Bike won't start.
deliriousthun...
PostPosted: 15:39 - 20 Jan 2011    Post subject: Bike won't start. Reply with quote
Checked the usual things (kill switch, fuel tap, fuel).
Engine turns over, splutters a little but doesn't actually start. Choke/no choke/medium choke, no throttle/blips. Nothing does it. Every now and again it makes a "pop" noise, at various levels of volume, sometimes just a small pop, sometimes so loud it makes me jump.
I considered the possibility the pops were something similar to backfires (since I was feeding fuel without managing to get the engine going), but it seems unlikely. I don't know how the fuel would ignite (to cause a backfire) when the engine and exhaust are both cold.
I've never heard a backfire without the engine running and my helmet on, but I'd say this sound is more similar to the pressure release you hear in air brakes when a bus pulls to a stop.
I've had the bike for a couple of years now, never failed to get it started no matter the temperature.
Next thing I would check as routine is sparks, but the plugs are very difficult to get at (it's a v4), and I wonder if anyone here has any idea what coule be causing the popping noise.
Thanks,
Tom
Paxovasa
PostPosted: 15:43 - 20 Jan 2011    Post subject: Reply with quote
The pops are it back firing, you would have flooded it.
Leave it for a while (10-15 minutes) to let the petrol evaporate and Try starting it again, in the way you normally would.
PostPosted: 15:53 - 20 Jan 2011    Post subject: Reply with quote
Suspect the above it right.
However I assume it has an electronic tacho. Does the rev counter move when you are cranking it over? If not then seems likely that it isn't triggering a spark.
deliriousthun...
PostPosted: 16:07 - 20 Jan 2011    Post subject: Reply with quote
The rev counter flicks a little when it sounds like it's about to start, but obviously doesn't move much.
I should mention the back story though, back before Christmas, my uncle was going to the garage to fire up his bike, and I asked to do mine while he was at it. I spoke to him later in the day and he said he couldn't get it started, he'd run the battery down trying, and mentioned the same popping noise I described. No real surpise there, it's a 16 year old bike, there's a knack to getting it to start in the cold weather.
So I forgot about it (wasn't using the bike anyway), until last week. I charged the battery overnight, and I couldn't get it to start either. (I noticed he'd left the choke on, but I closed it before leaving the bike).
Left the battery hooked up to the charger for a week to make sure it was properly charged, and tried again today. Same problem, so I doubt 10-15 mins is going to make a difference.
Sparks it is then?
Tom
PostPosted: 16:17 - 20 Jan 2011    Post subject: Reply with quote
Not sure on your rev counter but would expect it to read something while cranking over, rather than just occasionally spiking. However if the tacho starts at a fairly high reading then entirely possible it will only show a reading when it is running (or just trying to run).
However it is easily possible that the plugs have just got fouled up.
Backfire through the exhaust can be REALLY loud. Loud enough to leave my ear ringing for several hours with the FZR once.
deliriousthun...
PostPosted: 16:31 - 20 Jan 2011    Post subject: Reply with quote
Ok, well I suppose I should be happy to hear that, means it's probably nothing serious. Just a pain to get the plugs out.
Thanks for the tips, I'll post back again if cleaning/changing the sparks doesn't help.
Much appreciated,
Tom
DAVE1952
PostPosted: 22:34 - 20 Jan 2011    Post subject: bike wont start Reply with quote
Hi has the fuel tap got a prime when i had my xv750 it was the same if i left it a week or two put fuel tap to prime she would start no problem .
blinky
PostPosted: 09:01 - 23 Jan 2011    Post subject: Reply with quote
sounds like you've got the same problem a lot of people have had recently, incl. myself (see the hornet thread just below yours). I've been told its ultimately due to this record-breaking, cold climate bastard of a winter!
i'm going to check the plugs and carbs today myself, or at least try too Sad
...just wish it was warmer!
good luck Thumbs Up
Better to ask forgiveness than permission!
Oh i miss my first love, the lovely lil CG!
Rouser 135 2012... Enfield 25... Hornet 600 2002... CG125 2000
The last post was made 15 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 62.53 Kb
