Heated Grip Questions.
WillSwain95
PostPosted: 22:21 - 17 Jan 2011    Post subject: Heated Grip Questions. Reply with quote
Hey, Im thinking of getting heated grips. Even though i know its getting warmer but i was still thinking of getting some.
Just curious though. How do you install them? Like wire them up. Diagrams would be greatful if possible Smile
Thanks a lot.
Will.
PostPosted: 22:32 - 17 Jan 2011    Post subject: Re: Heated Grip Questions. Reply with quote
Often they just wire to a live with ignition wire (like the sidelight on modern bikes) with a switch in between - if you're getting fancier, you use a relay.
Muscle Bike Rider
PostPosted: 22:33 - 17 Jan 2011    Post subject: Reply with quote
I recently fitted mine with no experience at all, quite easy if you follow the instructions, go on to youtube and watch some vids of them being fitted. You can wire them direct to battery or splice into the ignition feed which is better as theres no chance you will drain your battery if you forget to turn them off.
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
WillSwain95
PostPosted: 23:04 - 17 Jan 2011    Post subject: Reply with quote
Ok thanks for the help. I cant find any good vids on how to install them on youtube. They're all the actual grips not the pads Sad
Muscle Bike Rider
PostPosted: 09:46 - 18 Jan 2011    Post subject: Reply with quote
Is it these?
https://cgi.ebay.co.uk/OXFORD-MOTORCYCLE-MOTORBIKE-ESSENTIAL-HOTGRIPS-HOTHANDS-/220698626302?pt=UK_Motorcycle_Parts&hash=item3362a9c8fe
Just wrap around your existing grips and wire direct to battery, there is a on off switch.
kawakid
PostPosted: 10:54 - 18 Jan 2011    Post subject: Reply with quote
Some heated grips have a built in sensor, so they know to turn off when the engine stops.
However many don't and thus will totally drain your battery. In that case it's best to use a relay. In that case follow this https://www.bikechatforums.com/download.php?id=53243
I've a twin and a 4.
owl10
PostPosted: 13:34 - 18 Jan 2011    Post subject: Reply with quote
A detailed instruction complete with pictures, written by stinkwheel on here is available from:
https://www.bikechatforums.com/viewtopic.php?t=192713&highlight=symtec+heated
there is a link to a similarly detailed thread, with similarly detailed pictures on how to wire up the relay contained in that as well.
I found it to be the most helpful whilst doing mine, and as I type I've remembered Ive left my grips turned on -but it doesnt matter because Ive used a relay so my bike will still start* when i go outside later!!!
It really is important to wire them properly, as coming back to a flat battery once is once too many times. Good news its really very simple to do.
The grips will be easier to fit than the pads.... once your old grips are off just slide on the new heated ones, wire up in the same way.
*hopefully, but if it doesnt start it wont be the grips causing it not too work - just one of the many other problems.....
DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
Adam80UK
PostPosted: 07:28 - 19 Jan 2011    Post subject: Reply with quote
Sack off the heated grip idea and go the whole hog with some Gerbings heated motorcycle gloves. Not cheap but they are awesome and guaranteed for life I believe.
Very toasty indeed with the elements covering your entire hands. Expensive yes, but worth every penny.
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
PostPosted: 10:56 - 19 Jan 2011    Post subject: Reply with quote
I haven't tried heated gloves yet (would like to) but from what other people have said, I still think either is better when combined with decent muffs - as this severely reduces the effect of the wind, so your hands stay a consistent temperature without the un-heated bits cooling down (heard some complain the inside of their hands too/cold outside too hot with the heated gloves; opposite for the grips of course.)
Adam80UK
PostPosted: 18:53 - 20 Jan 2011    Post subject: Reply with quote
Well you can get a little temp controller for heated gloves.
I've used them on the coldest weather the South East has thrown at us and hands stay toasty! I don't have a temp controller and have never had a problem, I just use them when it's very cold, else I use my good pair of Alpinestar winter gloves.
Adam80UK
PostPosted: 18:54 - 20 Jan 2011    Post subject: Reply with quote
Also above only applies to quality gloves, I'm specifically talking about Gerbing's, no cheap shite.
The last post was made 15 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 69.55 Kb
