Damaging engine banging?
sharpee1984
PostPosted: 12:26 - 19 Jan 2011    Post subject: Damaging engine banging? Reply with quote
Good Morning all,
I’m slightly concerned about my Yamaha 2001 X600. Over the last month there has been an intermittent banging, I think from the engine, possibly gearbox or clutch? The last 2 days on my commute I have noticed it a lot more and it sounds quite damaging. It is starting to send shockwaves through the bike, which can’t be a good thing! I’m pretty sure it’s nothing to do with the back wheel, which spins freely. The ride if fine (at the moment), and I only notice it in the lower gears. I have also noticed it only occurs with the clutch out? It’s most likely old age, done 65000 miles of which I’ve done 4000. The oil is always topped up and chain is looked after.
Any help or suggestions would be greatly appreciated.
Many Thanks
Lee
PRESENT: HONDA CBR600F 2002
Past: Yamaha XJ600N 2001
Past: Hyosung GT125 2008
Paxovasa
PostPosted: 12:34 - 19 Jan 2011    Post subject: Reply with quote
Does it make the noise at tick over?
If yes, then use a screw driver and listen to the engine.
Also check the sprockets (especially the front one).
PostPosted: 12:36 - 19 Jan 2011    Post subject: Reply with quote
My Vote is the sprockets, chain or rear wheel bearings.
DrDonnyBrago
PostPosted: 12:47 - 19 Jan 2011    Post subject: Reply with quote
Lift up the rear and spin the rear wheel by hand, I reckon you will be able to hear or feel the chain/sprockets click as the wheel goes round.
Should go without saying but: don't feck with the chain if the engine is running and it is in gear.
0ddball
PostPosted: 13:56 - 19 Jan 2011    Post subject: Reply with quote
Any marks on the underside of the swingarm where the chain may have been slapping against it?
PostPosted: 17:11 - 19 Jan 2011    Post subject: Re: Damaging engine banging? Reply with quote
sharpee1984 wrote:
Good Morning all,
Many Thanks
Lee
Lee there are some basic things to do to try to diagnose the source of the noise.
Firstly, does it happen when the bike is running but not moving? If so, the problem is in the engine.
When it happens on the move, does the frequency change with revs or with road speed. This is an important observation. Go up through the first three or four gears and listen to the frequency of the knocking. If it stays constant across a gearchange, the problem is after the gearbox, if the frequency changes with a gearchange and follows the drop in revs as you change up a gear, the problem is in the engine.
If it is a knocking noise that doesn't folow a perfect rhythm, but knocks randomly, then your problem is almost certainly final drive related, most probably a collapsed wheel bearing.
Try to give us some more accurate info on the nature of the noise, it will help to diagnose the problem for you.
sharpee1984
PostPosted: 19:52 - 19 Jan 2011    Post subject: Reply with quote
Hi All,
Thanks for the response. I will try and answer the questions to get to the bottom of the issue.
No, just when out and about.
I have tried this while on the centre stand. No banging or clicking as the wheel goes round. I turned it by hand and it spins freely 2/3 times. I also get it into gear, up and down into 2nd and nothing again.
No. Without taking the sprocket cover off (which I won't be able to do until the weekend) I cannot see any visible signs of the chain hitting anything.
Does it happen when the bike is running but not moving?
No, Just when I am on th move.
does the frequency change with revs or with road speed?
It bangs (approximately) between 1 & 3 times a second, and increases with speed, although seems to disappear when 30mph+.
I hope this extra information is useful.
Many Thanks
Lee
mr.kris
PostPosted: 20:14 - 19 Jan 2011    Post subject: Reply with quote
check your chain for tight spots!
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
PostPosted: 20:16 - 19 Jan 2011    Post subject: Reply with quote
I also think it's most likely final drive.
Does it get worse quickly when more power is applied?
PostPosted: 20:22 - 19 Jan 2011    Post subject: Reply with quote
It probably doesn't happen above 30 because you can't here it due to wind/engine noise.
It is gonna be the chain I think, can you post pictures?
sharpee1984
PostPosted: 11:09 - 20 Jan 2011    Post subject: Reply with quote
Once again I bow to all your superior knowledge. I had a check over the chain last night after reading your thoughts. Although it was too dark and late to check the front sprocket, which I will be doing this weekend, I checked the chain. It wasn’t in as great a condition as I thought and there were a few tight links. A quick clean, re-oil and TLC removed any tight spots. I waited until this morning’s commute to see if the banging was still occurring...it wasn’t. Ran smooth!
I could just about see the front sprocket last night and it definitely needs replacing. I couldn’t see any missing teeth but it was hard to make out. Needless to say I will be buying a chain & sprocket set ASAP. Any suggestions before I trawl through the T’internet?
I really didn’t think it would be the drive chain (that’s obviously why you guys have yellow dotted karma and not green like me, I will get there one day!) It sounded really vigorous at times and it sounded like it was coming and shaking from the right hand side. I was expecting worse, especially with the mileage.
Many Thanks Karma
Lee
PostPosted: 12:07 - 20 Jan 2011    Post subject: Reply with quote
Any branded O ring chain I'd go for being a 125.
sharpee1984
PostPosted: 14:14 - 20 Jan 2011    Post subject: Reply with quote
125.....don't insult me Wink
It's a X600N Yamaha.
Cheers though! Thumbs Up
PostPosted: 15:18 - 20 Jan 2011    Post subject: Reply with quote
Sorry just glanced at your sig, and saw 125, in that case go for a decent o or x ring chain.
PostPosted: 16:16 - 20 Jan 2011    Post subject: Reply with quote
Tight spots in a chain is almost always a sign of neglect. In the weather we hare having this time of year, you should lube it every day.
Paxovasa
PostPosted: 16:22 - 20 Jan 2011    Post subject: Reply with quote
Every day, that is OTT.
Twice a week will be suffcient. Thumbs Up
PostPosted: 17:18 - 20 Jan 2011    Post subject: Reply with quote
More dependant on miles that time IMO, I have a scotoiler and don;t have to worry about such things Laughing
sharpee1984
PostPosted: 19:01 - 20 Jan 2011    Post subject: Reply with quote
I thought I was keeping on top of it giving it a brush of oil every weekend riding approximately 130 miles a week. Not anymore!
Thanks for your help people!
DrDonnyBrago
PostPosted: 10:27 - 21 Jan 2011    Post subject: Reply with quote
AFAM or DID chain and sprocket kit.
Avoid IRIS chains and unbranded chains, they are shite.
Something like:
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/2743VX
The last post was made 15 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.12 - MySQL Queries: 13 - Page Size: 110.79 Kb
