Replaced Small end bearings - still probs.
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
kev
I Hump Things
PostPosted: 19:25 - 07 Aug 2004    Post subject: Reply with quote
First of all what engine is it?
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
kev
I Hump Things
PostPosted: 20:26 - 07 Aug 2004    Post subject: Reply with quote
It will be far cheaper to just replace the engine.
If you do decide to fix it for a start your going to need a new crank and rod and maybe a piston as well if you say its a bit on the buggered side.
kev
I Hump Things
PostPosted: 09:42 - 08 Aug 2004    Post subject: Reply with quote
When big ends start to go they will get worse really as time goes by then they will just give up.
Your best bet really is to get another crank for it then put it back together and hope for the best.
PostPosted: 11:59 - 08 Aug 2004    Post subject: Reply with quote
Is there any vertical play in the big end bearing?
PostPosted: 16:52 - 08 Aug 2004    Post subject: Reply with quote
If the bore is well worn, could it not be piston slap?
Main bearings OK?
You said it yourself though, if you can get it rebored for that sort of price then go-ahead. If it is still clattering then just keep riding it 'till it lets go and get a new engine.
PostPosted: 23:52 - 08 Aug 2004    Post subject: Reply with quote
Sounds like the big end bearing is fine. You can check the mains for play but they normally whine instead of knock.
New over size piston and a rebore might be required, or get someone to accuratly measure the barrel first possibly.
From experience stick to original pistons.
The last post was made 22 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 75.44 Kb
