspeed
PostPosted: 00:15 - 15 Jan 2011    Post subject: Reply with quote
Ben
yes I will agree that some places actually have decent lads in them but there is no smoke without fire (just look at the exhaust thread on here for a start)
the biggest problem with fast fit places is the fact that they can't specialise on one make of car and work on everything (we do vw mainly and are picky about anything else for instance).
dont get me started on wind back tools not only do we need left and right threaded ones we also need a bloody laptop to fit some audi rear pads Rolling Eyes
SoND
PostPosted: 00:35 - 15 Jan 2011    Post subject: Re: Kwik Fit & Brake Pads Reply with quote
mistergixer wrote:
blah
Do it yourself, it's a 30min job.
EDIT: Free pads? Pay for the offer but take the pads and do the job yourself.
Phoenix
Twisted Firestarter
PostPosted: 01:22 - 15 Jan 2011    Post subject: Reply with quote
Never understood this, they don't hold your car to ransom. If you use kwik fit you go in and tell them what you want and then leave. You don't hand it over and say, "fix it and anything else you find". Kwik fit is only good for oil changes in my book as it's the cheapest way to do one.
Personally I wouldn't bother with brakes, they're so easy to do yourself, the only tools you need over the ones that come with the car is sometimes an allen key or spanners for removing the caliper and disc, it takes less than 2 hours to do brakes and discs at the front if you've never done it before, be a lot cheaper too. I always push the pistons back just like on a bike, not buggered any seals up yet but then I don't drive a Vauxhall.
mistergixer
PostPosted: 01:53 - 15 Jan 2011    Post subject: Reply with quote
Cheers for the advice chaps. Think i'll just do it myself, as usual.
I was only really wondering if it was a good enough deal to be worth avoiding the 'arse' of DIY - at the moment the unsurfaced 'carpark' (corner of a field) where we park is like the last days of the battle of the Somme after all the wet weather recently.
It won't surprise me if i develop trenchfoot during the hour or so it'll take me to do the pads, that's how soggy it is underfoot.
Space Monkey #7
Des
PostPosted: 10:14 - 15 Jan 2011    Post subject: Reply with quote
I am another former Kwik Fit customer that will never go near them again. After 3 very bad experiences with them, they will never get another penny out of me. I know a few people that say the same, and my sister got caught out by them once with the old "squirt some oil on the shock absorber" trick.
1998 Fireblade
1988 VFR
MinhDinh
PostPosted: 11:01 - 15 Jan 2011    Post subject: Reply with quote
Basically, Kwik Fit offer free stuff like any other company to get you to come in, which is a point where they try and make money off you for finding other things that are wrong.
Hit the G spot. Wink
Robby
Dirty Old Man
PostPosted: 13:37 - 15 Jan 2011    Post subject: Reply with quote
The thing about damaging the ABS pump by pushing back the pistons may be true, but opening the bleed nipple gets around it. Not really a problem for me, seeing as I nearly always change the brake fluid at the same time as pads. Generally do discs as well. New discs, pads and fluid means you can pretty much then ignore the brakes for ages, and they're so much sharper.
Groove
PostPosted: 00:10 - 16 Jan 2011    Post subject: Reply with quote
I used quick fit for their £30 oil and filter change.
They do also do a free check of your car which is meant to include air pressures etc.
While i watched him change the oil (and filter!) and poke around the tyres and shine a light around the suspension all he came back with was the back 2 tyres only had around 2mm of tread on each.
I do have a few suspicions though as although i do not know the age of the tyres, i can tell they are different makes and surely fitted at different times so should not really have the same tread.
I also know that one of the rear tyres seems to have a VERY slow puncture and that the pressure was low in that tyre but he has marked it the same as every other tyre!
He asked me if i wanted prices for the tyres, i said no.
Not bad for a 12 year old car with 190k on the clocks i was expecting a list! Laughing
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
andyscooter
PostPosted: 09:18 - 16 Jan 2011    Post subject: Reply with quote
my old mans car went there once
they used an air tool to put the allan head bolts back in the caliper
and it was done so tight the heads rounded off
two years later we went to change the pads and couldnt get the caliper apart
The last post was made 15 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 142.8 Kb
