| astroscope |
 astroscope Spanner Monkey
| astroscope |
 Posted: 14:37 - 15 Jan 2011 Post subject: |
Basicall I'm trying to remove this big wheel nut (spindle) but it's just going round in circles  ____________________ 2010 Honda FES S Wing 125 |
| whitedevil |
 whitedevil World Chat Champion
| astroscope |
| Vincent |
 Vincent Banned
| astroscope |
| Vincent |
 Vincent Banned
| CaNsA |
 CaNsA Super Spammer
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| astroscope |
| neil. |
 neil. World Chat Champion
 Posted: 18:20 - 15 Jan 2011 Post subject: |
Always used LM grease on my spindles with no issues.  |
| stinkwheel |
 Posted: 18:45 - 15 Jan 2011 Post subject: |
Moly grease will be fine.
I use copper grease on mine. Just a thin skimming so it doesn't get into the bearings. Nothing should be turning on the spindle anyway, the grease is there to stop it seizing, not for lubrication.
You get stuck spindles quite a lot. I think it's due to differing metal corrosion where the steel spindle passes through the alloy of the hub or an alloy calliper bracket. The alloy corrodes slightly and the hole becomes narrowed by white furry aluminium oxide. Worth giving this a clean out too with some emery paper or wire wool. A smear of grease will help prevent this recurring. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| astroscope |
 Posted: 23:37 - 15 Jan 2011 Post subject: |
Thanks for all your help guys.
I've managed to take the rear wheel off now.
Just need to get to those brakes tomorrow.
I've made a short youtube clip of my work.
Please comment with suggestions...
Cheers...
https://www.youtube.com/watch?v=epWvKqeAJQk ____________________ 2010 Honda FES S Wing 125 |
| ZRX61 |
 ZRX61 Victor Meldrew
| Vincent |
 Vincent Banned
 Posted: 12:35 - 16 Jan 2011 Post subject: |
Not too sure about the way you pull the axle out at the end - top points for using something that won't damage the axle but hitting it that way puts a little stress on the bearing as you're knocking the axle sideways. Also, you don't need a rubber mallet for hitting the wood, a lump hammer might be better. A piece of hardwood wouldn't fall apart as easily either. The best way in this instance would probably be to use a slide hammer, or a long drift from the other side, (exhaust permitting). That's a minute point tho.
This bit about lifting the wheel to get the axle centralised for removal, what I've done before to free both hands is to use a bottle jack at the front of the bike to lean it back until the weight is taken off the wheel.
Next tip - clean the bloomin thing  |
| astroscope |
The last post was made 15 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
