Odd NSR125 problems, clutch/gearbox? possible seize?
Fisty
PostPosted: 21:24 - 25 Jan 2011    Post subject: Odd NSR125 problems, clutch/gearbox? possible seize? Reply with quote
A lady at work fell off her NSR some months ago damaging the LHS of the bike quite badly and bending the forks.
We have fitted new forks, clutch lever, gear pedal, and hanger.
The bike starts in neutral but makes a horrid noise from the clutch/gearbox.
If you put the bike in gear it goes with a huge clunk. Also with the engine switched off If you put the bike in gear and pull the clutch in it its impossible to move the bike, the back wheel just drags. Yet in neutral it starts perfectly so I dont think it has seized.
Any Ideas?
Fatter and faster than Fret
rdboy88
PostPosted: 00:10 - 26 Jan 2011    Post subject: Reply with quote
hi have you checked the clutch rod that the clutch cable goes into pokes out the top of the clutch casing might be bent just an idea
weeeel
PostPosted: 11:07 - 27 Jan 2011    Post subject: Reply with quote
check the gear lever shaft hasn't been pushed through dissloging it from mechanism in clutch casing sometimes can be pushed through but shouldn't cause siezing find a friendly mechanic to have a quick look might be something simple if not i have a gearbox somewhere for a nsr somewhere with impellor seal failior but everything else ok does the bike move ok in neutral???? does it go into gear freely with engine off rock bike back and fourth with clutch out and change gear to see if all feels ok hope that helps but difficult to diagnose anything without seeing bike so unless your near north wales????
skatefreak
PostPosted: 12:11 - 28 Jan 2011    Post subject: Reply with quote
Hey,
Any news on the NSR?
Am very curious to hear how it goes...
Does the bike pull atall with the engine running and in gear with the clutch in?
Sounds like the clutch could be dragging heavily.
Best regards
-Jvr
Fisty
PostPosted: 08:43 - 30 Jan 2011    Post subject: Reply with quote
Turns out the clutch plates had fallen to bits.
The last post was made 15 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.76 - MySQL Queries: 13 - Page Size: 48.67 Kb
