bike starts fine just wont pull away?! help
JogR001
PostPosted: 16:13 - 20 Jan 2011    Post subject: bike starts fine just wont pull away?! help Reply with quote
hi, my yamaha jog r starts fine then let it warm up abit then when u want to pull away it will just rev and not doin anything and the night before it was fine as i went for a ride on it any ideas?? Confused
jsquance
truslack
PostPosted: 16:19 - 20 Jan 2011    Post subject: Re: bike starts fine just wont pull away?! help Reply with quote
If you take the drive belt cover off, check if the drive belt has snapped.
dragstaar
PostPosted: 16:22 - 20 Jan 2011    Post subject: Reply with quote
First port of call will be to check the automatic clutch. Sounds like it might not be engaging.
JogR001
PostPosted: 16:27 - 20 Jan 2011    Post subject: Reply with quote
ok will have a look, could it be flooded carbs maybe? cus when u give a it a couple lil revs it will try n cut out some times :S
jsquance
Paddy Blake
PostPosted: 22:14 - 20 Jan 2011    Post subject: Reply with quote
Hi.
First check what the lads have said above as the belt could be broke and
coiled near the front of the casing causing it to cut out.
Leave the carb alone unless you have to check that or you could
make more problems for your self. Thumbs Up
The last post was made 15 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 42.76 Kb
