What is this restrictor
timboellis
PostPosted: 01:29 - 21 Jan 2011    Post subject: What is this restrictor Reply with quote
I found this restrictor kit when just browsing but no mention of what it is or how it works, any suggestions
I thought it was all washers or somthing?
https://www.jacklilley.com/images/parts/2548.jpg
PostPosted: 10:30 - 21 Jan 2011    Post subject: Reply with quote
Definitely looks like a throttle stop. It literally just stops the throttle opening fully. Good point, it won't mess with the mixture or risk damaging your engine, bad point, it'll reduce acceleration at all speeds and RPM - carb restrictors should (in theory) only start restricting at higher RPM as they limit the draw through the inlet.
You could probably bodge something similar up fairly trivially if that's the way you want to go.
The last post was made 15 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 36.32 Kb
