Any metal workers in here?
loply
PostPosted: 00:39 - 20 Jan 2011    Post subject: Any metal workers in here? Reply with quote
Hi folks,
Just looking for some quick metal working advice if anybody would care to help.
I'm in the process of building a devilishly useful and rather large machine and it involves a fair bit of metalwork.
First question: I bought an Evolution Rage cut-anything toothed blade for my compound mitre saw. Cut some 40x20x2 box section beautifully, then chopped a 40mm mild steel rod with ease (albeit quite slow), then tried another 40mm rod and it went a few mm then got rapidly blunt and is now unable to cut mild steel. Have I done something daft? Should I risk another one of these blades or would I be better off getting a second hand metal chopsaw with an abrasive blade? I honestly don't know the speed of my mitre saw but I presume it's whatever is standard, these blades are meant for 2,500rpm or less - was my saw possibly too fast?
Second question: I had to drill an on-axis hole down the middle of that 40mm mild steel tube. I don't have a lathe so I chopped off a 20mm long section of it, popped that on my pillar drill and drilled an 10.2mm hole into it, which I then tapped to M12. It ended up miles off-axis. I had centre punched the piece really well, and drilled straight in with the 10.2mm drill using lube, it cut easily but emerged on the other side in a different spot to where it went in. What should I do when I retry this? Should I have used a smaller drill first? Do I need to buy a spotter drill?
Cheers for any help!
Yamaha SZR660 Caution to the wind, the throttle pinned!
SoND
PostPosted: 01:14 - 20 Jan 2011    Post subject: Re: Any metal workers in here? Reply with quote
40mm solid bar? Those blades just aren't up to heavy work like that, even a large abrasive disc would get badly worn down. Ideally you would use a big bandsaw with a lot of coolant but of course people don't tend to have one just knocking around in the shed.
If you see a cheap 9inch grinder somewhere get it and save your chopsaw blades for hollow sections.
PostPosted: 01:22 - 20 Jan 2011    Post subject: Reply with quote
You might have blunted the blade by using too light a cut or you might have cooked it by going too heavy.
If you have a lot of that 40mm bar to cut you're better off using a bandsaw or power hacksaw. The cut from the chop-saw is not likely to be perfectly square across the bar for starters.
To drill a through-hole concentric you really need to find a lathe, because for the inexperienced, trying to drill and tap it on-axis after you have cut it with the chop-saw is not going to yield good results.
SoND
PostPosted: 01:28 - 20 Jan 2011    Post subject: Re: Any metal workers in here? Reply with quote
Drilling a 20mm hole straight isn't easy.
How square were the faces? If they weren't square you didn't really have a chance.
What way was it clamped in? Cheap drill vises aren't square.
You could try drilling a pilot (3-4mm dia) about half way from either side, both holes should touch, even if they don't line up right. Then with the next size bit (~6), cut normally through the first half but when you reach the centre use high speed and low pressure to chip through into the next hole. Drills don't like going through offset holes, do it carefully and hopefully they will straighten out good enough for its purpose.
I'm thinking electric drill and bench vise instead of the pillar drill so the material isn't sitting on its not square face.
MaybeGuy
PostPosted: 02:12 - 20 Jan 2011    Post subject: Reply with quote
are you using coolant with the saw blade?
as for the drilling, try a pilot hole. start with a 4mm bit, or a slightly more bodgey way is to use a slightly smaller than required drill bit (like a 9mm) and drill halfway on each side, then widen it using the 10.2. only if you've got limited sizes available.
imo starting with a 10.2 with just a centrepunch is too much depending on the material. look at the tip of the drill. it's not a perfect point. ie: a tiny flat bit, may not look like much, but that's what's causing it to wander about and fuck your shit up. the pilot hole would clear the flat bit allowing a straight cut.
PostPosted: 02:26 - 20 Jan 2011    Post subject: Reply with quote
Bodgey is right. Better to go with a small pilot and then straight in with the final size. Puttng in a pilot just smaller than the finished size is asking for trouble.
loply
PostPosted: 10:54 - 20 Jan 2011    Post subject: Reply with quote
Hi folks,
Thanks for the replies so far.
Those Rage blades claim to be able to cut steel up to 50mm thick, and the first 40mm bar did indeed cut fairly effortlessly... I didn't use coolant or lube as it's meant to be used without. I did let the blade cool occasionally though.
I might look on Gumtree for a used abrasive chopsaw. Are these any good? How much does a replacement disc cost and will 40mm bar be a difficult task even on one of these?
MaybeGuy
PostPosted: 11:24 - 20 Jan 2011    Post subject: Reply with quote
that'll be why it blunted so quickly then. Surely the chop saw has a built in pump?
Theres not much you can get away with when working steel without coolant.
SoND
PostPosted: 14:47 - 20 Jan 2011    Post subject: Reply with quote
Rage saws are dry and highspeed, you don't use coolant with them.
It's probably advertised for 50mm hollow sections, not solid steel.
You can get your blades sharpened, if you stop cutting solid stuff it'll last a lot longer.
Solid bar will eat up an abrasive disc pretty quick and it will be just as noisy and slow.
It's not worth getting another saw just to cut a handful of bits, take your material to an engineering shop and ask them really nicely to put it in their bandsaw.
loply
PostPosted: 17:07 - 20 Jan 2011    Post subject: Reply with quote
There's a bloke advertising a 'barely used' chopsaw with blade for £20 locally, I think I'll go and buy that and then I'll be able to finish my bits and bobs using it, and I'll attempt to resharpen the Rage blade.
I wouldn't mind owning a chopsaw anyway as the Rage blade is a bit scary for cutting M12 stud or othersuch small objects. It works but... You can imagine the fear...
How would I sharpen the Rage blade? Using a mini file and doing the obvious?
SoND
PostPosted: 17:44 - 20 Jan 2011    Post subject: Reply with quote
There are people that do it professionally. The rage blades are tipped with tungsten carbide, you can give it a go but it's hard.
An abrasive chopsaw will be just as scary and dangerous! The cheaper saws don't tend to come with a vise built onto it so get clamps that fit.
Always clamp your work, those blades will cut through you like butter.
Safety goggles are preferable to glasses because chips can get under them easily.
Wear your ear plugs / defenders too. They're very fking loud as you've probably noticed and a hot spark in the ear isn't nice.
Safety nazi to the rescue!
MattHirst
PostPosted: 18:34 - 20 Jan 2011    Post subject: Reply with quote
When drilling a pilot hole, you should never drill a pilot larger than the web of the drill you will be using to finish the hole.
As for drills wandering, that's where u-drills and spade drills are made of winnah. Cut steel like a hot knife through butter Very Happy
loply
PostPosted: 23:55 - 20 Jan 2011    Post subject: Reply with quote
I went over and saw the bloke who was advertising a chop saw for sale - £20 I got myself a decent nick thing with a fresh looking blade. Pretty big diameter.
It has a built in clamp which holds the workpiece really well, and I have to say the overall result was a lot more predictable, smooth and safe than using the Rage blade.
It also had a well designed route for the sparks to go, whereas the Rage flings stuff in every direction.
I think it's a lot better to be honest, and knowing that the discs are only a few quid to replace is reassuring.
Wish I hadn't bothered with the Rage blade now.
PostPosted: 01:27 - 21 Jan 2011    Post subject: Reply with quote
They are safe enough if you don't abuse them tbh. I don't like the noise or the mess but I never had one pop a blade. A cold cut saw is ideal for cutting such large bar but that's going to be way over budget.
MattHirst
PostPosted: 10:37 - 21 Jan 2011    Post subject: Reply with quote
We have 3 at our work and they are used multiple times daily and get one hell of a lot of abuse.
I've yet to see a blade go and we regularly cut tool steel etc. We have even cut carbide re-inforced/solid carbide boring bars with it before, they take a lot of cutting but do-able.
If you are having blades go then you are either swinging on it to try and cut through really quickly, not clamping your work piece correctly so you are getting sideways movement (imo the most common cause of a disc breaking) or having a chip in the cutting edge of the wheel and not dressing the wheel before cutting your workpiece.
loply
PostPosted: 13:04 - 21 Jan 2011    Post subject: Reply with quote
Do you need to dress abrasive cutting discs? What do you use?
I have a stoney/diamondy tool which is a red plastic handle with a cube of moonlike sparkly material on the end of it, which I use for reprofiling the grinding wheels on my bench grinder... Should I be using that to keep the chop saw blade square too?
SoND
PostPosted: 13:24 - 21 Jan 2011    Post subject: Reply with quote
No, leave it be.
The last post was made 15 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 120.8 Kb
