1 person - RW alignment, urgent :p
kramdra
PostPosted: 16:38 - 17 Jan 2011    Post subject: 1 person - RW alignment, urgent :p Reply with quote
hello
I need some help. Im doing the rear wheel alignment. When I done it earlyer this month, I had somone to hold the bike up, so I could check the wheels were straight with a pole.
I dont have any one that can hold it today, so its on axle stands and center stand - but I cant check if its right.
Tomorrow I have a long journey (140 miles, crawley->folksone, and back) so need it to work.
When turning the wheel, there is a chain *clicking* noise from the front sprocket. gets worse with the alignment but doesnt seem to go away fully when its right.
Also last night the headlamp blew again (5th bulb since november). hoping it wont do any more as I put some orings on to take out vibration
any ideas?
thanks
Mark
PostPosted: 16:43 - 17 Jan 2011    Post subject: Reply with quote
I've always just matched the wheel to the marks on the swingarm, never had any problems.
Paxovasa
PostPosted: 16:49 - 17 Jan 2011    Post subject: Reply with quote
Why are you checking it every month?
The clicking could be due to too much slack, the chain too tight and even a tight spot in the chain.
neil.
PostPosted: 17:10 - 17 Jan 2011    Post subject: Reply with quote
Last time I had clicking from my chain at the front sprocket, the chain snapped soon after!
kramdra
PostPosted: 18:49 - 17 Jan 2011    Post subject: Reply with quote
I would not like this to happen! the reson is the chain, sprockets, and bolts are all NEW. one month old.
I also dont want to damage the gearbox bearings any more than they are :p so I need this right before I ride it.
iooi
PostPosted: 18:59 - 17 Jan 2011    Post subject: Reply with quote
If you did it a month ago when fitting the new c/s. Then just go by the turns on the adjusters.
Although after a month, the chain should not need adjusting unless you are not lubing it often enough.
140 miles should be nothing.
I think I would be more worried about the bulb going than the chain....
rob_scott92
PostPosted: 19:06 - 17 Jan 2011    Post subject: Reply with quote
When i put new chain and sprockets on my wee Gs i was having to adjust it VERY regularly. I bought a cheap set that wasn't D.I.D so i imagine thats why.
The set on the 350 though, i've had it for 8 months and done near enough 5k miles on it. I've not even had to touch the chain, although i might do soon. Its probably worth mentioning i have lubed this one more than my 125 but even so thats still fairly good going Very Happy
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
MaybeGuy
PostPosted: 19:24 - 17 Jan 2011    Post subject: Reply with quote
i bet the chains too tight
daesimps
PostPosted: 19:26 - 17 Jan 2011    Post subject: Reply with quote
The markings on the adjusters on my CBF1000 are way out. I certainly can't rely on them on my bike.
The way I did it was to measure the distance from the inside of the swing arm to the wheel rim on both sides of the wheel and check they were equal. I turned the wheel 1/4 turn and checked another couple of times just in case the rim wasn't perfect.
Mine has always clicked when rotating the wheel - worse when sat on the bike and not so noticeable when on the centre stand. I've had it checked out by various places and they've checked alignment, tension, chain tight spots, sprockets, front sprocket shaft bearings etc. The only conclusion is that it is the chain against the swing arm slider that's making the the noise. It's done it for the last 16,000 miles. It's never got any worse nor any better.
If it ain't broke, fix it till it is!
kramdra
PostPosted: 03:03 - 18 Jan 2011    Post subject: Reply with quote
So, its done. Ive test ridden it, and it seems fine now.
There is a slight click from the gearbox sprocket, but its not a loud one. The alignment is not perfect, but not far off....
Next week ill take it in to a garage. I noticed the brake cam has a lot of axial movement in use! (1-2mm!! for 45* of rotation?!)
And I did have a helper :p
Anyway, we adjusted the chain, with the wheel on the floor. pushed bike around to move the wheel into place.
but after tightening up the spindle its all moved :/ I guess this happened last time but didnt notice.
so we adjusted it again, with the spindle still tight (72ft/lbs) then I decided the adjusters need to be locked, so added a second, m6 nyloc nuts...
thanks
Mark
Devans
PostPosted: 03:06 - 18 Jan 2011    Post subject: Reply with quote
No bike is perfect, they're mechanical and do make odd noises sometimes xD!
PostPosted: 10:26 - 18 Jan 2011    Post subject: Reply with quote
Check the Chain slack when somebody is actually sitting on the bike, when you sit on the bike the chain gets tighter
geordiecbrblo...
PostPosted: 16:29 - 18 Jan 2011    Post subject: Reply with quote
The clicking noise is most likely the front sprocket being worn - the sprocket teeth take on a "ninja-death star" style shape!
https://www.bikechatforums.com/download.php?id=76709
The last post was made 15 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 91.37 Kb
